Electric Stunt => Gettin all AMP'ed up! => Topic started by: John Hammonds on June 08, 2009, 05:19:07 PM
Title: New A123 packs available
Post by: John Hammonds on June 08, 2009, 05:19:07 PM
I know only a few use these but I was wondering if anyone has tried the new breed of Life cells from A123? Nothing to spectacular apparently but they are a few grams lighter with a lower IR. Quality control seems to be much improved also by all accounts with cells being much more closely matched across the board. There is an info pdf here... http://www.battlepack.com/ANR26650M1.pdf
TTFN
John.
Title: Re: New A123 packs available
Post by: Mike Anderson on June 08, 2009, 08:49:35 PM
That .pdf is the one for the original (or at least the oldest) A123 cells (note - copyright 2007).  This is the same cell that I've been using for various electric powered flying since that time.  It may be that 'Battlepack' does some additional cell-matching or something, but mine came from two sources - a DeWalt 36volt pack and directly from the A123 factory as a "Development Kit" and I can't tell any difference from cell to cell.  They are just typical A123's.
Post by: John Hammonds on June 09, 2009, 09:11:34 AM
Ah, well spotted, :-[
I did not notice the date, I just copied the link from the site. They are definitely a new version though, these being shrink wrapped rather the the previous cardboard tubes. Probably why they are a little lighter.
A guy did a quick comparison over on Watt Flyer and found them to be far more consistant than the ones we (I) currently use.
TTFN
John.
Post by: Mike Anderson on June 09, 2009, 01:38:11 PM
I did find an updated data sheet (copyright 2009) for what is called the 26650M1A cell (whereas the 'old' version was the 26650M1 cell) but all the spec's and graphs are the same as the 'old' version, so I don't know what makes the "M1A" any different from the "M1" -
There does seem to be a slighly lower weight with the green plastic wrapped cells - there does seem to be at least anecdotal evidence that the quality control has been tightened up with regard to 'DOA' cells - cells that don't meet spec's when new.  (Speaking of anecdotal evidence, I have a couple dozen A123 cells (28, actually).  One of them blew the safety vent on the very first run after charging normally.  The rest have all lived up to their reputation and spec's.  The one that blew came from a DeWalt pack.)
There doesn't seem to be any evidence that they (the M1A cells) perform any differently than the old cells.
My take is that if you can live with approximately 1 in 20 or 25 failure rate, then you will not notice any great improvement in performance - so if you can get cells for $10 - $12 each you will probably be a few bucks ahead and no performance behind.
That said, the cells from Battlepacks are not much more expensive than buying "new" DeWalt packs off Ebay, in many cases, so one may as well get them from Battlepacks if the implied quality is important.  But I wouldn't throw out my old packs in favor of the green-sleeved ones, just yet.
Post by: Steven Hill on June 16, 2009, 08:05:34 PM
Thanks for linking us.  We are having a sale if you needs cells.  The green cells are better in our opinion.
Here is message from one of our customers http://www.helifreak.com/showthread.php?t=138819&page=2
Hi everyone. Here is the "NEW" A123/M1 review I've been promising you, and for those of you that don't really want to read the entire review I've provided a summary.
Summary: The new (green plastic sleeve) A123 cells available at www.battlepack.com/a123.asp are of a much higher quality build than the older (white cardboard sleeve) A123 cells that we're all used to getting. Their IRs all meet spec., as do their nominal and peak voltages; however, (here is the BIG bonus) out of over 2700 cells obtained and sold through battlepack.com, they have reported that NONE have been found to be substandard/defective vs. 4-5% of the old version A123 cells. These new cells also appear to be a little lighter (by about 2.5g/ea) than the old M1 cells, and also seem (in my opinion) to solder more easily than the old style cells. Am I happy with these new cells? You bet...and I'll be buying more of them.
When I received the new cells from Battlepack.com, I opened the box and was surprised at the apparent quality of the cells. The lime-green plastic shrink wrap that covered the cells, as a replacement for the old familiar while cardboard sleeves, was flawless, professional, and made me immediately think that these cells where of a higher quality than the old ones.
