  • July 12, 2025, 11:17:06 PM
Author Topic: New KR Governor Timer ver.2 with active governor gain  (Read 6976 times)
Offline Keith Renecle
« on: March 02, 2012, 06:02:36 AM »
The new version of the KR Governor timer is now ready and available. As some of you noticed, I have been working on a system with active regulation without using any external devices like gyros, accelerometers etc. I will be the first to admit that this system has its limitations like most of our power systems in C/L stunt, but at the same time, in my humble opinion, it is another big step forward in electric stunt. It works very much like the tuned pipe systems on glow engines. I added a user variable governor gain system that only adds extra gain when the system is loaded. Adding overall gain to a governor feedback loop usually causes oscillation and hunting. You could refer to my idea as differential gain as well.
After many months of testing with other pilots, everyone so far agrees that it really works well, especially for such a simple system. I’m sure that you will get comments from some of the present users. A lot of stunt fliers don’t take easily to electric, or 4-strokes either, because of the faster lap times, even though the maneuvering speed slows down. My system now kicks in extra rpm in the hard corners and climbs, so the lap times can be slowed down to those used by most glow engine setups. I have made this gain setting adjustable by means of the programming card. The standard gain factor is 1 and you can now set this to a maximum of 7. After this, it gets really wild, so I decided that the limit of 7 is far enough! From the feedback I’m getting, users are setting the gain from 4 to 6, depending on their individual preferences and also what motor they are using. Most are lowering the revs by around 300 to 400 rpm, but are using very much the same amount of battery power. I guess that this shows that the same amount of power is coming from the extra kick when it comes in. A quick comparison is done by leaving the gain set at 1 and the lowering the rpm by the same amount. You will find a lower battery usage, but also a distinct lack of power with slowing down plenty through the pattern, because the motor is now out of it's happy band!
The hardware upgrade was also necessary because of manufacturing hassles with version 1. The programming card used the only input left on the processor chip and needed 3 functions. I therefore used a resistor voltage divider to do this. The surface mounted resistors plus LED made the board difficult and slow to produce. Because the product has sold so well (thanks to everyone!), I had to gear up for a full machine built pc board. This is quite expensive with the laser cut stencil and all, but in the long run it’s a much better deal. I used a 14-pin processor this time and put the LED on the timer board. The programming card now uses 3 logic functions into individual pins, so the board is much simpler, and can be produced a lot faster. I was making the last version at a total loss in terms of time, so rather than putting the price up for everything, I did a complete re-design.
The price increase from $30.00 to $37.95 will cover the new manufacturing costs plus the software development. The programming card is still only $12.00 and remember that it can be used with as many timers as you need it for. This is a different system to the version 1 system for programming so the old card cannot be used with the version 2 Governor timer. I did not want to force my previous customers to get rid of their older stuff, because I did advertise the fact (like I did above) that you can buy more timers and use just one programming card. What I have done therefore is to make a new version called version 1.2 with the new pc board, but that works on the older programming cards if customers do not wish to upgrade. These will be available on special order from RSM Distribution or from myself in other countries outside North or South America. The version 1 timers can also be updated to have the new variable governor gain program for a nominal fee, by sending them to RSM or to me.
The performance of this very simple system with low cost esc’s has now been improved greatly, and I’m sure that anyone who tries it will be just as impressed as those who have helped with the test program. Once again, I would like to thank Andy Borgogna for his patience and continual help with this project.
One more thing, just remember that this system can also be used on 1/2A models. I know that many do not see a reason to use a governor system on the small stuff, but remember that this is the only system at present that shuts down the motor when the prop gets jammed. Even with prop savers, it’s much better to stop the motor and it sure saves burning out motors and esc’s. Besides, it is nicer to fly with a governor system even on the tiny stuff.
Here is the link to the complete story on my website: http://www.keithrenecle.co.za/Electric%20CL.htm
Keith Renecle
Keith R
Offline Dean Pappas
Re: New KR Governor Timer ver.2 with active governor gain
« Reply #1 on: March 02, 2012, 12:07:24 PM »
Bravo, Keith.
     Dean
Dean Pappas
« Reply #2 on: March 02, 2012, 12:22:26 PM »
Bravo indeed!
