Electric Stunt => Gettin all AMP'ed up! => Topic started by: John Sunderland on November 11, 2009, 09:25:59 PM
Title: Ok here is my plan! GET HELP HERE
Post by: John Sunderland on November 11, 2009, 09:25:59 PM
 I have 59 oz. airplane less fuel. With fuel its a 65 oz airplane. I am putting a 630/40 sq. in. wing  in rather than the 661 it had. Same wing,, three inches less span .I will be cutting out motor mounts, re- doing  the bottom bock and cowl as I will have no need of a pipe tunnel, so may save an  oz or two there. Another oz with the wing span reduced. Im guessing  I can get this to come in at 54 to 59 oz.
I am considering a Turnigy 35-48B motor and their $30 5s. If they work four or five of these wont break the bank. Not including  the timer and  ESC a battery and motor are weighing  in at 15.99 oz. I am quite sure this will weigh less ready to fly than the 65 oz. take-off weight I have come to recognize as, " normal weight". Hmmm an over powered 54 oz airplane.
Am I headed the right direction here fellas?
Title: Re: Ok here is my plan! GET HELP HERE
Post by: John Sunderland on November 12, 2009, 10:20:25 AM
 H^^ How about some feed back fellas!
Post by: Alan Hahn on November 12, 2009, 10:54:35 AM
John,
I have no experience with the Turnigy line, but I bet someone who has will be popping in soon with some advice!
Post by: Mike Anderson on November 12, 2009, 11:34:25 AM
I have been poking around on the HobbyKing site, just to brush up on the items discussed here - my initial reaction is that a 54-60 oz model should be fine on a 4 cell setup.  One combination that we have flying here is the Turnigy SK3548-900 on 4 cells.  Plenty of power with a 12-6 for a model of that size, with adequate headroom for a governor mode ESC to do its thing.  It will also handle a 13" prop and the extra current that it requires.  I have also been using my Twister as a 4 cell testbed with a 900 Kv motor and a Phoenix 45.  Weight is probably right around 51 oz, like it was with a 3 cell setup, and the power is way more than needed.  The 3 cell/1100 Kv setup drew an average of 3000 mah for a 'full-pattern' 5:30 flight.  It appears that the 4 cell/900 Kv setup will be under 2500 mah (maybe even less) for the same flight (both using a 12-6 prop).
If you really want to do a 5 cell, I would opt for a motor with a lower Kv -- in fact, I think even with four cells and a governor mode ESC, you could get by with a Kv of 750 - 850.  You could choose a C4250-700 or even an SK4240-750.  There is also one of the 'red & blue' motors - a 3548-850 that I've been thinking about giving a shot.
I would also like to point out that the SK line is a step up in quality over the "C" line motors - they have better magnets, better bearings and (in the 35xx size, at least) larger shafts.  That said, I have flown the Twister with both an SK3548-1100 and a C3548-1100 and there is no discernable difference in the way they fly on the Twister.  The main considerations there would be if mounting it in a full-fuse, that you get some cooling over the motor and battery, whichever model you choose - I can tell you that it is possible to cook a motor if there is no cooling and as soon as I get it re-wound, I can tell you if the Kv was a little too high or not.
Post by: John Sunderland on November 12, 2009, 03:24:03 PM
Thanks Guys,
All help and advice is much appreciated. Im All Amped Up! y1 #^
Post by: John Witt on November 12, 2009, 06:01:15 PM
My Panther has been flying with the Tgy 3548-800 very well. Spins a 12-6 APC with no problems and will go a lot faster than needed. The plane is 47 ounces, so lighter than you're are talking about, but my guess is that it will work fine.  The 3D RC guys work these motors a lot harder than we do. I'm only using about 2100 mAh (Zippy 4S pack) for the full pattern, plus 2-3 extra clovers at the end, 340 second runs, and the motor is barely warm with 60 deg ambient temps.
Hope to get some data this weekend with the Vector on the same power train, but with the ICE 50 ESC, so can tell more then.
We're having fun now!
Post by: Dean Pappas on November 12, 2009, 08:48:34 PM
Hi John,
Your near 60-ouncer will fly nicely with a 4S 3850 ~ 4200 mAh LiPo and a motor that weighs between 6 and 8 ounces that jhas a Kv of 800 to 1000, assuming a 12-6 prop. You'll like the pusher better, honest.
