  • July 14, 2025, 02:25:44 AM
Author Topic: Nomenclature Proposal  (Read 9268 times)
Online Howard Rush
« on: February 20, 2015, 07:30:17 PM »
We need a better way to differentiate between electric stunt and internal-combustion-engine-powered stunt, which Mr. Buck recently called "conventional".  I propose we adopt the nomenclature used for guitars: "electric" vs. "acoustic".  These names are more applicable to stunt powerplants than they are to guitars anyhow.
Can I get an amen?
Re: Nomenclature Proposal
« Reply #1 on: February 20, 2015, 07:32:49 PM »
What is wrong with saying engine and/or motor?
« Reply #2 on: February 20, 2015, 07:47:57 PM »
Because engine and/or motor are both commonly used to describe electric motors and/or internal combustion engines.
I like "'lectric" and "slime", myself.
I believe that in some circles, tail dragger landing gear is still called "conventional".
Online Howard Rush
« Reply #3 on: February 20, 2015, 07:50:26 PM »
It is.  We looked into conventional landing gear for airliners.  Merely using that name was inadequate to give the proposal credibility.
Offline Shawn Lenci
« Reply #4 on: February 20, 2015, 08:35:46 PM »
Howard...I'll give you an Amen brother. ;)  The only problem I see when the different powerplans are being capaired to geetars is that the electrics are usually noisey and the acoustics are usually the quite ones.  Just the opposite of a stunt power plant.
Shawn
AMA 97686
Offline John Sunderland
« Reply #5 on: February 21, 2015, 12:37:34 AM »
I am behind the times with a learning curve in front of me. The motors and batteries I saw at various times a few years ago are now something else with a new nomenclature.. mw~ Dennis, Kenny and Bobby were guiding me a bit. Pete Bergstrom sent me a power 15 or something a few years ago with a timer and battery...sounded weak for a Chevelle. Lost those the in storage wars and move to the southwest in 2011. Eric's stuff sounds canned weak and limited. IS there a pattern for electric power in CLPA E power plants and batteries....seems everyone is searching for the grail....again.
Gimme two old revamped PA 61s and a "slightly smaller bird" on RE muffler, 26 thou deck, a #6 fuel post venturi and I think I could make decent ponies for the job.. at 6 oz. fuel.
« Reply #6 on: February 21, 2015, 11:59:34 AM »
Look at what Bobby Hunt is using.
Offline NED-088
    • Heartstrings
« Reply #7 on: February 21, 2015, 03:45:01 PM »
I've been flying 'acoustic' off an on since 1985  ;D
However, only the newest -still to be completed- has electric up front.....
Online Howard Rush
« Reply #8 on: February 21, 2015, 06:50:44 PM »
Now for a pickup on the banjo.
Offline NED-088
    • Heartstrings
« Reply #9 on: February 22, 2015, 03:43:29 AM »
A pickwhat?  :o  No way Jose!  n1  ;)
I've been struggling with them noisy Coustics all my life.  n~
Since I have found out how to work the 'Large diaphragm condenser microphone', all I'd do from now will be A-Coustics.  #^
Offline Phil Krankowski
« Reply #10 on: February 22, 2015, 06:05:33 AM »
...but ENGINE implies it runs on HEAT while MOTOR implies that it is changing energy states, such as electricity or compressed air (co2, whatever) to rotation.
Offline Allan Perret
  • Proverbs
« Reply #11 on: February 22, 2015, 10:39:51 AM »
I like it short and to the point, as in "E" and "IC". ~>
Allan Perret
AMA 302406
Slidell, Louisiana
Offline John Rist
« Reply #12 on: February 22, 2015, 02:04:53 PM »
Me too!   #^
« Reply #13 on: February 22, 2015, 02:38:24 PM »
Howard is fine
Howard is cheeky
Nomenclature aside
His trolling is sneaky
« Reply #14 on: February 22, 2015, 04:39:41 PM »
 Perfect, and each are terms that are already recognized and in common use. y1
 If everyone would just use "real" engines we wouldn't have this problem. :##
« Reply #15 on: February 22, 2015, 08:07:50 PM »
No, No, NO!  E=IR!  How you gonna build yer 'lectrickery if you don' know the basics....
Offline Mike Ferguson
« Reply #16 on: February 23, 2015, 12:12:06 PM »
Can I get an amen?
As long as that means I get to throw an Ibanez Tube Screamer in front of my electric set-up, I'm okay with that.  ;D
Offline Target
  • C/L Addict
« Reply #17 on: April 21, 2015, 09:30:14 PM »
While clearly in the minority, I agree 100% with this statement.....
Motors for CL have wires with electricity going to them, Engines for CL have liquid fuel for combustion going to them.
That is why "Motorman" confuses me! He should either fly all electric, or change his name to "Engineman", LOL!  n~
Chris
AMA 5956
