  • July 17, 2025, 12:04:16 AM
Author Topic: New Soldering iron offerings  (Read 1703 times)
Offline Dane Martin
  • heli pilot BHOR
« on: August 18, 2020, 10:17:15 PM »
I got a few new soldering irons to try. I did a short little unboxing / trial video on the DC powered Sequre D60-B. It's got an xt60 connector so you can plug in your lipo pack and do some field repairs,  or plug it into a power source. There's also AC powered versions if you don't want to fiddle with the DC adapters.  The one in the video is only $29. Products can be found here (fastest shipping, great company from California)  https://pyrodrone.com/pages/search-results-page?q=Sequre
Sequre put it on their blogspot.
https://sequremall.com/blogs/video/sequre-d60-b-trial-run
My YouTube video is here.
Online John Rist
Re: New Soldering iron offerings
« Reply #1 on: August 19, 2020, 09:43:10 AM »
That's cool.   A true temperature controlled soldering iron for a good price.  Of course the tips are expensive.
Offline dennis lipsett
« Reply #2 on: August 19, 2020, 02:25:46 PM »
There are lots of battery powered tools that are small and fit in your tool box easily.
I also have a battery powered soldering iron and a nice battery powered glue gun. All powered by a 3 cell Li-po battery. The glue gun is about 6 dollars and the soldering  iron is about 9 dollars. It pays to have the tools to fix anything when your at the field.
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: August 19, 2020, 03:44:44 PM »
Dennis, that Li-po powered hot glue gun is amazing. I love mine. And you're right, we always have the batteries around anyway!
Here's the more powerful iron, if anyone is following along. I'll try and get a couple more battery powered ones for comparison videos. This is a bad mama jamma. 500c temp!
110w iron for about $34
Offline john vlna
« Reply #4 on: August 23, 2020, 08:41:12 PM »
NICE TIP, NO PUN INTENDED, ANY IDEA ON HOW MUCH CURRENT IT DRAWS?
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: August 24, 2020, 08:42:19 AM »
From my understanding, it's approx 1a from the receptacle. I didn't do an actual current test,  and that 1a figure would be at full temp, probably while heating from cold. But I still haven't tried 500 degrees Celsius with it. I don't do anything that large
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #6 on: August 26, 2020, 07:14:55 AM »
   Thanks for the information Dane and Dennis. I'm going to check them out.
         Doug
Offline Jim Damerell
« Reply #7 on: August 26, 2020, 08:21:57 PM »
What is everyone using on 12 gauge wire and Deans Plugs?
Offline William DeMauro
« Reply #8 on: August 27, 2020, 07:28:57 AM »
I use a Weller 8200 but its the old style. I don't like the newer ones.
AMA 98010
Offline Dane Martin
  • heli pilot BHOR
« Reply #9 on: August 27, 2020, 03:48:50 PM »
I guess keeping along with my own thread here.... here's the least expensive option from Sequre. I like it. It's super cheap and exceptionally easy to use, while still being thermostatically controlled. 3 temp settings, 30 seconds or less heat up
