  • July 11, 2025, 12:59:37 PM
Author Topic: new electric  (Read 4036 times)
Offline paul winter
new electric
« on: September 21, 2012, 03:49:58 AM »
new Bob hunt foam wing for my new electric model
came out at 11.5 ounces
so i Geo"d it to get rid of 2.5 ounces
the model is going to be a strega but with a Cardinal 92 wing
the centre has been fibre glassed
im going to plastic cover it as if dope gets into the foam .........
the last panel will be cut out when the tips are on
hopefully 52 ounces all up weight .....ha ha
and retracts
Offline William DeMauro
Re: new electric
« Reply #1 on: September 21, 2012, 04:11:46 AM »
Hi Paul,
 I see that this is your first post, so welcome to Stunt Hanger!!!. Your wing looks great. I'm looking forward to seeing this plane finished. Hope all is well for you.
William
AMA 98010
Offline Crist Rigotti
Re: new electric
« Reply #2 on: September 21, 2012, 07:18:20 AM »
Hi Paul,
What William said!
Re: new electric
« Reply #3 on: September 21, 2012, 09:02:00 AM »
Now you came to the rite site.   I thought I recognized the name and looked at your profile.  I don't get on the Barton site as much for some reason.  Still have a profile PeaceMaker waiting  for diesel ingredients.   Just no big rush.
Offline paul winter
Re: new electric
« Reply #4 on: September 21, 2012, 09:10:47 AM »
hi thanks
as the airframe looks so good im going to cover it in a coloured clear profilm/monocote
the fuz is going to be tissued
Offline Jason Greer
Re: new electric
« Reply #5 on: September 21, 2012, 10:25:32 AM »
Looking real good Paul.
Jason
El Dorado, AR
AMA 518858
Offline paul winter
Re: new electric
« Reply #6 on: September 22, 2012, 04:50:52 AM »
wing ready for covering ,8 ounces
fuz coming along nicely
Offline Douglas Ames
Re: new electric
« Reply #7 on: September 22, 2012, 06:45:55 AM »
I like the bracing on the fuse. Tha's a neat idea.
AMA 656546
Offline paul winter
Re: new electric
« Reply #8 on: September 22, 2012, 10:15:20 AM »
hi Douglas
the bracing adds very little weight but gives lots of strength of the torsional forces
the strips are 1/4 square cut from very light sheet
paul
Eric Viglione
Re: new electric
« Reply #9 on: September 22, 2012, 10:32:45 AM »
Looks good Paul, welcome aboard SH!
Yes, that's a good idea, especially if you like your stab to stay level  even after you put silkspan on the fuselage,... don't ask how I know that one!
I did a similar deal with a Dixon kept foam wing, I used SLC film just over the open bays and 1/2" beyond for adheasion so I could silkspan after like normal. I didn't SLC the whole wing so as to avoid any film type bubling over the sheeted areas. Once you silkspan, it stablizes the SLC and it doesn't shift.
EricV
hi Douglas
paul
Offline Ward Van Duzer
Re: new electric
« Reply #10 on: September 22, 2012, 11:27:22 AM »
Paul,
Fuse looks good! Very Hunt-ish.
W.
Offline paul winter
Re: new electric
« Reply #11 on: September 24, 2012, 12:39:33 PM »
model moving along nicely
as you can see i have rebated the front of the wing so i can get the batteries as far back as i can
even with a ten inch nose my last model was 30 grams on the tail needed
also the retracts and wires in place
on this model the battery tray is in line with horizontal CG
and when the retracts are up it should be prefect ,,,,,,,,last famous words
more photos to come ,,tail plane next
usualy build 1/2 inch thick stabs but this time trying 3/8 geo .
pw
Re: new electric
« Reply #12 on: September 24, 2012, 01:39:45 PM »
Lookis really good Paul.   I especially like how you are adding lightness!
Offline paul winter
Re: new electric
« Reply #13 on: September 24, 2012, 03:12:22 PM »
Hi Dennis
the  way i get things light is very care full wood selection
also Bob Hunts Foam wings are very light to start with
i got all this  wood from Prague many years ago
for ex-sample 1/16 x4 x 42 inches c grain 12grams but to get the light stuff i had to buy lots of medium
when i went last i bought 2500 sheets of various wood thicknesses
as Windy used to say "if your wood is 15 grams and not 10  your model is 70 ounces and not 55 "
paul
Offline Andrew Borgogna
  • Andy
Re: new electric
« Reply #14 on: September 24, 2012, 11:12:08 PM »
How are you avoiding interference between the inboard retrack and the leadout lines.  I too have a set of the same retracks and a special timer from KR that works great with them.  I keep thinking the leadouts will conflict with the inboard retrack, maybe that is the problem I am over thinking this!
Andy
Andrew B. Borgogna
Offline paul winter
Re: new electric
« Reply #15 on: September 25, 2012, 12:34:37 AM »
Hi Andrew
the bellcrank is mounted high in the wing
and the re tracks wire is pulled tight when connected so it sticks to the bottom of the wing
Offline paul winter
Re: new electric
« Reply #16 on: September 26, 2012, 04:11:19 PM »
hi all more pics of my elec  model
the top decking is moulded out of 1/16 very light balsa the location strips are put on the edges to locate with the fuz ,a 1/8 square down the spline to stiffen it and super glue  sprayed on it
weight is 9 grams
next is the access panel so i can get to my retracts wires
esc and timer bay  next
complete model without motor 17 ounces
next dilema is to tissue the whole model or cover in plastic ?????????   answers please your views
Re: new electric
« Reply #17 on: September 26, 2012, 06:02:50 PM »
Hi Paul,
I would cover the open bays only with SLC, just onto the wood enough to seal it down.  Then use silkspan over everything.  You will get the puncture resistance of the SLC plus the added strength of silkspan.  Total weight gain is negligible, since less dope is needed to fill the silkspan.
