  • June 17, 2025, 09:43:56 AM
Author Topic: Any reason not to use RC standoff mounts?  (Read 827 times)
« on: June 23, 2010, 09:55:30 PM »
I am most of the way through a retro fit on a fuse I was given and the only real way I can get the motor mounted is to use a standoff (cage) still mount - is this a bad idea?  any input would be appreciated
I will try and snap a pic of it tonight to show what I have had to do....
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
Re: Any reason not to use RC standoff mounts?
« Reply #1 on: June 24, 2010, 04:49:59 AM »
Cant think of any reason why not.  I was going to do that when I converted the Vector, but found another way to do it. ie installed a plywood mount between the bearers.
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Dean Pappas
« Reply #2 on: June 24, 2010, 10:11:56 AM »
Hi Wynn,
I have used this approach several times, with "X" shaped plates attached to the motor and simple mild-steel threaded rods rather than standoffs. Blind nuts behind the firewall and washers/nuts in front combined with nuts on both sides of the plate attached to the motor work fine. I have a picture somewhere, but not with me now. I have done this with the motor mounted from the back and with it mounted from the front. I used 6-32 rod with big 3000 Watt motors and 4-40 with smaller stuff. The springiness in torsion never bothered a thing, and the stiffness in the "wobble" direction is good.
I'll go look for pix tonight,
Dean P.
Dean Pappas
Offline Dean Pappas
« Reply #3 on: June 25, 2010, 06:38:11 AM »
I think this explains it.
Dean
Dean Pappas
