  • June 15, 2025, 02:07:31 AM
Author Topic: New Electric Twin project back on track  (Read 150182 times)
Offline Kerry Ewart
Re: New Electric Twin project back on track
« Reply #350 on: May 24, 2014, 03:21:02 PM »
A twin with retracts,,the limitations are endless I say,,,
Counter rotating props Bob ?????
"If you cannot beat them!JOIN THEM.
Offline Tom Niebuhr
« Reply #351 on: May 27, 2014, 10:09:11 AM »
Bob,
I am confused. What is the difference in the two twins. I know you had a test twin with profile nacelles. Are their two full bodied twins. Am I losing track of all your projects?
AMA 7544
Offline Tom Niebuhr
« Reply #352 on: May 27, 2014, 11:58:41 AM »
Bob,
So is there a "Third Wind" which is which???
AMA 7544
Offline Mike Ferguson
« Reply #353 on: May 27, 2014, 12:21:02 PM »
The thread started with the "old new twin" (the Second Wind, which you can see in photos has a built up Lost Foam wing).
The testbed first was mentioned here.
The "New new twin" is the Wildfire (which you can see in photos has a sheeted foam wing.)
Pictures of all three (old new, new new, and testbed) are here.
« Reply #354 on: May 27, 2014, 10:06:58 PM »
 Nice to see some progress with the finish Bob, hopefully we'll see it all wrapped up and flying soon. #^
Offline MarcusCordeiro
« Reply #355 on: June 06, 2014, 07:00:27 AM »
Wow, wow, and wow!!!!.... :D 8) 8) 8)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #356 on: June 06, 2014, 07:59:21 PM »
I just noticed looking at the photo of the twin in Chromaseal that you have in the background exactly what I'm looking for :
I'm in the middle of making the worlds biggest game of monopoly - and I need giant Dice.
« Reply #357 on: June 15, 2014, 08:41:00 PM »
  NOW we're talkin'!!! o2oP CLP** o2oP
  I like how you went with a straight line over the top for rear portion of the "canopy", it looks more realistic than the Crossfire type. y1
Offline Tom Niebuhr
« Reply #358 on: June 16, 2014, 05:23:44 AM »
Looks great!
Now the final work and graphics, clear coat and flight.  The NATS are getting very close. I know that you have very good airplanes ready, but I hope that this will be your NATS plane.
AMA 7544
Offline Tom Niebuhr
« Reply #359 on: June 16, 2014, 09:10:20 AM »
Here is the new Huntmobile!
AMA 7544
« Reply #360 on: June 16, 2014, 06:09:27 PM »
The Crossfire canopy treatment is meant to simulate many of the modern jets that have such shaped canopies. The twin is supposed to be more of a private plane look. Although it's always madness on my part, there is often method associated with it.  n~
Later - Bob Hunt
 Yup, gotcha. :)
Offline James Mills
« Reply #361 on: June 19, 2014, 09:37:00 PM »
I spent Father's Day applying the red trim and a bit of the blue trim. Also got the canopy on. One more long day should do it!
Later - Bob Hunt
Bob,
Looks nice, look forward to seeing the finished product.
James
AMA 491167
« Reply #362 on: June 20, 2014, 07:04:13 AM »
Wel l , That was quick . :P Like good wine , I suppose .  ;D H^^
« Reply #363 on: June 29, 2014, 10:37:14 PM »
 How's the paint coming along Bob?
« Reply #364 on: July 03, 2014, 09:36:01 AM »
I'll be waiting.   Have fun at the NATS.
« Reply #365 on: July 24, 2014, 02:14:34 AM »
RIGHT .
No Impediments NOW . ! n1
Test Flight DUE . . . . ;D
 H^^
Offline Tom Niebuhr
« Reply #366 on: July 24, 2014, 07:29:45 AM »
I little bird told me that the first twin will be in the air, possibly in less than a week, weather permitting.
Looking forward to the first flight report and pictures.
AMA 7544
Offline David_Stack
« Reply #367 on: August 11, 2014, 10:07:02 AM »
Congratulations on the successful maiden flight (and then some) Bob!