I have some KR timers and am chomping at the bit waiting to fly them.  I am intrigued with the adjustable gain concept - in effect, being able to adjust just how strong the 4-2-4 break is.  Note that this cannot be done with the Castle...
Offline John Tate
« Reply #3 on: March 02, 2012, 02:36:55 PM »
Keith,
I have enjoyed using the first version of the KR Governor Timer (works very well). The new Ver.2 sounds even more interesting.
John Tate
Offline Andrew Borgogna
  • Andy
« Reply #4 on: March 02, 2012, 02:57:43 PM »
It has been fun working with you on this project and I know that this product will do well.  I have tested the variable gain concept on everything from 1/2a to .46 size planes and it works.  I hope other modelers will give this system a try, it is a real alternative to what you have been using.  This governor was not designed for helicopters, Keith designed it for our use.  For the first time we are no longer leverageing off something designed another application, the new KR timer and firmware code was designed with control line aerobatics as the primary application.
Andy
Andrew B. Borgogna
Offline linheart smith
« Reply #5 on: March 03, 2012, 08:41:49 AM »
I can see myself flying a Nobler at 5.8 laps with this timer kicking in on those verticals just like the old days with my Fox 35.
Linheart
linheart
  • Andy
« Reply #6 on: March 03, 2012, 11:18:57 AM »
Linhart
The only difference is there is no noticeable sound change from the motor.  It's kind of weird, at first I wasn't sure it was working except the plane would not fly the pattern at the reference RPM unless the gain was turned up.  The power just comes on seamlessly, no sudden increase in noise and no sudden burst of speed it just keeps pulling.  You are turning 5.5 second laps, you pull the nose up and it just keeps going.   y1
Andy
Andrew B. Borgogna
Offline Will Moore
« Reply #7 on: March 03, 2012, 06:01:32 PM »
Andrew;
What simple ESC"s  did your testers use.  Is there one that you prefer over others?
Can you name them for us ?    Not good with ESC's with gov , right ?
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
 AMA # 209
« Reply #8 on: March 03, 2012, 10:56:06 PM »
Hi Will,
You can use the timer with esc's that have a governor as long as you disable the internal governor. This is a good way to check out my governor. This is obviously a bit of an overkill if you want a new system. I've used most of the low cost esc's like the Hobbywings, Turnigy's etc. Some have a rather coarse throttle resolution and this makes some revs hard to latch on to. This is mostly with the real "El-Cheapo" types. The one with the smoothest throttle resolution that I've tested is the ZTW. This has no jumps from low to high throttle. I made a tester with a PIC chip that steps the throttle slowly from zero to full power in 10 rpm steps, and this shows up any jumps in the throttle range. If you try this with the throttle stick on a R/C TX, you usually miss the glitches. I'm using a 20 MHz clock on my timer as opposed to the 4 MHz clock on some of the other timers, so my governor can adjust down to 10 rpm. When you program the rpm however, 10 rpm is not practical, so the steps on my programming card are around 50 rpm. Most tachs can also only show steps of 100 rpm except for the Globee, but then most people block off the last digit. Engines can't really be set any finer than 100 rpm.........if you're lucky!!
The 55 amp Scorpion that I have is also very smooth but the throttle response is very damped and my governor hunts a bit with it. It also has its own governor that works very well for heli's but not for C/L. The price is in between the Hobbywings, ZTW's etc. and the high-end governors like the CC.
I'm flying my 64 oz. Electron with a 55 amp ZTW series A and it's very compact and runs cool on a 4-cell 3300 lipo. I put Eric Rule of RSM onto ZTW and he stocks them if you have difficulty find a stockist for ZTW.
Keith R
Keith R
Offline Will Moore
« Reply #9 on: March 04, 2012, 08:12:37 AM »
Keith,
Thank you for your info.  If we use your system on a high end ESC, say Castles Creation or Jeti, ( can't use Shultze F2B  because I don't think you can
disable the Gov. mode)  and disable their Gov. mode, do you think your system performs even better than theirs because you can actually adjust the Gov
gain  with yours?   Because if you can, I think it's a huge leap forward in tuning in Gov. to the airframe's needs and pilot's ability and comfort zone.
One more question, tell us more about the on / off switch.   When off, does that separate the battery from the system ?  What does it turn off.
Keith, you are to be commended for this great product. And It's inexpensive!!   Your research and development , along with the other pioneers
who have done the same in electric, have helped all of us to embrace this new technology and enhance the enjoyment and level of the sport.
