  • June 19, 2025, 06:23:45 AM
Author Topic: esc programing  (Read 677 times)
Offline John KruziK
esc programing
« on: December 30, 2013, 08:11:33 PM »
Have a dumb question, the esc programer doesn't get mounted on plane does it? The esc is a trust Brand and the reason I ask is it seems like it can be installed between esc and timer. The instructions talk about setting up with r/c radio. thanks
AMA 874027
Offline Dean Pappas
Re: esc programing
« Reply #1 on: December 31, 2013, 02:37:33 PM »
Hello John,
No the ESC programmer is something you use on the bench and then set aside.
I am not at all familiar with the Thrust (trust?) ESC.
Will you be setting up an RPM governor in the ESC and using a timer, OR will you be using the ESC in fixed endpoints mode with a governor/timer like the KR?
If this question makes no sense, then start reading and asking ...
Welcome and Regards,
  Dean
Dean Pappas
