  • July 17, 2025, 01:52:28 PM
Author Topic: Old Dog new ‘Trics; Fiorotti Timer Accelerometer Programming and Use  (Read 30524 times)
Offline Fred Underwood
The old dog in this thread may be the airplane or its owner. The airplane is one of the series that Dave Denison and I built and they are similar to each other in that they share wing templates and have similar parameters of nose and tail moments and wing and thrust lines.  The basic difference is the fuselage look, and construction, at times, from profile to built up fuse.  This one an attempt to look Similar 2 the 70’s fuselages as well.  Profile because it works for me to fly on Saturdays with Church on Sundays.
« Last Edit: April 19, 2016, 08:27:58 PM by Fred Underwood »
Fred
352575
Re: Old Dog new ‘Trics; old plane new Rogerio Fiorotti Timer
« Reply #1 on: April 18, 2016, 01:32:58 PM »
Similar 2 is two years old and has about 850 flights, all but the last 75 – 80 with a KR timer system. The owner is still trying to learn and keep up, and decided to try the new  ‘trics and found the thread on the Rogerio Fiorotti timer.  A Castle Edge Lite 50 ESC was acquired along with the Fiorotti Timer.  It seems that there may be only 4 users in the US, all relatively new, so basic information included.
System shown here in reply 17 and 18
http://stunthanger.com/smf/timers-by-fiorotti/new-control-line-timer-by-fiorotti/
and more here on the Timer site
http://www.metaenergia.com.br/
That was about one month ago.  Initially, it was a trial for a new build so the temporary home.
The bottom photo shows the timer moved from the back of the battery housing to the old switch position under the battery housing.
« Last Edit: April 23, 2016, 10:21:07 AM by Fred Underwood »
Fred
352575
« Reply #2 on: April 18, 2016, 01:55:07 PM »
So how do you like it?  Did you fly with it on Saturday?
« Reply #3 on: April 18, 2016, 02:19:09 PM »
Yes, I flew with it.  I have used it for a month without anyone noticing.  Better question is how did the judges like it - oh yeah, that was you.  And thank you for your comments.
Fred
352575
« Reply #4 on: April 18, 2016, 02:34:19 PM »
Install, set up and use to follow.  Hopefully with enough help for those who might be interested.
I found it fairly easy to transition from KR as both use button and lights.  If I had only known early on and used Edge lite ESCs, that expense would have been covered.  A good transition for those already using Castle ESC's.
« Last Edit: April 18, 2016, 05:31:48 PM by Fred Underwood »
Fred
352575
« Reply #5 on: April 18, 2016, 02:50:09 PM »
I've been OK with the Hubin timers.
And for any wondering, this plane is awesome. The pilot is pretty good, too.
« Reply #6 on: April 18, 2016, 07:58:16 PM »
Thank you Randy for the kind words about the dog, or dogs.
I don't have a good comparison as to the Hubin, not used one, but I use about 5 - 7% less battery than I did before.  I am not sure how that will hold over the course of a season and wind conditions, but good so far, and I have tried some wind in practice with the same settings.
As I get time, I will post a few further pictures of the install, and then talk through the set up and thoughts on flying.
Fred
352575
« Reply #7 on: April 18, 2016, 10:23:25 PM »
The Accelerometer pad is about 0.65" wide and the 4 prong plug from the sensor is about 0.4" wide.  The allowable fuselage is 0.75" behind the wing TE, and most are 0.75" after the front section.  A tunnel was made in the fuse by temporary removal of the bottom, and a housing box cut into the fuse side.  If the opposing fuse side is thinned appropriately, then the 0.65" pad can sit inside the fuse with a box cover on one side. Photos demonstrate a method useful for installation in a profile fuse.
Fred
352575
« Reply #8 on: April 18, 2016, 10:28:49 PM »
And then putting it back together in the following photos, and then to paint the cover white.  Set up and use will follow now that it is housed.
Fred
352575
« Reply #9 on: April 19, 2016, 11:54:37 AM »
Fred, did you have to move the sensor around to find the spot that worked. Looks like yours is much farther back than mine. I wonder how critical that is because I just stuck it on the balance point and it worked fine.