Please keep your ideas flowing !  Thanks again.
Will Moore
« Last Edit: March 04, 2012, 01:13:47 PM by Will Moore »
 AMA # 209
« Reply #10 on: March 04, 2012, 10:02:52 AM »
Hi Will,
Thanks so much for the nice words. I must tell you that some years ago I was not at all interested in electric power. It was your articles in Stunt News that got me hooked. All that work you did after Mike Palko was really a blessing and certainly helped me to understand what motors to try and how it all went together. So a big thank you for writing such good articles!
My slide switch only puts the throttle pulse back to 1.0 ms or low throttle to stop everything. The program stays running until you remove the power. The reason for a slide switch and not a simple push button is to allow the user to calibrate the esc throttle range if necessary without having to resort to using an R/C system. If you put the switch on and then connect the battery, my timer puts out full throttle or 2.0 ms. Switching it off again will output low throttle or 1.0 ms. If you switch it off during the motor run it shuts down the motor. Once the flight is over, the the program stays at 1.0 ms, and the only way to restart the flight is to remove the battery and start over again.
Is my system better than the governor in the CC??.....difficult for me to say, but I believe that I would prefer to use my new system with the extra boost than the straight governor in the CC or Jeti. I will be flying in the next world champs with an E-Max 2826, a ZTW, esc and my system. In a one on one governor comparison with my timer and the CC or Jeti, I believe that the built-in governors will react faster and this may be better. For the price of my system however, it is unbeatable right now and the performance is very good. I do believe as I said though that with the variable gain, it puts it on a new level that is really great to fly and will be highly competitive now.
Keith R
Keith R
Offline Will Moore
« Reply #11 on: March 04, 2012, 01:22:29 PM »
Keith;
I will be in touch with Eric Rule this week to purchase your complete system,
so I can try it out.  I will let you  know via e-mail how I'm making out.
At these prices, I would think everyone would want to try out the
timer and it's adjustable Gov. set up.
I will stay in touch, and thanks again
 AMA # 209
  • Andy
« Reply #12 on: March 05, 2012, 10:30:12 AM »
Will to answer your question I have tested the KR timer on the following ESCs
ZTW 50 and 70 amp.
Turnigy 50 amp
CC Thunderbird 12, 38 and 56 amp.
Right now I am finishing up an RSM Continental that I have modified to electric.  I will have a Hacker A30-10XL motor, ZTW 70 amp ESC KR timer/governor, 3300mha battery and a APC 12 x 6.5 WEP prop.  This is the same setup I am using on the Naughty Girl and I am very happy with this setup.  On the Naughty Girl I get 5.25 sec. laptimes and line tension everywhere.  I wind up with around 30% left in the battery.  Depending on the weight of the Continental I may have to adjust the battery and RPMs but I don't expect it to weight much more than the NG.  She came in a bit heavy at 52 ounces with battery, but flys better than anything I have ever had.  Again I am an Intermediate flyer best score ever 436 which I got on the Naughty Girl at the Southwest Regional last month.  I try to let as many expert flyer's fly my plane as possible to get a more balanced judgement, they all seem happy with the setup.  One last thought, on the Naughty Girl I am nowhere near max motor power available, and I still have 10% available battery capacity should I want to crank it up.  But the way it is flying now I see no reason to mess with it at all.
Andy
Andrew B. Borgogna
« Reply #13 on: March 05, 2012, 11:55:40 PM »
Hi Andy, I'm running a 50 amp ZTW with a 3300 4-cell battery in my Electron and it is heavy at 1820 grams (64.2 oz.). I use around 2200~2400 mAh when I fly at sea level. I reckon your 52 oz. Continental could use a smaller battery and the 50 amp ZTW. This will save you some weight.
My friend Percy Attfield has a new Impact with a Hacker A30-12XL on a 5-cell 2700 mAh battery that he is busy testing now. His other Impact has the same MVVS 6,5/910 motor as my Electron in it so we will have some good comparisons shortly. The 5-cell Thunder Power lipo is lighter than the 4-cell 3300 lipos that we use.
My new stunter is under construction now and my target weight is around 58 oz. or less, so I should get away with a 4-cell 2700 lipo. Right now Percy and I are having fun with these systems.
