  • June 08, 2024, 03:43:58 AM
Author Topic: New Electric Twin project back on track  (Read 119238 times)
Online Larry Renger
Re: New Electric Twin project back on track
« Reply #450 on: May 06, 2014, 06:05:30 PM »
Absolutely interesting! I guess we have less patience than you do.  :##
« Reply #451 on: May 06, 2014, 10:23:59 PM »
I just thought that the building process of these ships might be of interest to the readers on this forum.
Later - Bob
 Yup, very much so. Sure am anxious to see some color though! ;D
Offline Bob Hunt
« Reply #452 on: May 07, 2014, 04:33:24 AM »
Gee Wayne, it has dark gray on it now... LL~
Trust me, I'm working just about as fast as I'm able to. In fact, this one is coming together faster than any plane in the past for me. It's a very complex subject, however, and I really need to "eat this elephant one bite at a time" just to be sure I don't forget anything or rush through anything and get it wrong.
I couldn't resist taping the nacelle parts to the crutches for a hangar flying session... #^
I'm going to carbon the fin and rudder today, and also work on the front main access hatch holdowns, and glue the nacelle top pieces on permanently. My hope is to be in full finish mode by the weekend.
Later - Bob
Offline Bob Hunt
« Reply #453 on: May 07, 2014, 05:04:53 AM »
Here are a couple of shots of the bottom that show that nacelles to good effect. The main retract gear mounts will also go in today or tomorrow.
Later - Bob
Offline Allan Perret
  • Proverbs
« Reply #454 on: May 07, 2014, 06:59:45 AM »
That nacelle alignment process is pretty impressive.  And it does look like a lot..
Just curious, when doping the cf on the rudder/fin do you have a fixture to hold model with wing vertical so the rudder surfaces are horizontal.
I use a cardboard box about 3ft tall, and the 20" x 20" top opening is lined with foam pipe insulation to protect model.  Works great.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Bob Hunt
« Reply #455 on: May 07, 2014, 12:56:22 PM »
Hi Allan:
My holding fixture is pretty simple. I clamp two 3/4 x 2-inch pine strips to the edge of my bench and then cushion them with a couple of layers of microfiber towels. Easy and quick...
Later - Bob
« Reply #456 on: May 07, 2014, 09:36:08 PM »
Later - Bob
 Just keepin' ya on your toes Bob! ;D
Offline MarcusCordeiro
« Reply #457 on: May 08, 2014, 10:17:59 AM »
 8) 8) 8) 8) 8) 8) 8) 8) 8)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Bob Hunt
« Reply #458 on: May 14, 2014, 09:49:37 AM »
Okay, I got a bit more done.
The retract mount supports were made from 1/16-inch plywood and they get installed against the rear inner faces of the nacelles. Next, a 1/8-inch plywood retract mount was installed on the supports. Note that there is a hole in the rear of the mount that will serve as the holdown for the nacelle hatches.
I've spent a lot of time getting the top hatch to fit perfectly and all the parts are now carbon covered. The primer will be shot on this weekend. #^
Later - Bob Hunt
Offline Tom Niebuhr
« Reply #459 on: May 14, 2014, 10:14:39 AM »
Thanks for another update. Looking goooooood!
I hope that you don't run out of time to fly the twin at the Nats.
AMA 7544
Offline Bob Hunt
« Reply #460 on: May 15, 2014, 02:34:29 PM »
Thanks, Tom!
Got a bit done last night and this afternoon. The fillets are in and I made a fixture to hold the plane while priming and painting. Primer goes on Sunday!
Later - Bob
« Reply #461 on: May 15, 2014, 03:14:29 PM »
Such a beautiful job!!
Marcus
Aces High!
Offline Chris Cox
« Reply #462 on: May 15, 2014, 06:25:55 PM »
Great fit on the gear doors Bob.  They are virtually invisible  >:D
Offline Bob Hunt
« Reply #463 on: May 15, 2014, 07:45:42 PM »
The bomb bay doors are also a great fit, Chris...  VD~
Marcus: Thanks for the kind comments! #^
Bob %^@
« Reply #464 on: May 15, 2014, 09:55:20 PM »
Offline Chris Cox
« Reply #465 on: May 15, 2014, 11:04:13 PM »
All kidding aside Bob, it looks great!  Can't wait to hear how it flies.
That said, the bomb door idea isn't too bad!
Offline Alan Resinger
« Reply #466 on: May 16, 2014, 07:51:49 AM »
Bob,
What size props are you going to use?  I know a guy that might be able to supply you with a RH and LH pair for the project.
