  • June 23, 2025, 03:46:36 AM
Author Topic: New small electric twin build thread  (Read 18813 times)
Bob Hunt
« on: December 28, 2020, 09:03:19 AM »
A few years ago I designed a twin electric Stunt model that has a 530 square inch wing, a built-up fuselage, and profile nacelles. It was much the same in aesthetics as my big test bed twin, but with no retracts. It was reasoned that a small electric twin might be attractive to those who might wish to try an electric twin Stunt model, but with much reduced building time and much reduced cost. As for overall size, think of a Nobler with a longer tail moment.
As with the original big test bed twin, the smaller ship (name will either be "Double Take" or "Two Small") features a "Lost-Sheeting" wing. That's the name I gave to my adaptation of the Combat world's treatment of foam cores. They cover them with a low-temp plastic material, while I chose to apply .2 carbon mat using water thinned Titebond II glue. In either case the strength of the wing mainly comes from two imbedded 1/8 x 3/8-inch basswood spars - one on top and one on the bottom - that run full span and have a couple of 1/8-inch balsa shear webs installed between them. The basswood spars are glued into a slot in the top and bottom of the foam panels and are also glued to the shear webs, preventing "racking." This yields an incredibly strong wing at very low cost and very little building/assembly time.
The new small twin will be powered by E-Flite Park 450 motors (with the option to go to Park 480 motors if needed).
My question is: Would the readers/contributors here be interested in a photo essay of the build, and if so would they also be interested in plans and foam parts for this model?
Thanks - Bob
PS: Attached are a couple of photos of the original big twin test bed for reference as to what the new small twin will look like, and also a couple of photos of the Lost-Sheeting wing construction on one of the Joe Nall Cadets. - Bob
« Last Edit: January 14, 2021, 05:24:45 AM by Bob Hunt »
Offline Craig Beswick
Re: New small electric twin question
« Reply #1 on: December 28, 2020, 03:44:07 PM »
Yes.
Craig
AUS 87123
"The Ninja"
Online Brent Williams
« Reply #2 on: December 28, 2020, 05:08:49 PM »
Oh yeah Bob!
(But you already knew I would be very interested!)
Offline Dennis Nunes
« Reply #3 on: December 28, 2020, 06:01:41 PM »
Yes Bob, I would be very interested! As our good friend Jim Aron (aka Uncle Jimby) would say, "Twins are cool"!  ;D ;D ;D
Dennis
« Reply #4 on: December 29, 2020, 01:51:05 PM »
Bob,
What is the motor/ESC/Timer/Battery set up for this ship? For the ESC how is it sized for amps?
Best,   DennisT
« Reply #5 on: December 30, 2020, 05:07:33 PM »
OK Bob. You now get a new name. You are, hence forth, known as the King of Cool. I like it.
Offline Dane Martin
  • heli pilot BHOR
« Reply #6 on: December 30, 2020, 06:37:52 PM »
You've got me on the edge of my seat now
Offline MikeyPratt
« Reply #7 on: December 30, 2020, 06:41:25 PM »
Bubba,
I like it a lot Ol Buddy.  Send me the drawings and I’ll CAD them out for you.  After thinking about this, I like the name “Bubba’s Double Trouble” seems to fit perfectly.
Mikey
« Reply #8 on: December 30, 2020, 07:25:37 PM »
Bob,
So are you using two Castle Talon 25 ESCs (one for each motor) and a single 4S 2,800 mAh battery with Y harness and single timer with a Y harness? Just trying to understand how these twins are set up.
Best,   DennisT
Offline John Rist
« Reply #9 on: December 30, 2020, 09:40:22 PM »
Bob,
Best,   DennisT
Can't drive two motors with a KR timer. So you need ESCs that have RPM control and a Hubin timer.   In an earlier post it was mentioned that some one makes a twin motor timer.  Is that true?  How does it work?