BIG Bear
RNMM/AMM
Offline paul winter
Re: new electric
« Reply #18 on: September 27, 2012, 12:17:37 AM »
hi Bill
whats Slc??
paul
Re: new electric
« Reply #19 on: September 27, 2012, 07:35:15 AM »
hi Bill
whats Slc??
paul
Hi Paul,
"SLC" is "Super Light Covering" offered by Phil Cartier.  It is a clear mylar (?) covering which irons on, heat shrinks and is paintable.  Several people are using it under silkspan or silk.  It greatly increases the puncture resistance while doping on the silkspan gives it better torsional (?) strength.  Plus, it requires less dope to fill the silkspan.
BIG Bear
RNMM/AMM
Offline paul winter
Re: new electric
« Reply #20 on: September 28, 2012, 01:05:55 PM »
foundout esc was faulty ,because ibought a ztw esc and coupled it to a will hubin fm9 timer and it seemed to work ,so my question is...are these esc,s with governers really nessarcery????
Re: new electric
« Reply #21 on: September 28, 2012, 01:35:15 PM »
Uh - right thread?  Did you tell us what the problems were?
Will Hubin has a bunch of different timers to choose from; most of them are designed to work with an ESC with a governor.
The Kieth Renicle (sp?) timer contains a governer and an algorithm to sense a prop strike and shut things down; it'll work with any old ESC (but if you use it with an ESC with a governor you want to turn the governor off, lest the two governor algorithms get into a fight).
Offline paul winter
Re: new electric
« Reply #22 on: October 01, 2012, 04:28:19 AM »
hi All
well nearly finished
just trying to decide what coulor to do the wings
so far 26 ounces as it is
paul
Re: new electric
« Reply #23 on: October 01, 2012, 08:40:04 AM »
Now, how much  is the total power train components?   As far as colors, do it in your nations colors.
Offline paul winter
Re: new electric
« Reply #24 on: October 01, 2012, 11:40:06 AM »
hi John
total power train is 25 ounces with the retracts
paul
Offline paul winter
Re: new electric
« Reply #25 on: October 02, 2012, 12:12:43 PM »
all finished
52 ounces all up weight ,with retracts ..... #^
canopy to follow
Re: new electric
« Reply #26 on: October 02, 2012, 12:30:09 PM »
Nice clean workmanship, Paul.
What is the wing covered with and what did you use for the yellow?  How much trim color is waiting to be done?
Thanks!
Offline Airacobra
Re: new electric
« Reply #27 on: October 02, 2012, 12:59:17 PM »
Geesh Paul, you sure don't waste any time putting it together!!
Keith Bryant
Offline paul winter
Re: new electric
« Reply #28 on: October 02, 2012, 02:21:23 PM »
hi
the trim on the model depends how it flies
the finish is yellow tissue and blue profilm ,its a light weight plastic covering
paul
Offline paul winter
Re: new electric
« Reply #29 on: October 04, 2012, 12:36:30 PM »
hi all
When we were at the 2012 Nat's Jason Greer among others were flying electric ,Jason said "once you have flown electric you will never go back to I/C"
i said "no never i like my four strokes "
but i eat my words ,
i have two electric planes now and going out to fly is a real pleasure ,and clean ,noise isn"t a problem where i fly
thank you Sir Jason for buying my first kit for my birthday
paul
Re: new electric
« Reply #30 on: October 06, 2012, 07:11:17 AM »
Paul:
52 oz WITH RETRACTS is a stunning accomplishment.  It sounds like you are really enjoying electric flight too.  CONGRATS!
Offline Jason Greer
Re: new electric
« Reply #31 on: October 06, 2012, 11:18:49 AM »
Looks great Paul.  I'm glad to hear that you are pleased with the performance.  Say hi to John for us.
Jason
El Dorado, AR
AMA 518858
Offline paul winter
Re: new electric
« Reply #32 on: October 07, 2012, 08:41:11 AM »
so here is the model finally with black decking and canopy on
spending lots of time trimming ,the pusher props ,here it is with a 13x4.5 thin pusher
model came out at all up weight 53 ounces
i must say a 53 ounce model flies a heck a lot better than a 72 ounce plane , thats what i have found ,and you all going to say of course ,that as there is no large saito up front the model turns very well
full speck
wing is a Bob Hunt Cardinal 92 foam panels ,lightened
fuz is Brodak strega design ,18 inch hinge to hinge with a 10 inch noise
motor is an OS 3825-750
battery ...hobby king 5s-3000
esc casltle lite 50
time Will Hubin fm9r
retracts ..e-flight 10-15
prop 13x4.5 thin ep
revs still playing but around 9800
battery usage is about 75%
finish tissue fuz and tailplane
brodak clear dope to apply finish
wing    profilm
paul
Re: new electric
« Reply #33 on: October 07, 2012, 09:24:23 AM »
Paul,
Very nice airplane.  What's the wing area?
Offline paul winter
Re: new electric
« Reply #34 on: October 07, 2012, 11:53:05 AM »
About 690 i think
Re: new electric
« Reply #35 on: October 07, 2012, 12:16:22 PM »
Thanks Paul.
