  • June 29, 2025, 02:24:21 AM
Author Topic: New Plane ECL ( take apart)  (Read 1112 times)
Offline Larry Wong
« on: January 18, 2011, 07:00:14 PM »
New ECL if weather stays (AMPURA )
Larry
Offline John Cralley
Re: New Plane ECL ( take apart)
« Reply #1 on: January 18, 2011, 07:19:32 PM »
Larry
Looks nice!! What are the specs you intend to use (motor/battery etc.).
John Cralley
AMA 52183
Central Illinois
« Reply #2 on: January 18, 2011, 07:25:03 PM »
nice Larry!!!
I really like how you got the camo to match your driveway HA
Offline Larry Wong
« Reply #3 on: January 18, 2011, 07:34:46 PM »
Ok John : Here what I have.   64"WS 42"long   Plettenberg 20-12, Schulze ESC 18.46K F2B, Hubin Fm-9 Timer. Battery will have to see , I think PTG and Erick are using 4c 265o mAh ! n~
Larry
« Reply #4 on: January 19, 2011, 07:31:49 AM »
Larry,
Great looking ship. What prop do you plan to use (APCE 13x4.5P)? Also is the battery a 5S1P or 4S1P?
I like the top loader will the hatch be held on with magnetize?
Best,    DennisT
Offline Larry Wong
« Reply #5 on: January 19, 2011, 07:46:35 AM »
Dennis: Yes a top loader with a Bob Violet spring latch, the prop. will start with APC 13-4.5 EP  and 4-cell / 5-cell  might even try a 12-8 EP lower RPM . I also have Platt. 30-12 & 25-12 to try.
Larry
« Reply #6 on: January 19, 2011, 04:03:25 PM »
Looks REALLy good Larry - NICE job!
Offline Mike Scholtes
« Reply #7 on: January 19, 2011, 09:57:59 PM »
I have seen Ampura in person and can testify to the excellent workmanship and innovative design. Larry had this model pretty far along before PTG unveiled Elroy, and the two share some features in common, evidently by coincidence. Cooling tunnels and ducting around the spinner are similar, with top loading hatch with ESC downstairs. I think we are seeing the future of CLPA in models like this, and of course Dennis' unique model (name escapes me, sorry Dennis). With luck and good painting weather Larry should have this in the air by spring contest time.
« Reply #8 on: January 19, 2011, 11:59:52 PM »
3 Questions :
1: What are the carbon undercarts your Using. They look like the ones on the bear
2: How are you doing the fillets for the TA wing.
3: How do you find the Tom morris TA hardware - I hear good things.
Offline Larry Wong
« Reply #9 on: January 20, 2011, 06:21:42 AM »
P J : The landing gear is from Randy Smith
       The fillets are made out of Balsa wood like a 1/2" larger rib mounted to fuselage and shaped.
       The Tom Morris T/A system easy to use. y1
Larry