Keith R
Keith R
  • Andy
« Reply #14 on: March 06, 2012, 03:43:10 AM »
Thanks for the information Keith.  I will do some testing to see if I can reduce the battery size, it would shure help in the CG area.
Anduy
Andrew B. Borgogna
Offline Percy Attfield
« Reply #15 on: March 07, 2012, 12:34:13 PM »
My name has been mentioned so Percy Attfield will provide input.
Since the last quarter of 2011 I have been flying with the new KR Timer and each time I fly I am more enthusiastic.  At the end of January there was very light wind and I purposely did the much of the pattern wind up.  Sure it became lighter on the lines than when it is flown wind down but that is all.
The new timer has a “Gain” function which can be programmed.  Essentially this changes the timer algorithm to suit your own style of flying for the particular plane that you fly.  It is like adding Nitro until the engine performs as you per your preference; more power, not necessarily more revs.  We have found that lighter planes and thin wing planes require different Gain settings to my Centurion, which is modelled on a standard Impact, the fuselage outline is different between the two planes.  It weighs 66 ounces battery in place ready to fly and uses an MVVS 6.5/910 motor with a 4 cell 25C 3300MAH battery and a 60 Amp Align ESC. Remember we fly just over 6 minutes in accordance with the FAI rules which states that we must be landed and stationery in 7 minutes.
Governors try to keep the revs of the motor constant as set by the pilot.  Using the Gain function the pilot changes the algorithm in terms of the severity of the reaction of the governor in response to the deviation from the set revs.  With the Gain set at 10, the maximum, the governor reaction is “Violent” and Keith decided to cap the Gain at a 7 setting.   With a heavy plane you hear how the motor kicks in and out to respond to every little deviation in the flight path.  Nearly like adding too much Nitro and having a far too strong 4/2 break in the pattern.
With the Gain set at 6 the Centurion did very well in the verticals but the bottom quarter of a manoeuvre (especially the consecutive round ones) speeded up; at least that is what it felt like to me.  I changed the Gain to 4, with nearly the same vertical performance it addressed the speeding up.  Who knows a Gain setting of 5 may also work, but I am so happy at 4 that I have refused to move from that Gain setting (to the frustration of Keith Renecle who wants to experiment).
When the Gain function is used a number of things happen; the revs can be reduced by 200 rpm; the battery usage goes up by between 2% and 6% depending on the Gain setting; the vertical performance improves; the line tension improves. You become in charge of the algorithm and can set your plane to fly the way you enjoy it.  In my case a plane which had to be flown at 5.2 seconds is now flying at 5.4 seconds and doing better than it was at 5.2 seconds.  I can go as low as 5.6 seconds with a higher Gain setting but while it does the pattern it is not a pleasant plane to fly at that setting.
The Gain function has settings between 1 and 7 and each pilot will need to experiment which setting works best for him and the specific plane at the site where he flies.  I fly at 5,300 feet above sea-level and at the end of January it was a nearly windless 34 Celsius (94 Fahrenheit) day.
I used to like my electric Centurion........since I found my Gain number I love it!
Try it; and yes it requires some experimentation and it likely that the Gain number will vary at different flying sites, but it is worth it.
I have new 1750 grams (61 ounces) Centurion-XL with a Hacker motor, a 60 Amp ZTW and a 5 Cell light weight Thunder Power Battery.  It has only had 2 flights so there is no information yet.
Included is a photo of the old Centurion and I taken during the Winter in August 2011.
« Last Edit: March 07, 2012, 01:02:39 PM by Percy Attfield »
Percy Attfield - South Africa
  • Andy
« Reply #16 on: March 07, 2012, 04:21:33 PM »
Hi Percy
I have found that a gain of 5 works very well on my Naughty Girl it has a thick airfoil and a blunt leading edge.  On the Trophy Trainer 5 was too much, I am currently back to 1 and will start moving up when I get some time.  Right now all my time is going to preparations for the Vintage Stunt Championships coming up next week.  It's great to know that others are have good results with this product, a lot of time when into this project by Keith and he deserves a lot of recognition for his work.
Andy
Andrew B. Borgogna
Online Larry Wong
« Reply #17 on: March 07, 2012, 04:53:38 PM »
Guys I might have miss it but I'm using a CC/45  and CC/ice 50 and Schulze ESC's   What do I have to do to the Gain control on these unit? or can I just leave as I'm using it and just add the K R Ver.2 timer? ???