Re: Old Dog new ‘Trics; Fiorotti Timer Accelerometer Programming and Use
« Reply #10 on: April 19, 2016, 08:12:13 PM »
The Fiorotti Timer uses an Accelerometer to adjust power as needed. Functions include, in non-engineer terms and hopefully correct
1) Start delay in seconds
2) Time in minutes to be used with 3
3) Time in seconds
4) Sensitivity for "424" which is rpm gain or possible reduction based on "tilt" or angle of the sensor
5) Increased or decreased rpm sensitivity based on centripetal acceleration
6) Limit of rpm increase of 5
7) Limit of rpm decrease of 5
and base RPM adjustment.
Defaults are preset as a starting point.
In addition, sensor placement is a variable.
And finally, an ESC is required, Castle suggested, and some programming is needed and values are provided as starting points.
As MM found, the timer and sensor can be used essentially as sent.  I tried a different approach as the rpm default in particular concerned me.  A tachometer reading showed around 9600 rpm if I recall correctly, but that is not an exact set, but battery cell number/voltage, motor and Kv, and perhaps prop dependent.  Before heading to the field, the rpm was adjusted as per the website video to about 10,300 - 10,400 rpm, the previously used value. That also provided a basic understanding of the programming sequence.
It is somewhat difficult to describe and understand the programming without having any demonstration, but the rpm video may be helpful.  The rpm video shows the rapid sequence flashing that is encountered in setting rpm, and in entering function programming.  Best observed to be understood, so if you are trying to understand, look at the video for rpm. Flying with all default settings is fine, but, the time for default was 3 minutes and 20 seconds.  Specifically short to allow the user to figure lap times or rpm, and battery usage over 3 minutes and 20 seconds and then calculate what 5 minutes and your choice of seconds will bring.  No use in killing a battery from too fast rpm for too long.  I found that the best way to learn the function setting was to repeatedly set minutes until comfortable. Minutes because that was the only change along with rpm to get a basically good full pattern flight.
Setting rpm requires holding the start button in until you have observed two sequences of rapidly flashing lights.  There is a several second delay between the two sequences, so expect that. That can be observed on the video.  To enter the function section, hold the button through the first sequence and then release and then wait a few seconds.  The timer will then self interrogate and show defaults.  Function number is the number of long flashes and the actual setting is the number of short flashes following and the timer will continue self interrogation through the seven functions.  My concern was function 3, minutes and the 3 long flashes was followed by 3 short or more rapid flashes. Once the timer cycled through a time or two, I begin to understand the sequence.  It is then a matter of holding the button in at the start of the function/flashes that you wish to change.  The long flashes and short will go as usual, button still in, and then release the button.  After giving you the current setting, the short flash sequence then repeats and you press the button at the desired number of flashes.  Let the timer continue briefly, then you can unplug to store the setting.  I then re-interrogate to make sure that I have what I want.  While very wordy and tedious to describe, it is easily done after first couple of times quickly and without difficulty at the field.
Hopefully this will help in addition to instructions on the site, written in Portuguese and then translated, Google or similar.
Fred
352575
MM,
IIRC, the suggested sensor position was 30 - 40 mm behind the bellcrank pin. That did not happen to work well for me on the wing, but that may have been the issue.  I will post more on sensor location over the next days.  It may be the ideal position for you.
Great to see that you had a good experience.
Fred
Fred
352575
Offline Curare
« Reply #12 on: April 19, 2016, 08:28:50 PM »
Fred, is that a pink foam core in that profile?
Is that full length?
Sorry for the off topic question  :(
Greg Kowalski
AUS 36694
IIRC, pink foam, 1.25 lb/cu foot, from trailing edge forward, too heavy for tail end when compared to triangulation of balsa.
Fred
352575
Offline Curare
Interesting, I'll have to try that one day.
I'm looking forward to reading flight reports of the new system!
Greg Kowalski
AUS 36694
« Reply #15 on: April 19, 2016, 10:30:08 PM »
 Setting rpm requires holding the start button in until you have observed two sequences of rapidly flashing lights.  There is a several second delay between the two sequences. To enter the function section, hold the button through the first sequence and then release and then wait a few seconds.
 The timer will then self interrogate the current settings.  The function number is the number of long flashes and the actual setting is the number of short flashes following. The timer will continue self interrogation through the seven functions then repeat.
 Once the timer cycled through a time or two, I begin to understand the sequence.  It is then a matter of holding the button in at the start of the function/flashes that you wish to change. My concern was function #2, minutes. The 3 long flashes were followed by 3 short rapid flashes indicating 3 minutes.