« Reply #10 on: December 31, 2020, 07:23:08 AM »
Bob,
I think this is a very interesting thread. It would be great if you could go through the process for the Twins of initially selecting motors, props, ESC size, Timer options (with and without retracts) and battery size so it could be applied to different size ships. Would also be good to layout the wiring arrangements (like a one line diagram) and component hook-up arrangements (like the "Y" harnesses needed). Then the build pictures for the actual ship which you do a great job on always.
Best,   DennisT
« Reply #11 on: December 31, 2020, 11:03:47 AM »
Even though I will probably never build one,  the old DOC will keeping watching for the results of a true craftsman. H^^
Offline Dane Martin
  • heli pilot BHOR
« Reply #12 on: December 31, 2020, 11:32:24 AM »
I think I could see myself flying something like this. The more I look, and read through this... the more excited I get to see it develop. I'm a big fan of a "smaller" plane. Not that it's small, but I don't fly a lot of 60 sized ships. I stay around the sig twister size.
Offline Steve Berry
« Reply #13 on: December 31, 2020, 03:13:27 PM »
I am very interested in this as it will relate almost directly to the OV-10 Bronco I've been designing (based off the Pathfinder Twin - big thank you to John Miller for helping on initial CAD and plan review, and to Keith Trostle for his help on design considerations).
Sent from my Lenovo TB-X505F using Tapatalk
Offline Rob Smith
« Reply #14 on: December 31, 2020, 05:51:42 PM »
I always enjoy your builds!
Rob
Offline James Mills
« Reply #15 on: January 01, 2021, 07:11:08 PM »
Bob,
Yes and yes.
James
AMA 491167
Offline Shorts,David
« Reply #16 on: January 02, 2021, 12:01:27 AM »
I ran three motors with my KR. Worked fine.
« Reply #17 on: January 02, 2021, 06:46:09 AM »
Dave,
Would be good if you could show a wiring one-line and some photos of the hook-ups.
Best,    DennisT
« Reply #18 on: January 02, 2021, 06:50:07 AM »
Bob,
Can you post the layout sketch of the twin so we can understand the dimensions and how you arrived at the location for the nacelle. What wing airfoil did you select? Why?
Best,    DennisT
Offline Dwayne Donnelly
« Reply #19 on: January 02, 2021, 10:55:35 AM »
Hi Dennis:
Well, I don't actually have a "layout sketch" of the plane; I just drew the plans... The nacelle location on the wing was determined by the maximum diameter prop that might be used. In this case it was a 8-inch prop. I left enough room between the nacelle center line and the fuselage side to be able to use a 9-inch prop if that becomes possible. In any case there is enough clearance between the tip of the prop and the fuse side. I know that doesn't sound too technical, but I've always worked more out of "feeling" than out of science. Hey, it's worked pretty well for me so far.
This build thread is about showing how I build a Lost-Sheeting twin-motor model, and I won't go into too much design theory. I'm using proven airfoils and "numbers" that I know will produce a good flying model (at least I hope so...). When the build is done and the model has been flown, then I will release plans for the ship and also offer cores and some other parts for it.
I'll post more photos and information later today.
Happy New Year - Bob
Hi Bob we chatted on the phone a bit a few months ago about my Legacy build I was going to use a power 25 but you suggested a 15 would be enough which I did switch to, now I see you are designing a Nobler size twin  with little 8 inch props, I have to say this is quite fascinating, I'm looking forward to the rest and if you offer plans and cores put me down for a set.  ;D
Rick_Huff
« Reply #20 on: January 03, 2021, 08:34:57 AM »
Of course, Bob.  Glad you like the syrup.
I'm looking forward to the rest of this thread,
Rick
Offline Dave Heinzman
« Reply #21 on: January 04, 2021, 06:59:14 AM »
  Hi Bob, thanks for sharing you new plane construction with us! I'll be watching along the way. I'm building a profile Pathfinder electric twin right now.