Larry
  • Andy
« Reply #18 on: March 08, 2012, 12:32:10 PM »
Larry
You simply have to disable the governor, the governor feature is in the timer and does not use the governor in the ESC.   This is why I suggest using the less expensive CC Thunderbird series of ESC instead of the ICE unless they don't make a Thunderbird big enough.  Then I use the ZTW or Turnigy ESCs again with the governor disabled.  The good news the default setting for governor in all the ESCs I have tested is governor off.
Andy
Andrew B. Borgogna
Online Larry Wong
« Reply #19 on: March 08, 2012, 03:11:47 PM »
I went to the CC/link and the setting is controline throttle type says GOVERNOR , then it shows 3choices simple/ gov l and Gov. H . How do I disable the gov.?
Larry
« Reply #20 on: March 08, 2012, 04:19:58 PM »
in the setup menu - do not select control line - leave it at airplane ...then the governor option is not available
Online Larry Wong
« Reply #21 on: March 08, 2012, 04:21:04 PM »
THANKS #^ #^ #^
Larry
Online Larry Wong
« Reply #22 on: March 08, 2012, 07:13:04 PM »
OK I got the delay set as per instructions but every time I try to set the flight time, I count 31 flashes and let go of button, and unplug battery, then I try it and the delay works fine , then I get only about 10 sec of power??? I've tried it 4 times !!! am I missing something? ???
Larry
« Reply #23 on: March 08, 2012, 10:19:42 PM »
Hi Larry,
The programming system lets you know that you have stored the setting by coming back with the same amount of flashes again. If you set the flight time, you press S1 4 times. The LED flashes 4 times and then you hold the button for the amount of seconds you want, like in your case 31 flashes = 310 seconds. When you let the button go you need to wait another 3 seconds for the confirmation flashes (another 4 flashes in this case) and then the LED stays on again telling you that you have stored the setting. Then you can remove the battery. The fact that you get a 10 second run means that it only stored 1, or 10 seconds, so it's working fine in fact. Hope this helps.
Your setting is what I fly myself and is plenty for a good pattern with a little extra as well. Let us know how the system works for you.
Keith R
Keith R
« Reply #24 on: March 08, 2012, 10:36:06 PM »
One more thing I forgot to mention. The timer comes with a default setting of 300 seconds or 5 minutes flying time plus a 25 second start up delay. This means that the total time from when you start the timer is 325 seconds. When you switch the slide switch on, the motor will spin slowly for a second or two and then stop. After the 25 seconds start up delay, it will start up slowly and then the governor will kick in. So you can actually plug in the system and use it if the default setting suit you.
Sometimes when you get a new esc, then you need to calibrate the throttle range with low/high throttle. This means that you need to use an R/C system, but I've allowed for this on my timer for those that don't have an R/C system. You put the slide switch to the ON position before you plug in the battery. This outputs a full throttle signal (2.0 ms pulse width) to the ESC. It will not start up because all esc's are programmed this way to prevent the motor starting up if the throttle stick is not in the low throttle position on turn-on. So on my system you switch the slide switch into the ON position and plug in the battery. The esc will give a shorter series of beeps (usually 2) and then you switch the slide switch OFF. The esc is now permanently calibrated.
Just by the way, this is why I use a slide switch instead of a pushbutton in case you were wondering. It makes this job simple.
Keith R
Keith R
« Reply #25 on: March 09, 2012, 09:51:48 AM »
Hi Andrew,
Thanks for your information.  I was sitting on the veranda watchingthe the sunset and an approaching thunderstorm as I tried to think through some of what we know about the Gain function.  For example I found that the Hacker A30-12XLV2 "kicks" much more when the gain comes in than the MVVS 6.5/910 so I was thinking I should change the gain to 3 for the Hacker.  Then I thought it may not be the motor so much as the KV rating.  The higher KV of 910 uses a 4 cell battery and the lower KV of 700 on the Hacker uses a 5 cell battery that may be why it seems to be more violent.
Perhaps all lower KV motors will use a lower Gain number.
Anyway I have only had 2 flights on the new plane so it is still early days I will have more information after tomorrow but it will take more time than day or two to draw conclusions and as I said before different pilots will come to different conclusions, depending on how they like to fly.