I rearranged your post a little bit to help me understand, tell me if I got it right.
You had me until that last paragraph. Let me see if I understand. You push the button and hold it to choose a function and it keeps repeating the current setting of that function until you release the button. Then it keeps repeating the max number of flashes for that function so you can count out the number you want and press the button to choose?
MM,
Sorry for the delay in getting back to you.  Hopefully the PM helped.  After a few reads of what you wrote, I think that the question or difference is mostly in regard to how long to hold the button in.  I release the start button after the long and first couple of short flashes for a function.  If only 2 short flashes, such as with seconds, then it may be for the whole time.  I believe that after the interrogation cycle, the flashes are then all short waiting for the user to chose the desired number.  The full number will recycle if you don't chose.  I have not tried and am not sure what happens if you continue to hold the button in.  I am sure that you could try it without harm, as it could easily be done since one might not remember the current setting and still have the button in when you come to the end of the actual short flashes.  As noted, I let off after a couple of short flashes.  My guess is that you would be in the full range in flashes even with the button in, but not sure.
Fred
Fred
352575
First flights were interesting as hearing the prop noise change and realizing that the timer/accelerometer is actually reassuring and a bit mesmerizing at first.  As mentioned I did a few short flights to assess amperage usage and make adjustments, and then went to 5 minutes 20 seconds.  I started with the sensor taped to the undersurface of the inboard wing because of easy access, and about 40 mm behind the bellcrank pin as suggested by Rogerio. The flight was a bit fast and the outside loops were definitely faster than inside.  Inverted level seemed a little faster than upright.  An early datalog from the Castle confirmed, see below.
If not familiar, the top line is rpm, and the pattern maneuvers are sequential across the graph.  Under is ESC temperature, then amp usage. More data is available as a choice on the datalogger, and in particular, throttle response which demonstrates accelerometer/timer function, but then rpm is an adequate reflection. With a little imagination and a straight line through the center of the inverted flight section an rpm increase of about 100 - 150 over the initial upright laps is noted, also confirmed on an actual datalog with the cursor reading rpm at a given point. Much more apparent is the elevated line without much slowing in the outside loops versus insides.
Since the timer accelerometer does not have functions to adjust for that, sensor placement issues seemed likely.  Again, the sensor was taped to the inboard wing bottom, smooth side up.  Figure the tapers of a symmetrically tapered wing, the sensor was mounted with enough angle(s) to need adjustment.  The wing high point is fairly close to that 30 - 40 mm suggested location and I thought that the calibration might tare that out so to speak, but not so.  Without any rocket science or engineering skills, leveling the sensor to a wing center line seemed reasonable.  In reality, leveling helped, but to get to even upright and inverted/inside and outside, the sensor ended up being a bit off level in the opposite directions. A couple of shims were tried until the desired results.
Also on the original datalog was an end amperage usage of 1.87 amp hours.  RPM was higher than desired, faster lap time, so for future rpm was lowered with lower amp usage.
Fred
352575
Make sure that you're not compensating for your whole plane being tilted -- vertical CG or flap tweak could cause a general tilt one way or another, which would require the shimming you describe to overcome.
Good thought Tim.  This particular plane has about 850 flights and hopefully enough observers to have seen that already.  I believe that it is flying in correct attitudes (hopefully the old dog owner has the properly adjusted attitude as well).
I should add that there is a bit more information that I would have added later.  The wing shim was about 3/32 higher at the high corner.  Once the sensor was moved into the fuse on a carefully leveled slot, that shim is only 1/32 higher at the high corner, but noticeable if 1/32 different more up or down to flat.
The new datalog showed improvement, but still slightly high rpm on outsides, below
« Last Edit: April 20, 2016, 09:48:18 PM by Fred Underwood »
Fred
352575
Fiorotti told me the 40mm from the balance point was a max measurement not a starting point.