Alan
« Reply #467 on: May 16, 2014, 08:32:38 AM »
With that carbon finish it reminds me of some of the military jets that are flying.   It's looking great and I hope is worth the effort. H^^
Offline Tom Niebuhr
« Reply #468 on: May 16, 2014, 09:14:45 AM »
Bob,
Remember that AMA does not allow things dropping off airplanes during official flights....so......keep the bombing runs for demos only!!!!!
AMA 7544
Offline Tom Niebuhr
« Reply #469 on: May 16, 2014, 09:47:02 AM »
Bob, Chris,
Now that the real purpose of this magnificent project has been revealed, a name change is in order.  Electro Bomber; Hi Voltage Bomber; Electron Bomber; Shocking Bomber:???????????????
AMA 7544
Robby Hunt
« Reply #470 on: May 16, 2014, 11:08:46 AM »
"Voltage Drop" anyone? Haha.
« Reply #471 on: May 16, 2014, 03:11:10 PM »
Hi Bob,
As usual your workmanship is awesome.  I hope it flies beyond your expectations!  Looking forward to seeing it in paint and hearing the flight reports.
« Reply #472 on: May 16, 2014, 03:16:06 PM »
I think that electric planes have been around long enough that we don't need to have electron-themed names for the things.
Lesse -- twin engine, looks like a mosquito but it's not.  Musquito, bug, interesting bug, interesting flying bug -- lightnin' bug!
Robby Hunt
« Reply #473 on: May 17, 2014, 11:38:15 AM »
Are you positive? Don't be negative.
Offline Tom Niebuhr
« Reply #474 on: May 17, 2014, 02:03:27 PM »
Tim,
Bob mentioned the bomb doors in jest. I have known Bob since we were both in our teens. Certainly Robby knows his dad pretty well. So Robby, Chris and I are having some fun at Bobby's expense, and I am sure he is laughing with us.
So like Robby suggested, don't be negative.
I sort of like Robby's "Voltage Drop". After all, Bob said it is a bomber! Maybe someone else can come up with another name.
AMA 7544
Robby Hunt
« Reply #475 on: May 17, 2014, 02:23:41 PM »
I'd say Tim is right there too!
« Reply #476 on: May 17, 2014, 10:44:34 PM »
 Since it's a twin, having two "thrust generators",  I think Bob's "Second Wind" name is really cool and actually applies to the entire project. Beyond that, it may take Howard to resurface here to come up with a topper. ;D
« Last Edit: May 18, 2014, 08:41:13 PM by wwwarbird »
Offline Dean Pappas
« Reply #477 on: May 19, 2014, 09:51:20 PM »
I ought to say something clever about staying grounded during these discussions ... but I won't.
Dean
Dean Pappas
Robby Hunt
« Reply #478 on: May 20, 2014, 05:33:50 AM »
Dean
Uncle Dean, I know deep down you're still pulling for "Fred" in the name game, but surely you won't impede. ;)
Offline Shawn Lenci
« Reply #479 on: May 20, 2014, 04:06:51 PM »
Since Bob designed the "Hole Shot"...how new twin being called the "Double Shot"?  :)
Shawn
AMA 97686
Eric Viglione
« Reply #480 on: May 21, 2014, 06:06:03 AM »
Tim, Bob could just go with the thread title, but I do like your wind idea...so... how about "New Electric Wind Twin" ? The best part of this name is obviously that we would get to call it "The NEWT" for short. :)
« Reply #481 on: May 21, 2014, 11:11:22 AM »
Bob
Only the truth....
It's threads like yours that get us, normal people, motivated to dare try to build something that vaguely resembles what you and the other top builders do here.
If I am a better builder now, I owe it all to the people who post here.
Marcus
Aces High!
« Reply #482 on: May 21, 2014, 10:39:38 PM »
 Bob,
 Did the primer happen last Sunday?
Re: Is this going to be Nats Ready ?
« Reply #483 on: May 21, 2014, 10:50:02 PM »
I've seen a lot of talk, and a lot of Photo's - as impressive as this is.. I just want to know if its NATS Ready ?
And if so - will this be the year ? Only a few more weeks.....
Offline Bob Hunt
« Reply #484 on: May 22, 2014, 03:42:11 AM »
Hi PJ:
Well... no, this one will not be at the Nats. I was trying hard to make that deadline, but some unforeseen and amazing circumstances in my work have made it impossible for me to spend the time on this project that I had hoped to.
