  • June 16, 2025, 04:46:12 PM
Author Topic: Line pull Excel spreadsheet  (Read 782 times)
Offline John Witt
« on: June 03, 2009, 06:22:21 PM »
I've written a small Excel sheet to calculate line pull at different heights above ground. I just found that I can't post it, so e-mail me if you'd like a copy.
I'd be interested to get your feedback and additions or corrections.
The calculated pull feels about right for my Panther.
« Last Edit: June 11, 2009, 03:43:33 PM by John Witt »
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline John Cralley
Re: Line pull
« Reply #1 on: June 03, 2009, 06:36:35 PM »
Humm, have you tried copy and paste into your message or do you have it set up for feeding in parameters and getting line pull calculated? If the latter, you may well be blocked from posting here.
John Cralley
AMA 52183
Central Illinois
Re: Line pull
« Reply #2 on: June 03, 2009, 07:00:10 PM »
I would like a gander at it if you please? thanks,email in profile
Alan Hahn
Re: Line pull
« Reply #3 on: June 03, 2009, 07:35:41 PM »
I'd be interested to get you feedback and additions or corrections.
Out of curiosity, do you assume the same laptime, or same airspeed??
Offline John Witt
Re: Line pull
« Reply #4 on: June 03, 2009, 07:41:21 PM »
You need to run it in Excel, so cut and paste won't work, though I could post a screenshot, I suppose.
I assume a constant air speed, calculated from the laptime.  User enters lap time, circle radius (line length + arm + distance to A/C center) and airplane weight.
JW
John Witt
AMA 19892
Edmonds, WA