MM,
I started at about 40 mm "from the bellcrank pivot point" as noted in the instructions, and the crank is already a bit behind the balance point.  My crank is well behind the balance point/CG which has moved forward.  When I initially had differential rpm as above, I tried a different point just to see if it made much difference, and it did not in my case.  As described, there was some sensor tilt adjustment.  Since it didn't make a problem having is back, I used that position as it made the internal mount into the fuse easier.  The cheek/light ply mounts extend back as you can see in an early photo above.  I believe that Rogerio has given safe well working reliable instructions. That location may balance well with the default settings and be most trouble free.  If it all works well at 40 mm and is easily accessible, no reason to try to move.  It may mean a change is sensitivity is necessary to balance the change in position.
How did setting changes go?
Fred
Fred
352575
The Fiorotti Timer site at "com.br" has only been intermittently working in the last couple days.  Hopefully quickly fixed, and will be moved in the future. If you need to contact Rogerio, PM through SH still seems to work.
Fred
352575
I successfully changed the flight time, now I need to change the flight speed.
Offline Rogerio Fiorotti
    • Control Line by Fiorotti
For me every time I accessed the site www.metaenergia.com.br worked properly, the site provider could not explain the problem reported by Fred, but hopefully stabilize.
Tomorrow will be doing video on changing the timer programming, so you're ready I notice everyone.
Rogerio Fiorotti
If you changed the time, then you are in the functions and all should be fairly straight forward now.  The instructions for rpm along with the video are fairly easy to follow. It will be interesting to hear further flight reports.
Rogerio,
After your post I got on the site again for the first time in 2 days. Perhaps something with my computer though all else seems ok. I mostly just wanted people to know how to contact you if they had problems with the site.
Fred
Fred
352575
After initial setup flights were done to try to tune the system for my preferences.  This system is very flexible with adjustment of item #4 the "424" a graded rpm change with angle change and blended with #5 rpm change based on centripetal acceleration.  The system is quite usable out of the box after adjustment of appropriate rpm and flight time, but curiosity prevailed about what could and could not be done.
If 4 is set very low or off, then angle changes are essentially eliminated and centripetal acceleration controls.  Flown this way with advanced sensitivity of 5 and high limits of 6 and 7 were fun, but can get past practical.  A significant rpm can be seen, felt, and heard in the corners to a point of becoming a little unsettling of the airplane.  That can be blunted with limits mostly of 6. The decrease of rpm seems less pronounced and has less need for limit, or allows a numerically higher limit (larger decrease of rpm).  Flying more off of 4 with 5 desensitized gives good rpm for up and flying high, but gives little decrease in rpm; 4 functions better to add rpm than decrease.  And finally, the base rpm is a factor as to how much rpm gain is needed. All fun to experiment with, but time was getting short before the first contest.
I should note that the datalog graphs are not good to tell much about 4 and 5 changes, except to note rpm.  You obviously don't get a feeling of timing of the power/rpm gain or decrease from the graph.
The datalogs below show first a lap time of about 5.25 with 4@5, 5@13, 6@8 and 7@10.  Peak rpm got to 10,700 and level at about 10,100.  The second datalog was the day before a contest when I somewhat foolishly changed settings late in the game with lap time to about 5.32 and base rpm about 9950, and 4@6, 5@12, 6@6 and 7@10 and peak rom got to 10,500 with less corner kick and a smooth flight.  Fortunate late change for me.
Also note the throttle changes on the datalogs, changes by the accelerometer.
Using a blend of functions 4 and 5 with 5 limits (6 and 7), I feel that the rpm gain or decrease is well timed and easily controllable and helpful. Wind up is also manageable using 5 and a large number for 7 to allow a decrease in rpm.
Fred
352575
If a picture is worth 1000 word, the video is worth much more. Programming was a bit difficult to describe. The programming video and rpm video make field changes very easy, thanks Rogerio.
Fred
352575
At first I thought about doing something more advanced as using a box with display for programming, much easier to visualize but my challenge was to use one LED one Switch and lower cost.
I know that in the beginning is laborious adapt with LED flash but then is very practical.
Rogerio Fiorotti
It should be noted that a computer is not needed or desired, for most, at the field. In fact a computer may be needed only once to set the parameters in the ESC.  The computer adapter is available from Castle for free with a purchase of a new ESC by emailing in a code, included in the package.
Datalogging was useful at the beginning, but mostly confirmed that my observations were correct.  Most timer changes can be adjusted on the basis of observation and feel, to accommodate user desired feel and style of flying and the specifics of the airplane.