I was also wondering what difference the heavier APC 12X6.5 (Dennis Adamisin) prop may have on the way the gain kicks in. It is half an ounce heavier than the old thin APC 12X6  pusher prop.
Enjoy VSC I am thinking of the guys in Tucson when it comes to the middle of March.  It seems quite amazing that we have been back in South Africa for the past 9 years already.  Out last VSC was 2003.
Percy
« Reply #26 on: March 09, 2012, 10:17:55 AM »
Probably a little late now, but, would love to see you back here again in the states.   We are, will be starting spring weather, then summer.  After this winter of mild temps, hate to think what summer is going to be like.  Besides, isn't it just a little over a hop, skip and jump from there to here? H^^
Online Larry Wong
« Reply #27 on: March 09, 2012, 02:37:22 PM »
Keith R
Keath : now I'm Really confused the instruction I got with the timer says to set flight time ( Press S1 3 times? )??????? ???
« Last Edit: March 09, 2012, 03:02:02 PM by Larry Wong »
Larry
  • Andy
« Reply #28 on: March 09, 2012, 04:37:55 PM »
Larry
Keith made a typo in his response.  For the original unit, the one that does not have a LED on it the following are the setting flashes:
2 pushes of S1 followed by 2 flashes of the LED, RPM setting.
3 Pushes of S1 followed by 3 flashes of the LED, Set flight time. (as you pointed out)
4 Pushes of S1 followed by 4 flashes of the LED, Set start up delay
5 Pushes of S1 followed by 5 flashes of the LED, Set gain value.  This feature only works with the latest firmware.  Your firmware can be updated to include this feature.  You need to contact Eric Rule at RSM for the details regarding firmware update.
For RPM press S1 twice and wait for two flashes of the LED, the motor will start running then use the two carets "< RPM down, > RPM up".  I secure my planes down and start the motor and with a tach I use the carets just like a needle valve to set the motor RPM.  Think of the carets at needle up and needle down.  When you reach the RPM you want press S1 the LED will flash twice and lock in the RPM value and shut down the motor.
For flight time you push S1 3 times, the LED will flash back 3 times and then be ready to program.  For flight time hold S1 down and count the number of times the LED flashes, each flash equals 10 seconds of flight time.  I usually set mine for 5 minutes (30 flashes).   When you have counted the correct number of flashes release S1 and wait approximately 3 seconds the LED will again flash 3 times and the flight time will be set.
For start up delay, do exactly the same routine except for start up each flash is 1 second of delay.  The same is true for gain value, hold S1 down and each flash increments the gain by one.
I should warn you that sometimes you will get an extra flash of the LED when you are finished counting flashes.  This will add 1 second to flight start up delay and 10 seconds to total flight time.  It can be annoying but it has little effect on the over all flight.  BUT you can also get the extra count on the governor gain value, this can have a real effect on your flight performance.  Make sure you count flashes and observe if you get an extra flash and decide if it is OK for the setting you are changing.  Again for flight time and start up delay I just ignore it, but if I get an extra flash for gain I reset the gain again.  I have found that if you release S1 as soon as the last flash you want occurs you generally don't get the extra count.  A little practice helps.  If you are still confused send me an email or give me a call and I can help you with the process.  I have done it many times on many timer/governors and it does work.
I really hope I have not confused you.  Like I said I am here to help.
My email address is: abborgogna@hotmail.com
Andy Borgogna
Andrew B. Borgogna
Online Larry Wong
« Reply #29 on: March 09, 2012, 08:40:28 PM »
Guys Just wondering !    What does the yellow wire Do?   does it matter were it 's  connected to of the 3 wires to motor?
Larry
« Reply #30 on: March 09, 2012, 10:05:51 PM »
Hi Larry, Sorry about the number of flashes error..........sitting here with a touch of the flu unfortunately. Andy summed it up pretty well. The new boards with the LED on the board is exactly the same. The extra flash that Andy mentioned is just timing. The programming cycle has to keep the esc happy all the time while you're doing the programming. Just let it go as soon as you see the last flash that you need.
The yellow wire can go to any one of the motor wires. I tend to stick it on the centre wire because it looks nice.......to me!
Keith R
Keith R
  • Andy
« Reply #31 on: March 10, 2012, 03:26:40 PM »
Below is a response to a message I received from Dennis Adamisin.  Since there might be others asking the same question I thought I would post this to everybody.