If you go up to 1200 on the Kv, then you could easily run a 4 or 4-1/2" pitch in the same diameter, and if you go lower than 800, you'll probably need a 7" pitch to keep enough voltage headroom for the big loads near the end of the schedule.
My rule of thumb is to plan on running at (or very near) an RPM of 75% of Kv times the battery voltage. In your case it's 4X3.6 or 14.4V. If you used a motor with a 900 Kv, then 0.75 X 14.4 X 900 = 9700 RPM. on 65 feet that's about a 5.5" pitch, but I'd just run the 6 and lower the RPM to just above 9000.
If you go for a 5S battery, then shoot for a motor with a Kv of 700 ~ 800 and a capacity of >3200 mAh.
Expect to consume about 2800 or 2900 mAh with the 4S and 2300 ~ 2400 mAh with the 5S.
My rule of thumb is that it takes about 0.7 watt-hours per ounce of airplane weight to fly the schedule.
A 4S-4Ah battery has 14.4V times 4A-h  in it or 57.6 Watt-Hours in it, and you should limit yourself to using 3/4 of the battery for the sake of battery life. Both above combos adhere to that.
Hope that helps.
Dean
Post by: Mike Scholtes on November 12, 2009, 10:32:34 PM
The Turnigy Aerodrive SK 4250 is a 650kv motor, which I have paired with the TGY 3300 5S battery. Not in the air yet so can't report on results, but the Adamisins are using this TGY motor in a Strega with good performance. This motor gets high marks from RC 3D users, too. Check out the thread on "motor choice for larger models" a month or so back. Your 630" model probably does not need or want a motor this large, based on what I have learned here. The AXi 2826 series would be plenty, and the equivalent Scorpion is about $30 less. Both are available in kv ratings to use either 4S or 5S batteries to get into the right rev range. The smaller TGY Aerodrive SK 35-48 series should be fine, but again I have no personal experience with it. It has a 5mm shaft as do the 42 series (and the AXi and Scorpions). The 4250 is 9.1oz while the AXi is 7.1, an important difference that far forward. The SK 35-48 is 6.9oz.
Post by: SteveMoon on November 18, 2009, 07:13:11 AM
John: I just ordered a complete Turnigy setup to convert my Imitation to
e-power. Should be a piece of cake with the firewall front end. I'll let you
know what I think when I get it in the air.
Post by: Robertc on November 18, 2009, 08:32:29 AM
Steve,
You mean I won't be the only electric at the Dallas contests next year?
Robert Compton
Post by: Jason Greer on November 18, 2009, 09:27:47 AM
I was the only electric at the labor day contest this year.  I'm looking forward to flying with you guys next year.  My new weapon is already under construction. :)
Post by: Archie Adamisin on November 18, 2009, 11:02:57 AM
John,
I have a 35-48-1100 SK that is an absolute stump puller.  For Stunt, I would recomend the SK 35-48-900Kv  as on 4S it would give plenty of RPM for say a 13 x 4.5P and a bit less current than the 1100 Kv.  Cut it down to suit, but it will turn the full 13" no problem.  I would also use 4S 3700's from Turnigy to save money if that is what you are looking to do.  You might find that as you optimize the system, you may be able to get down to 3300's.
Archie Adamisin
Muncie, Indiana
Post by: John Sunderland on November 18, 2009, 12:57:48 PM
John,
Archie Adamisin
Muncie, Indiana
Thats what I wanted to hear Archie! THE PLAN is in place! y1 A Hubin timer and  CC speed controller. The 4s 3700s it is,. four of these and a charger. Already bought my props. I will clip/work the props as necessary.  Mucho Thanks to all. The shop is just about together. I will post some pics real soon.
Post by: John Sunderland on November 18, 2009, 01:00:38 PM
Thanks Steve, much appreciated and I look forward to your findings and opinion.
Post by: Archie Adamisin on November 18, 2009, 06:52:43 PM
John,
Let me know when you have an idea of final weight, desired lap time, and line length.  I would recomend the 13 x 4.5P prop.  You may decide to chop the diameter if you don't want to run all the diameter, but a 640 sq in bird should be able to handle it.
Whatever you decide, I can send you a program for your controller to upload and should get you within a few tenths of your desired flight speed.
Can't wait to hear how your ECL model goes.
Archie Adamisin
Muncie, Indiana
Post by: John Sunderland on November 18, 2009, 10:27:45 PM
John,
Archie Adamisin
Muncie, Indiana
Thanks again Archie, I cant wait either. I will stay in touch . Your time and help is greatly appreciated!