I fly with datalogging turned off.  As annoying ticking was encountered and it seems to be a problem of the Castle ESC and some outrunner motors.  An old reference to that was found in an old Castle FAQ section.  A Castle rep initially stated that the problem was with the old Phoenix units, but it turned out to be still present with at least my particular combination of Castle Edge Lite 50 and Cobra 3520 14 motor.  It does come and go with datalogging on and off.  The Castle rep felt that it was not harmful, just nuisance. I am past much value from datalogging, so leave it and ticking off.
Fred
352575
Make it so it works with the Hubin break out box and you're golden.
Offline John Tate
The RPM video that Rogerio did help me a great deal. At first the flight the lap times were too slow. I programmed the timer with one more "blink" and then the lap times were too fast. After watching the RPM video, the nose of the model was tilted down. I followed the instructions. On the next flight, the lap times were what I wanted. You just have to take you time and learn how to use this timer. Once you use it, you will enjoy it.
John Tate
So the difference is when you change flight time you blink in a certain number then push but when you change speed you just push once to add or subtract speed depending if the nose is up or down?
The video is a little confusing because at first he raises the nose then lowers the nose. Do you have to do it this way or was he just showing nose up for increase and down for decrease?
If you push once to raise the speed then fly and you want to raise the speed again do you push once again or, do you push twice or, will pushing twice raise the speed twice as much as the first time?
In the video shows the operation of how to change the engine rpm, notice the LED lights in the positions up (increase rpm), down (lower rpm) and level (record).
In any position you must click START, eg to increase rpm put the nose up click START how many times you feel necessary, level the plane and click START to record.
If to decrease rpm nose down, and do not forget of leveling and START to record.
Rogerio.
Today I flew in variable wind of about 0 - 10 and all directions except from the south, of course, not away from the sun. I decided that the lap time was a bit slow for comfort in all of the variability - about 5.35.  After 2 flights with the lines still on the plane, a fresh battery was mounted, the timer held for the 2 rapid flash sequences, then the plane held nose up for one button push, then back on the ground and the ready light on.  Button pushed for the rapid flash noting memory storage and battery disconnected.  That was quicker and easier than my typing of the description.
Flight then confirmed lap time of 5.29, actually 52.94 for 10 laps.
For the MM question above, if more speed change is desired, the sequence and number of flashes starts over at the new level.
I have made changes to the functions numbers similarly, according to their instructions, with the plane on the lines and ready.  A couple of practice runs relaxed at home made that easy. Rpm practice changes done and checked with a tach, and function changes done and confirmed by interrogating the functions.
Fred
352575
Offline John Tate
It is still kite flying weather here on the east coast of Virginia. The average wind here is around 10 MPH. I am having trouble with the model speeding up, (wind-up), while approaching the bottom of the loops. This really screws up my timing. On a few calm days that I have, the model flies fine in the loops. I only have 5 steps for programming the timer. I emailed Fred Underwood and found out he has 7 steps on his version. The  newer version looks like it will  limit the RPM and help prevent wind-up in the loops. Anyone having the same problem that I am having?
With this version only you and the winner of the draw.
If you want to send with the new version free of cost, we shall treat it by e_mail ok?
Rogerio
Offline John Tate
I went out and flew a couple of times today in mild winds that were around 7 to 9 MPH. There was no wind-up in the loops in mild wind conditions. Now I really enjoy this timer/accelerometer setup. I just had to learn how to set it up. When you are used to doing things the old way, it is hard to learn something new. I can see why Fred titled this tread " Old Dog new Trics". For only having a wind-up problem in loops during high winds is a minor thing to me. Rogerio just sent me an email and is helping me out. We just need to get more control line modelers to try out this timer/accelerometer setup so there will be a large data base to learn from.
The last few outings have had alternating weather, 10 - 12 mph wind and 0 - 4 mph wind.  Fortunately the timer has performed well as I gain experience. When flying in the wind the plane will gain about 2 laps by the end of the flight with the non-wind setting.  2 laps is about 10.5 seconds and there are approximately 61 laps, or lap equivalents, in 320 seconds so the gain is about 0.15 seconds/lap.  Knowing that a flash of rpm gives about half of that, 2 flashes of slowing mostly corrected the lap time and made the whole flight better.  If the speed for a lap goes up, more so for the maneuver as the accelerometer adds.  The other settings were left untouched.  I might use a third flash for wind in the 15 mph range, but easy enough to tweak after the conditions are known.
