  • June 15, 2025, 09:09:18 PM
Author Topic: oiling your electric motor  (Read 743 times)
Offline keith varley
« on: February 14, 2012, 05:44:20 PM »
I started out this year with a brand new Axi in my E-Sultan for 2012.The motor was making a bunch more noise than my last years rig, but otherwise worked just fine.It was apparent that it was bearing noise .I got a loan of a bottle of "Tri-Flow" , which comes with a fine plastic tube for precision application. The motor is now just as quiet as it should be. The bearing appeared to be sealed , that is, I couldn't actually see the balls , but a few drops apparently made their way into the right place and did their magic. One member of our club is a locksmith , and says that stuff is great on the door locks of your automobile .He has been using it for years. Keith Varley
Online Bob Hudak
Re: oiling your electric motor
« Reply #1 on: February 14, 2012, 06:10:42 PM »
Would a light weight oil with molybdenum suspended in it be good for bearings ? Or what about air tool oil ? I see places selling oil in small bottles specifically for bearings but feel it may be substituted for something of equal value but less expensive.
                                              Bob
350838
Offline chuck_b24
« Reply #2 on: February 15, 2012, 12:42:56 AM »
"MOST" of these bearings I have seen are  shielded ( metal shields)  so oil will work its way through the small shields fairly easy!!
Offline William DeMauro
« Reply #3 on: February 15, 2012, 05:42:01 PM »
If you read through this older thread http://stunthanger.com/smf/index.php?topic=22864.msg219531#msg219531 I give all the links on where to get bearing oil,How to change the bearings an where to get them.
AMA 98010
Online Bob Hudak
« Reply #4 on: February 15, 2012, 08:40:03 PM »
Thanks Will,
 The site you found was very helpful and informative. Gonna lube the bearings with light machine oil after every 30-40 flights.
        Bob
350838
