  • July 14, 2025, 08:18:57 PM
Author Topic: Nobler with A123 setup ?  (Read 883 times)
Offline Vincent Corwell
« on: June 18, 2009, 06:09:22 AM »
What is an ideal setup for a Nobler
I want to use A123 battery in single pack
I can get Hyperion or Axi motors locally
then the ESC and timer are no problem
other motors or batteries are difficult to
get in Europe, ( without incurring heavy charges )
Fly stunt love our forum
Vincent H^^ H^^ H^^
Alan Hahn
Re: Nobler with A123 setup ?
« Reply #1 on: June 18, 2009, 08:14:15 AM »
Vincent,
First off make a mockup of the A123 pack to see where you can put it in the plane.
I don't know much anything about the Hyperion motors, but if I was going with an AXI in a Nobler, I would start with the 2814 or 2820. I am not sure what kV you will need with a 5s A123 setup (I would guess somewhere in the 900-1000 rpm/Volt range.  However I think Igor Burger would probably have a better idea of where to start. He may know more about the Hyperion too.
I just recalled that on my original Nobler thread, there was a post from a German modeler on a electrified Nobler. That was a really sweet setup! Here is a link to it. The relevant reply is #34
http://stunthanger.com/smf/index.php?topic=6975.0
Offline John Witt
« Reply #2 on: June 18, 2009, 05:33:45 PM »
What are the dimensions of a single cell? I found some web site info, but if you're building up a pack from individual cells, the single cell size is a good thing to know.
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline Igor Burger
« Reply #3 on: June 18, 2009, 10:45:50 PM »
I do not know Hyperion too, but since I know that combo 6s A123 works well with AXI 2826/12 for 5 minutes fligth time, I would say that 5S A123 will work well with AXI 2826/10. Both with APCE 12x6. it will have 20% less power, so you must use slower RPM and it means shorter lines. I fly 20m so if I calculate it witout knowing the model, then 20% power less means rpm 7% lower, so also line length must be 7% shorter to have the same lap time, so I would say lines approximately 18-19m.
One cell weights 70g so whole pack is at 350g plus motor 190g plus esc 50g ~= 600g = 22oz
cells dimmensions are directly in cell name: ARN 26650 ... means diameter is 26mm and length is 650mm :-)
Offline John Hammonds
« Reply #4 on: June 19, 2009, 11:12:45 AM »
Quote from: Igor Burger
Does that include the cardboard wrapper? (I haven't checked, but it would obviously make a difference when checking it will all fit).
TTFN
John.
BMFA 165249
