  • July 14, 2025, 03:21:42 AM
Author Topic: Not Control Line related but technology relevant.  (Read 888 times)
Offline John Hammonds
« on: December 23, 2019, 05:53:43 PM »
Hi All,
 After a visit to Scotland recently and a few rather over ambitious cycle rides I've come to the conclusion my Hip is no longer up to the hills so have purchased an electric mountain bike to give me a bit of relief for the steep sections.
Does anyone know the state Lion batteries should be stored during long (Winter) periods of inactivity?
I know Igor used to use A123 cells in the dim and distant past and I believe those are Lion cells?
Just a shot in the dark but I figure with the wealth of knowledge here someone might know.  y1
Thanks in advance
TTFN
John.
BMFA 165249
Offline Bob Hudak
Re: Not Control Line related but technology relevant.
« Reply #1 on: December 23, 2019, 06:19:37 PM »
50%. If, for example your bike uses a 10000mah(or 10ah) battery then you would want to store it at 5000mah. Hope this helps.
Bob
350838
Offline Fred Underwood
« Reply #2 on: December 23, 2019, 07:19:57 PM »
Just a guess, but if you have a charger with appropriate settings  for LiIon, it will have storage function for LiIon.  It should be in the 40 - 60% range, likely 50% as noted, but already selected for you by the manufacturer.
Fred
352575
« Reply #3 on: December 24, 2019, 03:58:50 PM »
Thanks Guys. I figured it was going to be 50% due to their lithium base chemistry.
The charger that came with the bike isn't intelligent at all. (Although it does seem to at least switch off when fully charged). I do have a Hyperion EOS 1210i which does have A123 compatibility as my main charger for flying but I guess that isn't suitable for easy modifying.
At least knowing that 50% is what I should be aiming for helps a lot. I can rig up an inline connector to monitor the voltage.
Thanks again guys, Merry Christmas, Happy Holidays (Or whatever you celebrate).
TTFN
John.
BMFA 165249