Do you start over when changing the flight time or delay time or the gain, or do you add  to what is already programmed?
Are the up and down carets only for RPM adjustments?
Do you hold down S1 or depress it for each count when changing start up delay seconds, flight time increments, or gain factor?
Do you press the carets for each increment change in RPM or hold them down?
Hi Dennis
Since these are really good questions I think I will add them to the thread but I will also answer them here.
For flight time, flight delay, and gain you aways start over.  Let use start delay as an example.  You want to go from 5 seconds to 10 seconds, you hold and count 10 flashes.  The up and down carets are only used for RPM setting, nothing else and I always click the caret buttons to move in a direction.  I think holding them down will also work but I am not sure.  That's a question for Keith, or I just go out in the garage and try it.   Finally yes it is "Hold and Count" for start up delay, flight time, and gain.
Andy
Andrew B. Borgogna
« Reply #32 on: March 10, 2012, 09:45:35 PM »
Writing instruction manuals is not my forte, but for setting rpm, it does say "Use the “>” button to increase the rpm and the “<” button to decrease the rpm. Each press and release will add or subtract approximately 50~100 rpm, depending on the number of poles in the motor." If you hold the S1 button in in this mode, it holds the rpm. I initially made it increment but found that it was hard to find a suitable cycle speed. Too fast........too slow sort of problem.
For the flight time, startup delay and gain it says "Now hold in the S1 button and count the number of flashes from the LED."
What I need to do is to make a video demo of how to do this and stick it on YouTube or somewhere. I just need to mount a system on a neat board to show everything properly. It sounds like a bit of a hassle but in practice, it's dead easy once you understand the procedure, and you will find that you don't set it that much anyway. Just by the way, I don't know the word "carets" that refer to pushbuttons. I even Googled it, so please educate me here. Thanks.
Keith R
Keith R
  • Andy
« Reply #34 on: March 10, 2012, 10:45:34 PM »
Hi Keith
The word caret is what we called the <> symbols where I worked.  It may have just been a local company term, but it's what I have alway refered to them as.  In fact I don't know any other word for them.  In math they were called "greater than" and "less than" but that does not seem to fit too well with what we are describing.  Anyway what do the people of South Africa call them?  I am good with any word you choose my friend. y1
Andy
Andrew B. Borgogna
« Reply #35 on: March 11, 2012, 11:09:17 PM »
Thanks Andy & Tim, I learn something every day! I'll ask around locally as well, and most likely they use the same term. It's just new to me, and I'll add it to my dictionary. It's a nice short word and beats "greater than" and "lesser than".
Keith R
Keith R
« Reply #36 on: March 11, 2012, 11:11:51 PM »
Keith R
Note, as you are folding it into your vocabulary, that I have only ever seen it used to mean "menu pointer thingie", never "mathematical operator thingie".
Online Howard Rush
« Reply #37 on: March 12, 2012, 01:26:11 AM »
Can we now use terms like ">^24Au"?  I'm working on folding it into my vocabulary.
  • Andy
« Reply #38 on: March 12, 2012, 03:47:15 PM »
Tim
You are absolutely correct the caret is not a math operator.  But it can be used to describe the results of relational computer operators as in, < less than op,
< = less than or equal too op, > greater than op, and > = greater than or equal too op.  These were test operators we used in our processors many years ago.   They were used to test the results of math operators and leave a flag on the top of the stack for the conditional branch operators to branch on.
Again you are absolutely correct to say they are not math operators. Man I sure like being retired from computers.  Model airplanes are much more fun.
Now for something important.  My wife and I arrived in Tucson for VSC, I got in a flight on the Ignition plane and all systems are go for tomorrows event.  Oh my I just don't want to make a fool out of myself! n~
Andy
« Last Edit: March 14, 2012, 04:03:08 PM by Andrew Borgogna »
Andrew B. Borgogna
Online Howard Rush
« Reply #39 on: March 14, 2012, 02:25:27 AM »
Looks like it hasn't worn off.  You were writing about vertical 8 "iterations" at VSC.
  • Andy
« Reply #40 on: March 14, 2012, 04:04:35 PM »
Dang Howard, you know you are right.  Old habits die hard.
Andy
Andrew B. Borgogna