You mention flaps that are less than ideal from a torsional stiffness perspective...  What about using a different form of carbon material instead of the carbon veil, something with some 'grain' to it?  You could orient the fibers on a bias to help prevent the twisting.  There are some awfully light carbon weaves being produced now, and in use in the R/C discus-launched glider community.  Something along the lines of what is being discussed here: http://www.rcgroups.com/forums/showthread.php?t=2161133&highlight=vlad+tow
r/
Offline Dan Bregar
  • Field Marshall
« Reply #368 on: August 11, 2014, 10:58:21 AM »
Fantastic !  Way to go Bob.  I'm staying tuned for the next chapter !  ;D
Dan
AMA 33676
Offline Tom Niebuhr
« Reply #369 on: August 11, 2014, 11:10:10 AM »
Bob,
Great progress to date.
I know that you had to make adjustments for the vertical c.g.
How much is that going to change with the gear up?
AMA 7544
Offline Matt Colan
« Reply #370 on: August 11, 2014, 02:09:03 PM »
Awesome Bob!!!
I think having the props turning in towards the fuselage will be best since it will eliminate having a critical engine. I'd imagine having a critical engine on an electric twin wouldn't be that huge of a deal because of the timer.
« Reply #371 on: August 11, 2014, 04:35:57 PM »
Plain and simple: NICE!!!!!
Marcus
Aces High!
Offline Dan Bregar
  • Field Marshall
« Reply #372 on: August 12, 2014, 05:22:42 PM »
Wow !  Fantastic work !  You are the best Bob !  I really like your stab jig too !  What adhesive did you use to put the carbon onto the foam ?  Thinned white glue maybe ?
Dan
AMA 33676
« Reply #373 on: August 12, 2014, 05:36:00 PM »
Man, Bob, you do awesome work. That is just unbelievable. I like it a lot.
Offline David_Stack
« Reply #374 on: August 13, 2014, 06:11:02 AM »
Dan;
  Back in post #354, Bob discusses the construction of the wing, what her terms his "Lost-Sheeting method", and the adhesive used.  You are correct in what you surmised regarding the adhesive used...
  Requoted here:
  "We used the same technique to build the wing for this testbed model as we did for the Joe Nall Cadet models. We call this construction the  "Lost-Sheeting method." There is no balsa sheeting on the wing. The wing is a solid foam core made from 1-pound density foam. There is a slot cut in the center of the wing cores to allow the leadouts to get to the tip and have some adjustment. There are slots cut into the top and the bottom of the wing at the high point to accept 1/2 x 1/8- inch basswood spars. The spars run the full span of the wing. There are several shear webs imbedded in the core between the spar slots to prevent the spars from "racking." That is the technical term for what the spars want to do on either side of the wing during maneuvering. In an inside maneuver the top spar in in compression and the bottom spar is in tension. If there were no webs between them, they would try to "clap hands" under stress. The webs prevent the spars from trying to move and hence impart a tremendous amount of strength. Enough not to break under maneuvering loads by themselves? Not quite. After the spars are glued into the slots and are firmly glued to the vertical grain shear webs, we apply .2 (two tenths ounce per square yard) carbon mat using water thinned Titebond wood glue. The carbon is first applied from the back of the spar on the top, around the leading edge and ends at the back of the spar on the bottom. A thin carbon strip reinforces the trailing edge area, and an additional piece strengthens the entire center section area."
r/
Offline Dan Bregar
  • Field Marshall
« Reply #375 on: August 15, 2014, 08:50:23 AM »
Thank you very much David.  :)
Dan
AMA 33676
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #376 on: August 17, 2014, 05:52:51 AM »
Nice photos of construction.  It helps me figure out how to convert my ARC Oriental to ECL.
Was wondering what the service ceiling was on engine out?
Just glad to be here
Offline Dean Pappas
« Reply #377 on: August 19, 2014, 01:45:30 PM »
70 feet, of course!
later,
  Dean P.
Dean Pappas
« Reply #378 on: August 26, 2014, 02:52:02 PM »
Very cool! ;D
Derek
« Reply #379 on: August 26, 2014, 03:39:38 PM »
U B twinning!
Offline RC Storick
« Reply #380 on: August 26, 2014, 04:00:32 PM »
Hey Bob who's the old guy holding your airplane?