The next day, I flew a flight with the "wind setting" and it was much too slow, could barely do overheads.  2 flashes of faster rpm solved it.  Next windy outing I used 2 flashes of decreased rpm before even flying and that seemed perfect, and next slow day, corrected back with 2 flashes of added rpm.
I have seen others with different systems change props and make other adjustments, including IC.  Adjusting the "needle" up or down seems an easy solution.  Interesting that before the Fiorotti system, I also gained 2 laps in the wind but then without the addition of accelerometer input, I liked the added speed. That speed is not necessary of desirable with the accelerometer making adjustments.
Wind-up seems well controlled with this system once adjusted for speed.  Some have said that flatter pitch and 3 blades props also help, but this seems ok with the 13 x4.5 F2B prop, slightly trimmed for prop clearance, running in the 10K range.
Fred
352575
How many times do you have to push the button to get an rpm increase of 1000 rpm? I'm trying to go from 8560 to 9560. From what I've been doing looks like an increase of 10 rpm for every push so, do I have to push it 100 times?
Next question. If I'm flying good at 9560 with the Hubin FM9 timer how much less rpm can I run with the Fiorotti timer.
Online Howard Rush
...13 x4.5 F2B prop, slightly trimmed for prop clearance, running in the 10K range.
My system has an auto-prop-trim feature that works on takeoff.  It works well with an APC.  I hope not to use it on an Igor.
I was able to get the rpm adjustment I needed. I just had to get a feel for how many times to push it for X rpm change.
I was winner of the draw and mine has 7 adjustments. The last 2 are min and max rpm which are still at factory default of 5 blinks. I haven't flown in high wind so I don't about the wind up. But I'll be playing with those settings next if it ever stops raining.
I can hear it power up at 45 degrees in a wing over and power down at 45 degrees on the down side. Pretty cool.
A little trial and error is a fairly quick way to get the answer, and I see that you have.
An explanation then rather than an answer.  The numeric rpm change/flash can vary based on several factors including base rpm, number of cells in pack, prop, base voltage and probably more than I am recalling right now.  That said, what I recommend is that you stooge or tie the plane down on a bench and get a tach and get comfortable.  Have batteries charged to flight level. Tach the current rpm and then raise a few flashes and recheck rpm.  After you are at about normal flying rpm, then bump up or down a couple of flashes and tach, and get an approximate rpm/flash change.  As an approximation, I am probably in the 75 - 100 rpm/flash range.
Be sure after doing the nose up or down flashes to have the system record the change, get the last rapid flash, not just unplug.
Always set rpm with a battery charged to the same point that you would for flying.  Changing voltage, or using a partially spent battery will not give reliable results.  This means that after you set and tach, use another fresh battery for the next rpm change.
Start with about the same rpm as you would usually use.  You may already know how many laps you get after a normal pattern.  That should be fairly consistent. If not already known, then take note for a starting point.  For emphasis, start the first flights with the same rpm normally used until you are satisfied that the timer is roughly set for your feel.  It will likely be too fast level, but better than too slow.  Fly short flights until you get some data on lap time and battery usage.  No reason to over use a battery trying to shorten the learning curve.
Now please be patient with the explanation.  Once you are close, you don’t need a tach.  Set by laptime, or just by flying style and feel, as follows.
320 seconds, a fairly normal flight time has about 320/laptime laps, or “lap equivalents.”  Sorry for the made up term, but that is about 60 or 61 5.2 second intervals.  If I change a lap time by about 0.1 seconds, I then gain or subtract just over 1 lap, 60 x 0.1 is 6 seconds.  My plane flies well at about 4 – 6 laps after the clover.  I can still manage at about 2 laps and from what I recall, that is about 5.4+ seconds and 6 laps left is in the 5.15 – 5.2 second laptime range.
If a lap is divided into 52 intervals of 0.1 seconds then 9600 rpm needs a change of 9600/52 to change 0.1 second.  about 180 rpm is about 0.1 second lap time change.
Short version,
find the rpm/flash change
note the number of laps consistent after a full pattern
Appropriate number of flashes to add or subtract time based on laps remaining.
Real short version
slow about 150 – 300 rpm from previous flight
But don’t start there until you see how the plane is flying.  A 5 minute flight too slow to do anything but survive is not fun.