First up, I tested each cell for its shipped voltage level. ALL eight(8) cells were at exactly 3.31v! That in itself made me wonder if my volt meter was working correctly, so I tested each cell again using my iCharger 1010B+ with the same results - 3.31v!!
The next thing I did was get setup for building my new 4s1p packs. Two 6" pieces of Deans 12 gauge wire (Black and Red), a female Deans connector, and three(3) shorter pieces of Deans wire for connecting the cells. All soldered onto the cells using Novak 3% silver solder.
Soldering the negative pole of A123s has never been very difficult, as they seem to take the heat well...but, soldering the positive pole has always taken more effort than I would otherwise like. The positive pole really sucks up the heat from the iron, and I've always been concerned about damaging the cells due to too much heat transfer causing them to overheat. This issue seems to be solved (or at least much improved) with these new cells. The negative and positive poles soldered up easily using my 80 Watt soldering iron, and very little excess heat was transferred into the cells themselves.
Once I'd finished installing the Deans leads, and connecting the 4 cells together in series, I installed a balance connector and then wrapped the new pack. I then repeated the process with the second pack.
Next up was testing Internal Resistance (IR) of the cells, so I connected the packs to my charger and ran the test. The IRs of the eight(8) new cells were: 8, 8, 10, 10, 11, 10, 11, 11. What does that tell me? Well, compared to my old style cardboard sleeved cells that I bought (supposedly new) off of ebay, these cells have lower IR readings. My old cells ranged from 12 to 14. That said, from a functional perspective I don't expect that there is much difference that would be seen...So, for all intents and purposes, I consider my new cells to be of equal IRs to my old style cells.
Next up was charging! I charge all my A123 cells to 3.65v (balanced) on my iCharger 1010B+. If a cell won't take a full charge, I write the max. voltage that it was able to charge to and put it aside (so I can later match it with other cells of the same max. voltage, and build a pack - at least that allows me to get some use out of them).
These new cells were all at 3.31v to start with, so balancing them shouldn't be an issue at all, but for the first charge - what the heck. So, I hooked up my packs and charged them. All of my new celled charged up to 3.65v without any issues. How does that compare to my last eight(8) cells of the old cardboard sleeve variety that I bought off of ebay? Well, of those eight(8) cells, only 5 would charge to 3.65v; two(2) charged to 3.35v; and one(1) cell wouldn't take a charge at all. In short, these new cells appeared to be head-and-shoulders above my old cells.
Now, having only a small number of old and new style cells, I decided to look into the rate of defective/substandard cells of both varieties. What I learned is that the old style cells (white cardboard sleeves) that we've been buying off of ebay or obtaining from DeWalt battery packs have a defect rate of about 4-5%. Further, these cells are the ones that A123 Systems has for R/C and tool uses.
In contrast, the new (green plastic shrink wrap sleeved) cells are not designated for R/C and tool use. They have the exact same specs. as any A123/M1 cell out there; however, they undergo a more stringent quality control process. From what I've learned from Battlepack.com, they haven't found a single defective cell in all of the new cells they've obtained from A123 Systems...and they've sold over 2700 of these new cells. So, even if I argue that 1:3000 of these new cells will be defective, that still leaves a huge gap in quality between the "old" and "new" M1 cells.
One last point I'd like to mention is their weight. I forgot about weighing the individual cells before I started building with them, because I just figured they'd be the typical 70g/ea. give or take a gram or two...BUT, when I weighed my two(2) new packs and compared their weights to my old packs, my new packs were a full 10g lighter! Could it be the difference between the cardboard sleeves vs. plastic shrink wrap, or is it that my soldering job has gotten THAT much better? Well, I don't think it's my soldering job.
Cheers and happy flying.
Post by: Ralph Wenzel (d) on June 16, 2009, 08:43:55 PM
As far as I know, the only significant difference between the M1 and M1A is that the latter has a 20-round magazine . . .
