  • June 29, 2025, 08:43:32 PM
Author Topic: New Electric Twin project back on track  (Read 151893 times)
Offline Allan Perret
  • Proverbs
Re: New Electric Twin project back on track
« Reply #150 on: April 27, 2011, 11:22:51 AM »
Thats cool.
What about when you get to the spraying stage,  you gonna set up a special holder ?
Allan Perret
AMA 302406
Slidell, Louisiana
Online Howard Rush
« Reply #151 on: April 27, 2011, 07:41:53 PM »
That is a great idea.  Thanks.
« Reply #152 on: April 27, 2011, 09:31:02 PM »
25 oz...
Im shocked as to how you manage to get it down that low...
I stuggle to get sub 60oz Ships consistantly. - I know what i add in finish, which is normal but WOW 25 oz airframe is incredbile...
Maybe over dinner you can share your tips :) - I look forward. - Back to sanding for me..
Online Howard Rush
« Reply #153 on: May 01, 2011, 11:01:23 PM »
Twins and retracts.  I'm so far behind.
« Reply #154 on: May 02, 2011, 07:14:36 AM »
Twins and retracts
Im so far behind
I paint my plane orange
for the Judges I blind.
Online Tim Wescott
« Reply #155 on: May 02, 2011, 09:27:36 AM »
When the wheels go up
Scores should erupt
But they’ll say I’m a clown
If they don’t come down
If the judges were managing to be completely objective, retracts would only make a difference in as much as they affect the aerodynamics of flight (and if they make it worse -- oops).  I suspect that if you get any points from the "wow" factor, it'll wear off as the judges get used to seeing the wheels go up.
I'm sure you're already thinking about this, but it sure seems that you'd want to think carefully about when you want the gear to go up.  Too soon and the "wow" factor is of entirely the wrong kind.  Too late and you don't get nearly as much "wow" as you'd like.  Just right, from a purely aesthetic point of view, would be to start a slow retract right as the wheels leave the ground -- but that really flirts with 'too soon' if anything delays takeoff.
I'd be concerned with the retracts messing up the airflow when I'm trying to achieve a smooth takeoff and level flight (actually, I'm a rank beginner -- I can't reliably achieve level flight yet, so retracts would just give me something to blame other than myself).  At worst, you could time things so that the wheels went up after your two laps of level flight, but that would certainly remove a lot of the "wow".  At best, any bobbles from the wheels going up would be slow, and could be timed for the climb phase of the takeoff where they'd hopefully get subsumed in the overall climb.
Online Crist Rigotti
« Reply #156 on: May 02, 2011, 10:40:56 AM »
Trust me, Bob will have them go up at precisely the right time, every time.   BW@
Online Howard Rush
« Reply #157 on: May 03, 2011, 10:03:02 PM »
I should introduce you guys.  Bob, meet Tim. Tim, Bob.  Bob is a former US National and World stunt champ.  He also either built a good chunk of our airplanes or taught us how to do it ourselves.  Bob is a good guy.  Tim is an electrical engineer who does motor control systems for a living.  We are learning things from him, too.  Tim is also a good guy.
Online Tim Wescott
« Reply #158 on: May 04, 2011, 01:14:44 AM »
It sure seems that with a wide selection motors and props, that you should be able to get more braking in he down lines.  You may need to go with some combination that's too aggressive at braking when the gear is down.
And I didn't want to say anything that would stop you: I'm just mentioning points that you may have not yet pondered, or have skipped over lightly.
Online Howard Rush
« Reply #159 on: May 04, 2011, 03:52:46 AM »
Since that experience in 1976, Bob pioneered tuned pipes in stunt planes.  Now he's known for having one of the best regulated electric powerplants.  He'll be OK if he doesn't get the polarity on the props and motors mixed up:
motor 1 rotation   motor 2 rotation   prop 1  prop 2  outcome
        L                       L                  L         L         OK
        L                       L                  L         R         bad
        L                       L                  R         L         bad
        L                       L                  R         R         bad
        L                       R                  L         L         bad
        L                       R                  L         R         good
        L                       R                  R         L         bad
        L                       R                  R         R         bad
        R                       L                  L         L         bad
        R                       L                  L         R         bad
        R                       L                  R         L         good
        R                       L                  R         R         bad
        R                       R                  L         L         bad
        R                       R                  L         R         bad
        R                       R                  R         L         bad
        R                       R                  R         R         OK
I wouldn't risk it.
« Last Edit: May 04, 2011, 09:57:22 PM by Howard Rush »
Offline John Witt
« Reply #160 on: May 05, 2011, 12:00:15 AM »
Just feel for breeze in the right direction behind each engine, then let go. <=
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Offline Dean Pappas
« Reply #161 on: May 05, 2011, 07:47:52 AM »
Actually, Bob is just covering up our efforts at creating the first Stealth Heli-Stunter. :!
In a semi-reenactment of Bob and Jim Hunt's efforts back in '76, I created a one-off control system that would control retracts via the lines but without having to insulate them. We called it FRED for Functional Retracts Eliminate Drag.
