  • August 03, 2025, 05:03:05 AM
Author Topic: Another question for Christ Rigotti  (Read 950 times)
Offline petermick
« on: January 13, 2018, 02:17:25 PM »
Hi Christ,
On your Thunderbolt profile it appears that you are using 4-40 bolts placed thru the front motor mount and into the Cobra motor. What are the bolts screwed into? It appears that the bolts are going directly into the motor.  Is this correct or am I missing something?
Peter Mick
Offline John Cralley
Re: Another question for Christ Rigotti
« Reply #1 on: January 13, 2018, 04:54:09 PM »
I don't know what the screws are but they aren't 4 - 40. They will be metric if they go into the motor.
John Cralley
AMA 52183
Central Illinois
Offline Crist Rigotti
« Reply #2 on: January 13, 2018, 07:26:16 PM »
Hi Christ,
Peter Mick
Pete,
Yes they go into the motor.  They are 3mm screws.  Don't get too long of screws because they'll hit the windings and ruin the motor.  I think I used 3 x 8MM screws.
Offline petermick
« Reply #3 on: January 14, 2018, 10:25:22 AM »
Thanks to both of you.  At least I was had the right idea.
Pete