Offline Crist Rigotti
« Reply #22 on: January 05, 2021, 03:25:11 PM »
You are a master Bob.  Everybody, pay attention on how Bob does things.  It will serve you well!
Offline PerttiMe
« Reply #23 on: January 06, 2021, 11:51:45 PM »
I have no particular interest in twins --- but this is going tobe good.
Offline Frank Imbriaco
« Reply #24 on: January 07, 2021, 09:47:10 AM »
 IMO, what Bob is trying to do here really should motivate guys who wish to experience a twin , but desire minimal work and cost.
I built a full fuse twin," TURNING POINT", that Bob designed a few years back.
It's full house ; retracts and all.
 A treat to fly.
 In the hands of someone like Bob, it's a weapon !
Offline Dane Martin
  • heli pilot BHOR
« Reply #25 on: January 07, 2021, 10:43:58 AM »
Dam. I'm jealous of yous guys that paint and make those so beautiful
Offline Paul Walker
« Reply #26 on: January 07, 2021, 12:05:32 PM »
wow Bob. Cool!
Two Park 480's???
I flew the first B-17 with 4 Park 480's at 120 ounces, and power was NOT the issue!
I suspect you will have "ample" power!
Good luck.
« Reply #27 on: January 07, 2021, 12:58:28 PM »
 A treat to fly.
Saweet!!  y1 #^ %^@ ;D
« Reply #28 on: January 07, 2021, 12:59:53 PM »
Bob, the old DOC gets a lot of info from your construction posts and I've borrowed a lot of them on different planes.  Thanks for all you do here. H^^
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #29 on: January 07, 2021, 02:19:58 PM »
            Bob, that is a great idea that you have made a reality! Yea, and its cool too!
       Doug
« Reply #30 on: January 13, 2021, 07:46:11 AM »
Sweeeet!
Offline badbill
Re: New small electric twin build thread
« Reply #31 on: January 14, 2021, 12:59:52 PM »
Awesome build, everything is so easy to understand. Question- Why not have the slot for the vertical bellcrank support in the middle of the spar slot, then just have a hole drilled in the spar that fits over it?? That way it's supported by the spar? Or is this something I'll understand in the next step  y1
Bill Davenport
AMA 28141
« Reply #32 on: January 14, 2021, 11:03:55 PM »
Nice!
« Reply #33 on: January 18, 2021, 08:27:32 AM »
Bob's build logs are the best!  He is very detailed and his pics are perfect.
« Reply #34 on: January 19, 2021, 09:08:41 AM »
That is so cool. I like the process.
Offline ericrule
« Reply #35 on: January 26, 2021, 11:40:58 AM »
Hi Bob;
Saw in a pervious reply that someone said the KR does not have a retract feature. That is incorrect. KR has a retract version. It works as follows: 15 seconds after the motor starts the retract come up (this time can be adjusted) when the motor "blips" (10 seconds before the flight ends) the retracts come down.
When Dave Sabon built his electric twin I sent him one of the KR's which he used with good success. Dave also used two motors with ESC's plus a single battery.
Offline Igor Burger
« Reply #36 on: February 01, 2021, 02:54:22 PM »
I'm pretty sure the Igor timer system has that feature as well, but I'm not certain of that. Someone enlighten me...