And Howard, I also have the auto-prop-trim and have used it a few too many times. When I noted that I trimmed for prop clearance, I didn't note the method.   Even the KR had that feature.  But, do you also have auto-prop-balance?
Fred
352575
Are you saying different voltages will give you different amounts of rpm change per number of pushes?
I just make my adjustment then check it with a tach after it re-sets. I can repeat several times with the same battery. If there's a difference from battery voltage in how many times you have to push the button to get X rpm it doesn't matter to me as long as I get the rpm I want.
Number of flashes doesn't matter.  If I run for tach settings I change the battery after each run.  If not, I believe that you may get a difference from your test when you use a fresh battery at full voltage at the field.  In addition, remember that the timer needs to calibrate at the new setting while flying level.  If you run about 20ish seconds for tach run, it may think that is has calibrated, but that will be with no centripetal acceleration sitting on a stand.  If you don't get a solid light for about 3 laps, it is not calibrating.  You can force a calibration run by raising the rpm, or lowering, one flash and then flying.  The calibration light is noticeably longer than "gear" light.
An example of above is that I charge to 4.17volts/cell, not 4.2.  If I put a 4.2v charged pack, I get a different run, and not subtle. Similarly, if I start a flight with a pack after a 30 second tach run, then I could get a different rpm for that flight.
At the field, I may set the rpm up or down with appropriate flashes, then store and not check with a tach.  Essentially no mah are used for setting, so the flight is normal, starting at normal voltage.  I only used the tach to approximate the initial beginning rpm.
If you datalog, you will get a reasonable rpm reading from the log.
« Last Edit: May 22, 2016, 09:18:47 PM by Fred Underwood »
Fred
352575
Hi Fred,
Just wondering how much does the run varies in lap speed with your set up? (4.17V vs 4.2V)
Joe, I didn't quantify it that way.  I was in a hurry to get the initial rough rpm setting and used mostly charged batteries, but not all equal.  I could not make sense of the rpm numbers. The KR timer I had used read rpm from a sensing wire and it didn't seen to matter even if I set rpm with a flight used battery.  I fortunately found out on the ground that consistent voltage is important in trying to establish an rpm. Just charge your batteries to your flight level, that will be to full charge for most, and then always the same.  Since I would do a tach run for say 30 seconds or a bit more, I learned to change to a different topped battery each time.  I have enough battery left that I could probably charge to 4.15 and then adjust back to lap time, but not motivated enough.
In practice, I set the rpm about 200 rpm less than with KR and after that adjusted to flight speed or lap time.
I discussed this with Rogerio who noted that he suggests to always use a full battery, and added that note to the Castle ESC settings file on his site. I find that batteries always charged to the same level work, even if not full.
Fred
352575
I went out yesterday with 3 fully charged batteries and made 3 adjustments for more rpm. Before adjustments flight speed was 5.60 previous day. 1st flight 4 pushes nose up then 5.40, 2nd flight 8 pushes nose up then 5.50, 3rd flight 10 pushes nose up then flight started at 5.60 then slowed to 5.80.
After 2-3 level laps there was no perceived increase in rpm and flight was timed every other lap on a 2 minute flight of level laps.
Today I'm checking the settings on the esc and cleaning all connections and will try again.
Offline Tania Uzunova
  • It's something more about gravity ...
    • www.indoorgeebee.com
Dear Rogerio Fiorotti,
the fact that i am silent the last month's it doesn't mean that i don't read and notice about your post and webpages.
I would like very politely and delicate to warn you about your timer, advertisement, introduction, information, showing pictures (especially graphics)!
Active timer of Igor Burger has copy rights! As well information in max bee webpage and gee bee indoor webpage.
I would like to let you know that the fact, He (we) shared since many years information about our products and mostly here for stunt hanger community is for non commercials goals. But everything else which goes over that level and limit, it can happened so to underwear low and person who started it, it will be taken as formal responsibility person.
We understand your creativity and tries to represent something which cl stunt people can use, but i would like to be also well understand it - that i found your way for not the popper and correct one. Honestly some "copy paste" work for me is truly visible and i assumed that certainly the set up, which you represent as working - it doesn't!
At the end with very friendly feelings i would like to ask to be more kind and more polite in representing your ideas and especially adverds. as product!
Sincerely,
Tatyana Uzunova