Right after Toledo in '89, I drove to Werwage's place and we spent 36 almost nonstop hours cutting retrcats into his old Tiger 46 powered Blue Max (really just another USA-1). Cutting Retract wells into an I-beamer was a joy! A few weekends later Bob, Bill and i flew the ship in turbulent air and the results were similarly astounding. We never had runway wind conditions to fly in, and the entire program was put on the back burner before they were available.
Dean P.
Dean Pappas
« Reply #162 on: May 05, 2011, 05:24:18 PM »
I didn't get as much done this weekend as I had hoped to, but I did get the main retract gear mounts made and fit. I made supports from 3/16 inch thick balsa and epoxied them to the sides of the nacelles where the main gear mount plates will reside. Next I cut the mount plates from 1/8-inch birch ply and fit the gear to them and marked the mount holes for drilling. I mounted the blind nuts and cut recesses to clear them in the balsa supports. I'll seal the wood beneath the mount plates with a thin coat of epoxy resin and then glue the mount plates in permanently tomorrow.
The following photos show today's work...
By the way, the holes in the back of the nacelles will be fitted with simulated turboprop exhaust pipes that will serve as air outlets. I think that will look neat!  #^
Later - Bob Hunt
Incredible stuff Bob.  I wonder where stunt would be without the innovators like you.  Thanks for keeping things moving forward, even though it does create a little envy!
Personally I expect great things from your current effort.
Online Howard Rush
« Reply #163 on: May 05, 2011, 06:58:03 PM »
But you know how Bob gets hot when his current effort meets with resistance.
« Reply #164 on: May 05, 2011, 10:18:28 PM »
Come on guys, Bob needs Positive comments, Negative ones dont help.  ;)
I dont blame you Bob, Id want to relax also with all of this verbal battery from your fellow fliers.
You have the capacity to make this project amazing.
Your conduct in staying on track is most admirable.
Phase 1 : Conception
Phase 2 : Build
Now your so close to PHASE 3 - Paint.
I think you might have an un farad vantage flying Second wind
My resistance to post further in this thread has been overcome by my capacitance to reason clearly.
« Reply #165 on: May 11, 2011, 09:45:20 PM »
 Watt's up Bob? ;D
« Reply #166 on: May 12, 2011, 06:41:13 PM »
 Sounds wise to me. y1 How about a pic of the Crossfire?
« Reply #167 on: May 12, 2011, 06:42:36 PM »
Dissapointing... I wonder If its too late for me to refund me airline ticket......
I thought the crossfire was at the same stage of finish?
« Reply #168 on: May 15, 2011, 11:10:44 AM »
Hi Bob,
Bummer, but you know what's best and we all know that not rushing the project at this late stage is best.  It will still be an awesome plane when finished!  And you will have a great deal more time to get it all sorted out before next years NATS, that's for sure.  You should be well settled into the plane by next year.  It would have definitely been a time crunch to get it ready and you probably would not have had much time to really get the trim and other dealings with the set up, etc., really worked out.  Good Luck with the Crossfire!
Online Tim Wescott
« Reply #169 on: May 15, 2011, 12:12:42 PM »
It seems that everybody wants a Motorcycle License to allow them to buy a small and fuel efficient bike for commuting and for errands. That's actually a very bad reason to buy a bike...
I sometimes consider buying a motorcycle for just that reason, then I reflect on the fact that I have totaled not one, but two bicycles by rear-ending cars and I change my mind.
I doubt that I'll make it to the nats before your twin is worn out, so when you get it flying would you please post a movie or two -- maybe one walk-around, and another flying?
« Reply #170 on: May 18, 2011, 02:55:43 AM »
I guess youd run two throttle settings for take-off then ' gear up ' . to keep speed even ?
A rubber Turbo Goose (Gruman) and the P-38 Lockheed run the props opposite to initial logic ,
i.e. std rotation inboard , L.H. outboard .I guess it gives favourable bias on rear stabilisor, when
its set above thrust line .
Now I guess there going to allow timers for Gas Engines , or you guys will need to fly till your
batteries run out . :!, otherwise its not gonna be a ' level playing field . !  <= or we'll all need
to fit electric spark , & throttles .  ~^
Offline PerttiMe
« Reply #171 on: May 18, 2011, 04:37:02 AM »
You need to put a front brake on your bike ... and learn how to use it ;)
There's a reason why cars and motorcycles have bigger brakes in the front  y1
Online john e. holliday
« Reply #172 on: May 20, 2011, 09:37:05 AM »
Bob, I haven't been here for a while.   Looks like it is coming together.  I like your statement of it is not anoter Nobler.   It is a very sleek design.   Now about your side kick,  I going to say the reason he has more hair is that he doesn't think as much as we do. LL~ LL~ Now I know he is going to kick my behind.   Now I need to get in gear on my projects.  Want to get the ISW in the air for VSC 2012. H^^
« Reply #173 on: September 02, 2011, 09:29:07 PM »
 It's been quite a while Bob, what's the latest??? ;D
Offline Dick Pacini
« Reply #174 on: September 03, 2011, 04:09:51 PM »
At the '73 NATS, I was new like a puppy
Bob Hunt was there, flying his Guppy
We both made the finals, but he did much better
I came in last, like an old Irish Setter
AMA 62221
« Reply #175 on: September 26, 2011, 09:56:12 PM »
"I plan on starting on it again sometime later this month (September)"
Well ? Updates... we need updates.....
