  • July 12, 2025, 09:25:08 PM
Author Topic: OH SH(*T!!! My first battery fire.  (Read 1655 times)
Offline Ty Marcucci
« on: July 12, 2012, 05:29:33 PM »
Well, it had to happen. This afternoon one of my batteries I noticed was swollen. I put it back on the chair and pierced the cover with an #11.   This to let out the air causing the swelling. Ha. Then it caught fire. Wow you never saw so much dense white smoke. As it was  spitting fire and smoke, I kicked it out onto the driveway. I didn't know I could move that fast.  LL~
« Last Edit: August 15, 2017, 06:15:13 PM by Ty Marcucci »
Ty Marcucci
Offline Darkstar1
Re: OH SH(*T!!! My first battery fire.
« Reply #1 on: July 12, 2012, 05:51:09 PM »
Ty
What kind of battery, and how puffy was it? My Thunderpower 3300s are a bit puffy but I don't remember dropping any and having them catch fire. Do U remember how it fell. If it fell on the balance wires that would explain a lot.
Later,
Evolve or get left behind!
Offline Dave Denison
« Reply #2 on: July 12, 2012, 06:01:53 PM »
The first time is really the one that scares the H*** out of you.  I've been very lucky lately, I had my old Nobler go straight in on asphalt...NO Fire no Leaking, just one badly bent up battery.. $35.00 quickly disposed off.
  Your best tool in the shop is a quality Fire Extinguisher.    Be safe.
Dave.
41041
ama 41041
« Reply #3 on: July 12, 2012, 06:31:31 PM »
It WAS a Thunder Power 45C 3300 MAh 4 cell 14.8 V
Not sure what it landed on, but only one cell burned up The other three are ok, but it split the covering. It now lays outside next to the fence next to the drainage ditch. Maybe one of those pesky nosy into everything Raccoons that lives back there will drag it home.  D>K
I don't know if it's still the recommended method, but when I started flying with LiPo packs you were supposed to chuck them in a bucket of really salty water for 24 hours to discharge before throwing them away.
Or, duct tape them to a post and shoot at them...
Offline Steve Fitton
« Reply #4 on: July 12, 2012, 06:37:33 PM »
Will a regular dry chemical home extingusher even begin to put out a burning metal fire like a lithium battery?
Offline Russell Bond
  • Bandolero
« Reply #5 on: July 12, 2012, 09:30:09 PM »
I just belt them with an axe and watch the fireworks....it's exciting!!!! ;D
I make sure all 4 cells have flared though and then drown them with water after the fire is out. Great fun!
Bandolero
Offline Mike Anderson
« Reply #6 on: July 12, 2012, 10:37:11 PM »
Rechargeable LiPo or LiFe or LiIon cells use NO lithium or other flammable metals.  They use lithium salts, lithium oxides or other lithium compounds.  Some primary (non-rechargeable) lithium cells - like some hearing-aid batteries - do have small amounts of lithium metal.
Mike@   AMA 10086
Central Iowa
« Reply #7 on: July 12, 2012, 11:17:25 PM »
Thanks Mike, for the great explanation on the chemistry.
Dave.
41041
ama 41041
« Reply #8 on: July 12, 2012, 11:19:31 PM »
There you go : A perfect example of a South Australian... possibly living in Adelaide  :-X
  • Bandolero
« Reply #9 on: July 12, 2012, 11:23:48 PM »
PJ, if you're going to "rubbish" people, get your facts straight!!!! S?P
I live in Monarto South.  Hahaha. ;D
Bandolero
« Reply #10 on: July 13, 2012, 02:22:51 AM »
Lets not let facts cloud this..
« Reply #11 on: July 13, 2012, 10:29:37 AM »
Here's what little I know.  The information is probably out there on the web if someone has time to dig.
Fire needs three things to live: heat, oxidant (air), and fuel.  Remove one of these three, and the fire goes out.
Lithium cells don't have metallic lithium (unless they're way overcharged), but they do carry around their own oxidant, so when things go wrong with a cell it'll keep putting out lots of heat and smoke even if you deny it all air.
Dry chemical extinguishers work by smothering a fire, and denying it air...
I suspect that dumping a lot of dry chemical fire extinguisher stuff on and around a burning battery will do you a lot of good -- the battery won't be getting oxygen from the air, which will restrict the amount of energy it can release, and the dry powder will help prevent other things from catching on fire.
I wouldn't empty all or even most of the extinguisher on the battery, though: I'd put some on the battery, and save the rest to protect any exposed flammables that catch on fire because the battery is torching.
Offline Douglas Ames
« Reply #12 on: July 13, 2012, 10:48:26 PM »
At the very least an ABC Fire Ex. or better yet a Class D Fire Ex.!
Don't ever use water!!   http://www.fire-extinguisher101.com/
AMA 656546
