CLICK HERE--><--CLICK HERE
New Airplane Project
Started by Peter Germann, October 07, 2026, 02:48:13 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Peter Germann
Being currently unable to fly due to vertigo problems I have decided to build a new conventional airplane to bridge the time required to regain my ability to fly. The set of (Corel Draw) drawings is meanwhile ready to go and I thought it might be a good idea to share the basic layout before starting to cut balsa.
Here is a link to my Cloud from which the basic view can be downloaded within 30 days from now.
https://www.mycloud.ch/s/S00AC2C87239B57C46E7E1D637B8FDEB5977FCF135E
Peter Germann
Howard Rush
I hope you overcome your vertigo.  I hear it can be done.
Battery seems to be a bit small.  I suggest a 2800 mA-hr 6-cell battery.
Ken Culbertson
#2
I had a serious case of vertigo in my early 50's.  Even laying down with my eyes shut I could feel the room spinning.  It went away in about 2 weeks with a full recovery in a couple of months.
The weight of your design is good for the area, really good.  but I think you should listen to Howard and go with a 2800 mah battery.  It may be just me but the 3515 (I assume that is what you meant) is a bit light for a 12" prop.  Leave room for a 3520 if you can.  I am using both and the Igor three blade 12-5 used more battery than an APC 12-6 two blade on my 3515 and less on the 3520.
Nice design - Ken
Mark wood
My wife has vestibular vertigo for the last 5 ish weeks She is now able to get around fairly well but still can't drive. I hope yours get better soon.
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
Peter Germann
#4
Thanks for comments
Quote from: Howard Rush on October 07, 2026, 01:18:25 PMBattery seems to be a bit small.  I suggest a 2800 mA-hr 6-cell battery.
A couple of tests (July 2026, before vertigo) with the slightly bigger predecessor Da Capo 25 with Fullymax 6S2200 40C has shown:
BadAss 3515-710, Jeti SPIN 66 ESC, Igor MaxTimer v1.0 (Target throttle 137 Sensitivity +30 Max throttle 200) Igor 12x5N 3bl  0.015 x 64 ft. 64 oz.
Lap Time 5.2
Flight Time: 5:30
Capacity remaining: 18%
Recharge: 1'750 mAh
eCalc Prop Calulation says the in flight (at a middle rpm of 9'000) motor efficiency is in the 80% region and operating with using 85% of the battery capacity will be 5.7 minutes.
Agree Agree x 1 View List
Peter Germann
Peter van de Mortel
That is a nice design.
Glad to read that vertigo doesn't stop you from designing & building.
Does an electrical model require the long nose, as in your design, to get sufficient stability or can the required stability be achieved with (slightly) shorter nose and other means? What is your experience on this subject?
Ken Culbertson
Quote from: Peter Germann on October 08, 2026, 02:38:12 AMThanks for commentsA couple of tests (July 2026, before vertigo) with the slightly bigger predecessor Da Capo 25 with Fullymax 6S2200 40C has shown:
Lap Time 5.2
Flight Time: 5:30
Recharge: 1'750 mAh
QuoteThose are nearly the exact usage I get from a 6s 2800mah 30c Li-ion battery on my 3515-710 using a JETI Spin 44 Pro and a Fiorotti V6 and a BadAss 12-6 prop.
With Igor's prop it is around 1850-1900 mah used.  That tells me that a 2200mah LIPO would work - for you.  So why do we use the larger size and everyone I fly with uses Li-Ion?  With Li-ion you need more "head room" to prevent the battery not having the power to provide the boost you need at the end of the pattern. LIPOs run steady to the end then quit. Li-ions slow down and fade away. Ah, but Li-ion batteries are lighter. The 6s3000mahs we are using now are the same weight +- a few grams as a TP 6s2200.  Then there is heat.  We just had 80+ days with the temperature over 100. Heat is a battery's worst nightmare. And the last, and probably real reason we are use Li-ions of 2800 size is because we already have them and they just don't die. y1
Peter Germann
Quote from: Peter van de Mortel on October 08, 2026, 09:43:29 AMDoes an electrical model require the long nose, as in your design, to get sufficient stability or can the required stability be achieved with (slightly) shorter nose and other means? What is your experience on this subject?
The nose lenght comes from the 6S2200 40C Battery at 324 Gr. being lighter than the 6S2700 30C battery (372 Gr.) used in the Da capo 25.
Since I wish to keep the CG at the same 19% MAC position (200 mm fwd. from the hinge line fwd.) as the 25 version, weight & balance calulations, when done without tail trim weight, have suggested the slightly longer nose of the 26 project. The aiplane may possibly a bit nose heavy which may be compensated by perhaps 20 Gr. in the tail.
Peter Germann
Peter van de Mortel
Quote from: Peter Germann on October 10, 2026, 04:30:54 AMThe nose lenght comes from the 6S2200 40C Battery at 324 Gr. being lighter than the 6S2700 30C battery (372 Gr.) used in the Da capo 25.
That is very clear what your objective is with the extended noselength.
Thank you for the reply and have a speedy recovery from the vertigo problems.