« Reply #381 on: August 26, 2014, 04:17:53 PM »
Way Kewl Bob!
Spool up sounds great!
 H^^
And old guys rule!
« Reply #382 on: August 26, 2014, 04:41:40 PM »
bob,
Yea, something I noticed (with my neophyte knowledge) flying my electric last weekend. The thing pulls like a truck but is easy to fly corners and maneuvers. With an IC plane pulling that hard, it would take hydraulics to make a turn.
Dwayne
« Reply #383 on: August 26, 2014, 04:45:07 PM »
If 5 years ago you'd have told me I'd be watching this I would have laughed. What a time for C/L stunt we live in, outstanding!!! y1  #^ ~>
Offline Dean Pappas
« Reply #384 on: August 26, 2014, 07:24:53 PM »
"So much time and so few experiments to do ... wait, reverse that."
With apologies to Willy Wonka,
  Dean P.
Dean Pappas
Offline Dan Bregar
  • Field Marshall
« Reply #385 on: August 26, 2014, 08:50:49 PM »
Man, I just loves it !!!  Fantastic.  And to think it's only going to get better !  #^
Dan
AMA 33676
Offline James Mills
« Reply #386 on: August 26, 2014, 10:01:44 PM »
Bob,
Ben said that was very cool.
James
AMA 491167
Offline Shawn Lenci
« Reply #387 on: August 26, 2014, 10:52:43 PM »
Very nice Bob...wish I could find a parking lot like that out here in CA to fly in.
Shawn
AMA 97686
« Reply #388 on: August 27, 2014, 06:35:28 AM »
Looks good in the air, Bob!  I know the "real" bird will be better!
Offline Tom Niebuhr
« Reply #389 on: August 27, 2014, 09:56:42 AM »
Bob,
Thanks for the very exciting reports.
It is a little hard to see the gear up and down for landing. I am sure that the small and larger twins will be a work of art.
We will all be anxious for more reports and for the flights of the new twins from you and Buddy.
This also gets me excited about getting back to work on my new electric stunter with retracts.
AMA 7544
« Reply #390 on: August 28, 2014, 09:11:16 AM »
Bobby, I am so excited to hear of the success you are having with the twin.   I guess the electrics is the big secret.  Tell Robby hi from the old man.
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #391 on: September 01, 2014, 03:12:53 AM »
Dan
Nice...sort of how Phil Cartier makes wings...
« Reply #392 on: September 10, 2014, 10:35:06 AM »
>>It still pulled like the Queen Mary out there<<
That's something I noticed with mine. The pulls like a truck. With IC planes, when the pull like that, they are usually quite hard to turn from level flight. Takes a ton of stick pressure to get them to want to turn. With this new electrical beast, it was pulling quite hard but turned very easily and precisely. I found that odd.
« Reply #393 on: September 10, 2014, 01:00:25 PM »
I've watched all the vídeos and liked them a lot....
Oh, the ship too.... I love it!!!
Marcus
Aces High!
« Reply #394 on: September 10, 2014, 02:32:24 PM »
>>Actually I have found that the swept forward trailing edges that I use on most of my models yield very little stick pressure.<<
Well, there may be something to that. My current plane has some forward sweep to the trailing edge. Only way I could get enough flap area with the elliptical wing.
Now, if I can just get out the slight hunt, I will be pretty happy with my new bird.
« Reply #395 on: September 11, 2014, 12:06:09 AM »
Haven't you heard?  All electric planes do that.
Offline Larry Wong
« Reply #396 on: September 11, 2014, 07:48:18 PM »
Randy I notice that all my electric planes also pull like a truck, I think the pusher prop I use cause it but they fly so well that I just can't make myself try a tractor prop. to see what happens. ???
Larry
« Reply #397 on: September 12, 2014, 11:08:36 AM »
Larry,
I thought the same thing. I may try a tractor prop on it just to see what happens, but haven't yet.
« Reply #398 on: September 12, 2014, 08:25:12 PM »
 Did I miss it, or has the full meal deal original not flown yet?
« Reply #399 on: September 14, 2014, 09:30:44 PM »
That is great news.  I can't wait to see what happens when you get the other twin done.