I have come upon a deal that netted me an incredible amount of balsa wood, plywood, sheet butyrate plastic, fiberglass. music wire, maple, and spruce, and I had to get it transported from where it was to my shop. I have to grade it all out and get it ready to market. It has left me with virtually no time to finish the new twin. I am hoping to have the older "new twin" ready for the Nats as it is much closer to fruition. Sometimes real world issues just take precedence.
Sorry - Bob :-\
Online Larry Renger
« Reply #485 on: May 22, 2014, 08:30:09 AM »
Fly it in primer if you have to, I bet you still get 10 points for appearance! It's beautiful in just carbon veil!
Offline Dean Pappas
« Reply #486 on: May 22, 2014, 08:29:34 PM »
F.R.E.D. shall rise again!  H^^
Dean
Dean Pappas
Robby Hunt
« Reply #487 on: May 22, 2014, 09:12:15 PM »
Dean
I retract my jest. ;)
« Reply #488 on: May 22, 2014, 11:23:17 PM »
Sometimes real world issues arise ?
I got married, and am coming over on a Honeymoon to fly in the Nats - From Australia.. dont tell me you can't get that finished.
PRIORITIZE !!!!!
Im sure you will take your time and have something amazing.
Offline Kerry Ewart
« Reply #489 on: May 24, 2014, 03:21:02 PM »
A twin with retracts,,the limitations are endless I say,,,
Counter rotating props Bob ?????
"If you cannot beat them!JOIN THEM.
Offline Bob Hunt
« Reply #490 on: May 26, 2014, 12:32:09 PM »
Hi Kerry:
Yup; counter-rotating, not contra-rotating... ;D
Wayne: I know you've been wanting to see color on the twin. Well, I've put the new twin on the back burner until after the Nats, but I've continued on with the original twin. It's a bit smaller, but it should be fine. I sprayed on the Chroma Seal coat today. I'll sand it tomorrow and it will be ready for the base white coat by Wednesday.
Later - Bob
Offline Tom Niebuhr
« Reply #491 on: May 27, 2014, 10:09:11 AM »
Bob,
I am confused. What is the difference in the two twins. I know you had a test twin with profile nacelles. Are their two full bodied twins. Am I losing track of all your projects?
AMA 7544
Offline Bob Hunt
« Reply #492 on: May 27, 2014, 11:03:24 AM »
Bob,
Hi Tom:
I don't know if you are losing track of my projects, but I'm pretty sure that I am... :-\
The "new" new twin is just too far out to complete for possible use at the Nats. The "old" new twin is much further along and could be flying in about two weeks if I hustle. I had a major distraction happen in the midst of my Nats push that put everything on the back burner for a couple of weeks. Unavoidable...
I will not ruin the "new" new twin by rushing it; it's just too good for that. As Jackson Browne wrote, "Time is the conqueror." Boy howdy... n~
Later - Bob
Offline Tom Niebuhr
« Reply #493 on: May 27, 2014, 11:58:41 AM »
Bob,
So is there a "Third Wind" which is which???
AMA 7544
Offline Mike Ferguson
« Reply #494 on: May 27, 2014, 12:21:02 PM »
The thread started with the "old new twin" (the Second Wind, which you can see in photos has a built up Lost Foam wing).
The testbed first was mentioned here.
The "New new twin" is the Wildfire (which you can see in photos has a sheeted foam wing.)
Pictures of all three (old new, new new, and testbed) are here.
Offline Bob Hunt
« Reply #495 on: May 27, 2014, 02:18:41 PM »
Egads! Mike's sorted it all out! ;D
Hey Mike, I do believe that you are the one person who might be able to balance my checkbook... %^@
Later - Bob Hunt
« Reply #496 on: May 27, 2014, 10:06:58 PM »
 Nice to see some progress with the finish Bob, hopefully we'll see it all wrapped up and flying soon. #^
« Reply #497 on: June 06, 2014, 07:00:27 AM »
Wow, wow, and wow!!!!.... :D 8) 8) 8)
Marcus
Aces High!
« Reply #498 on: June 06, 2014, 07:59:21 PM »
I just noticed looking at the photo of the twin in Chromaseal that you have in the background exactly what I'm looking for :
I'm in the middle of making the worlds biggest game of monopoly - and I need giant Dice.
Offline Bob Hunt
« Reply #499 on: June 15, 2014, 08:15:31 PM »
I spent Father's Day applying the red trim and a bit of the blue trim. Also got the canopy on. One more long day should do it!
Later - Bob Hunt
