  • July 31, 2025, 02:39:52 AM
Author Topic: Noseover at Launch  (Read 1206 times)
Online Howard Rush
Noseover at Launch
« on: June 12, 2025, 02:33:53 PM »
I had a second incident of my plane pitching down at launch.  Both cases were on grass, Spin 66 ESC, 12” Igor prop, Igor timer.  Both times the motor stopped, the prop was unhurt, and I was able to restart and fly.
Offline Brent Williams
Re: Noseover at Launch
« Reply #1 on: June 12, 2025, 03:06:42 PM »
Check with Jive Industries for a post incident airframe and prop status report, and alert Jive Grounds Maintenance for a thorough flatness and FOD check in the launch area of circle one.
Offline Crist Rigotti
« Reply #2 on: June 12, 2025, 04:34:05 PM »
My plane wants to pitch down on start too.  I have to be careful to have some up elevator at time of spool up.  Then once it starts rolling a few feet neutral elevator.  I've had this happen mostly in Muncie!  I'm thinking that I might be pulling on the lines when spooling up?
Online Howard Rush
« Reply #3 on: June 12, 2025, 07:32:53 PM »
These incidents were: 1) at a very crude field at a contest, and 2) after my stooge stuck, when I was probably distracted and holding down.  I did, however, mow Circle 1 afterward.
The first time I thought I was lucky.  When it happened again I concluded that the Spin 66 and the Igor prop are really good.
Offline Tim Just
« Reply #4 on: June 12, 2025, 10:48:34 PM »
The human stooge on incident 1 was a contributing factor.
Offline Igor Burger
« Reply #5 on: June 13, 2025, 12:26:43 AM »
It must be a lack of training — the more training, the more nose-over accidents, the shorter the grass at launch, and the easier the takeoff   VD~
BTW, thanks, nice to know that we also have good props for lawnmowers.