27 Sept..
« Reply #176 on: July 09, 2012, 09:04:03 PM »
But eventually, you'll finish it. right Bob?
Offline Jason Greer
« Reply #177 on: July 09, 2012, 09:07:34 PM »
The Crossfire refinish looks wonderful!
Will you be in Muncie next week?
Jason
El Dorado, AR
AMA 518858
« Reply #178 on: July 09, 2012, 10:16:28 PM »
Bob,
There's something about a red, white, and blue airplane!  Beautiful job.  All the best with it next week.
Offline Matt Colan
« Reply #179 on: July 09, 2012, 11:02:29 PM »
Looks fantastic Bob!!! Best of luck with it next week at the NATS!
« Reply #180 on: July 10, 2012, 05:57:45 AM »
The Crossfire looks awesome Bob! Very cool paint scheme. I love the look of the nose and rudder.
Derek
  • Proverbs
« Reply #181 on: July 10, 2012, 06:59:38 AM »
Wow, the twin's gear installation is some kind of cool.
The only thing that could top that would be full funcioning gear doors. (but I wouldn't even think about going there).
Hey Bob:
What is the setup of the thrust lines on the twin,  motors and stab relative to the wing ?
Are you going to setup the motors counter-rotation ?    If so, what props are you thinking about ?
Sorry if these have been covered earlier.  If so, let me know and I'll go back and re-read the whole thread.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Tom Niebuhr
« Reply #182 on: July 10, 2012, 08:04:20 AM »
Bob,
Just had to say again that the rebuilt Crossfire is awesome. I am glad that you will be continuing to expand the T-bird's scheme in the future.  Many thanks to Sina Goudarzi from all of us.
Oh.. please don't use the brown, bronze, copper on the twin. I am sure that Sina can help you.
Good flying at the Nats!
AMA 7544
« Reply #183 on: July 10, 2012, 09:03:33 AM »
Now how are we going to know which is Bob's planes?     Really Bob, the scheme looks great.   Have fun at the NATS and don't be too hard on the kids. H^^
« Reply #184 on: July 10, 2012, 09:54:53 AM »
Hey Bob,
I am not sure if it is far more patience or far more insanity. n~ Either way, thank you and see ya soon.
Derek
« Reply #185 on: July 10, 2012, 10:43:57 AM »
Derek, you could learn alot from Bob - those wheel pants came out of his workshop that way the same day the model was painted.
 S?P
« Reply #186 on: July 10, 2012, 11:29:28 AM »
 S?P
Yea yea yea, Mine are painted now   ::)
Derek :)
« Reply #187 on: July 10, 2012, 05:11:19 PM »
HI Brother Bob!
The refinished Crossfire does look awesome.  And the Second Wind is coming along.  I believe it will be very competitive once you work into it.
A thanks from us all for your tireless efforts to make this hobby/sport a better place.  And good luck in Muncie!
Offline James Mills
« Reply #188 on: July 10, 2012, 07:27:47 PM »
Bob,
The Crossfire looks very nice, looking forward to seeing it next week.
James
AMA 491167
« Reply #189 on: July 11, 2012, 10:10:13 PM »
Bob - did you fix that tracking error with the rebuild?
« Reply #190 on: July 12, 2012, 02:47:12 PM »
Glad to hear it, Bob. The new Crossfire paint scheme is awesome. Have fun in Muncie!
« Reply #191 on: July 12, 2012, 05:57:58 PM »
Awesome....
« Reply #192 on: July 12, 2012, 09:42:19 PM »
That Crossfire looks awesome, Bob. I love that canopy shape, a bit like the original Hanson Tipo's.
Really neat, good luck at the Nats.
Chris...
« Reply #193 on: July 12, 2012, 11:17:58 PM »
Randy and I both went through total refinishes..... they are hell.
I wont do it again - and I've done 3 of them.... problem is you *think* it will be easier than it is.. despite doing it before..
« Reply #194 on: September 04, 2012, 08:27:37 AM »
Wow, that's coming along very nice.
« Reply #195 on: September 04, 2012, 08:40:18 AM »
That is awesome.   Start a new trend in electric and leave in in clear or primer. LL~ LL~ LL~
« Reply #196 on: September 04, 2012, 08:46:29 AM »
It's really coming along Brother Bob!  I can't wait to hear your flight reports!
Offline John Cralley
« Reply #197 on: September 04, 2012, 01:54:24 PM »
Hi Bob,
I wonder if you are planning on counter-rotating, two pusher or two tractor props. If you are doing counter-rotation which is going to be which?
Thanks and OH yes it looks awesome so far!
John Cralley
AMA 52183
Central Illinois
« Reply #198 on: September 04, 2012, 05:32:03 PM »
stunning work!!!
« Reply #199 on: September 05, 2012, 04:45:53 AM »
Hurry up and finish it, I want to see that thing fly!!!  :o
Looks awesome Bob.
Derek