I see I again missed great thread here, sorry Bob I did not see it before. I like that building, I see I must show it to our kids, I am sure they will make milion of different models this way :- ))))
But to your question -
Yes and no  ;D. My timer does not do anything only controlls motor. I always concentrate to make the function fully implemented tested and well working and not to give other side fancy functions. So no, my standard timer does not have any buttons, landing gears lights and similar things. However my timers are modular, so in case that model needs another function there is no problem to add any other specialized gadget. In this case I have specialized timer for landing gears synchronized with main timer. Of course it is programmable by Jetibox and beside its normal function it has also input for RPM sensor with adjustable rpm. It can be any standard R/C device, so it will work with sensor for standard motor, or also magnet sensor for IC engines etc. That means it can be used also without my timer with accelerometer. Optionally it can be also connected to speed sensor or centrifugal sensor, but that is not good solution because it needs very good ajusting (so that does not extend when model slows in fugures, but act safely when it is really needed, does not react to whipping etc.) and I think it is not good idea to test landing gears with risk of landing to belly. Setting RPM is much simpler, exact and repeatable even on ground. Timer has many settings, beside RPM for emergency gear down with adjustable servo angle, it has slow motion retracting to look better (but emergency gear down function is quick). Unfortunately speed setting has no effect with electronic LGs. And of course it has "go home" button/jumper.
It also works with normal servos and standard hardware with lock arm, also servos without lock arm (so that it make hardware much simpler) and it is also tested with servo-less electronic landing gears which has little bit tricky controlls. Chris can tell stories about it :- ))
Here is picture how to connect it with my normal timer.
Offline Maksim Dubovitsky
« Reply #37 on: February 07, 2021, 02:59:19 AM »
Hi Bob, very, very interesting project! What are the dimensions of the model - wing span, wing area? What is the expected takeoff weight ?
« Reply #38 on: February 07, 2021, 11:25:02 AM »
Welcome aboard Maksim.  y1 #^
« Reply #39 on: February 08, 2021, 11:29:04 AM »
Hey Bob, I'm seriously considering this at around 600 sq in. range.
« Reply #40 on: February 08, 2021, 11:34:53 AM »
Hey Bob, where are you getting you're carbon veil?
« Reply #41 on: February 08, 2021, 04:04:15 PM »
Thanks, Bob.
« Reply #42 on: February 09, 2021, 09:13:46 AM »
projected weight with battery is in the 45 to 47 ounce range.
Wow, It seems that this will not be easy to do, given that the moto setup will weigh about 20 ounces, an empty plane should weigh no more than 26 Oz. What density foam are you using? And how much does a wing weigh without flaps now? And another question: will the model be painted?
« Reply #43 on: February 10, 2021, 08:41:08 AM »
Great job, Bob!
« Reply #44 on: May 23, 2021, 01:20:13 PM »
How's it going Bob, are you still working on this build?
Offline Tom Luciano
« Reply #45 on: May 23, 2021, 06:08:49 PM »
Wow! Thats BA!
AMA 13001
« Reply #46 on: May 23, 2021, 07:53:42 PM »
« Reply #47 on: May 24, 2021, 03:07:10 PM »
Hi Dwayne:
It will be finished after the NAts. I've been working on my "real" twin in hopes of having it ready for the Nats.
Later - Bob
Thanks for the reply Bob, looking forward to it, plane looks very nice good luck at the Nats  y1
Offline Matt Colan
« Reply #48 on: May 24, 2021, 06:37:53 PM »
Looks awesome Bob!! Can’t wait to see it!!
Offline Page Peterson
« Reply #49 on: September 15, 2021, 10:19:48 AM »
Bob, thanks for the directions and help.
Here is how my lost sheeting attempt came out. I am going to build one more of an Oosa-Amma. I wanted the two to look similar in the air and be able to reuse some of the templates. It will go a lot faster the second time. I will also keep in mind that this is not a long term model and be a little less concerned about some things being just right. Other than paint, I am not sure this one would have taken me any longer to do as a standard plane with sheeted wings and molded fuse shells. The wing can definitely be done quickly and it turns out light.
The foam fuse shells were a bit of a pain. On the second attempt, I made a template similar to a mold buck. I stuck the foam block in with double sided tape and then sanded to template shape. That turned out well. I used a hot wire to cut out the hollow in block and then used slices of the cut out for formers. Covered the fuse foam the same way I did the wings with veil and Titebond.
Double coats of veil work pretty well for numbers and the cockpit.
Page
