  • June 21, 2025, 04:39:40 AM
Author Topic: ME - 262  (Read 5348 times)
Offline jjorgensen
ME - 262
« on: September 08, 2013, 04:22:12 PM »
Lost interest for awhile because it got to be a lot of work. Now I'm back in the mood and am getting ready to cover. It will be a twin.
Jim Jorgensen
Offline Doug Moon
Re: ME - 262
« Reply #1 on: September 08, 2013, 09:45:46 PM »
Wow!  That is awesome!
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline John Rist
Re: ME - 262
« Reply #2 on: September 10, 2013, 07:37:20 AM »
I take it that it will an electric scale.  Looks really good.  Should be light.  All my scale projects turned out to be lead sleds.
Looking forward to a flight report.
Offline Michael Boucher
Re: ME - 262
« Reply #3 on: September 13, 2013, 08:21:40 AM »
Well done!  H^^ Is it going to be duct fan or props? Are you going to use the foam engines again?  #^
AMA 59633
Offline jjorgensen
Re: ME - 262
« Reply #4 on: September 13, 2013, 08:31:38 AM »
This one will be props. While duct fans work well for RC versions once they get up to speed, I don't think the current technology gives enough poop for a stunt pattern. The nacelles will be profile with the motors mounted on the inboard sides and they will also serve as main gear mounts.
Jim Jorgensen
Re: ME - 262
« Reply #5 on: September 13, 2013, 09:57:06 AM »
Hi Jim,
That one is at the top of Profile Stunters as far as I am concerned, regardless of how well it actually flies a pattern.  A twin, swept back I-Beam Profile.  Things like this are not seen often.
Great Job!
BIG Bear
RNMM/AMM
Offline jjorgensen
Re: ME - 262
« Reply #6 on: November 17, 2013, 03:41:29 PM »
I'm pretty much done with the paint at this point. Latex and acrylics work really well for electrics. Now its time to start hooking up the hardware. I was considering using folding props with no landing gear, and some sort of launch platform but I think I will go ahead and put the gear on. I don't know if they would even allow a no gear in stunt. I know you can't use a drop off dolly but how about if it launches off of rails?
Jim Jorgensen
Offline MarcusCordeiro
Re: ME - 262
« Reply #7 on: November 17, 2013, 04:25:42 PM »
Wonderful!!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: ME - 262
« Reply #8 on: November 17, 2013, 06:11:24 PM »
Really nice! Kudos!
Great scheme!
Outstanding!
Charles
Re: ME - 262
« Reply #9 on: September 16, 2014, 11:34:05 AM »
Hi James, How is the ME 262 coming along? Please give an update if you have done more with it. Thank you, Mike  #^
AMA 59633
Offline jjorgensen
Re: ME - 262
« Reply #10 on: September 21, 2014, 04:45:54 PM »
Unfortunately the ME 262 bit the dust. It looked great in the air, and had plenty of power. It tended to leap off the ground which should have given me a clue. It did insides fine, but the first time I tried an outside loop it would not pull out before it hit the ground inverted. My guess is it needed a touch of downthrust in both motors. I had the same issue with the single engine version I built but thought I may have inadvertently put the motor mount in with a touch of up thrust. Guess not. Live and learn. Next one will have downthrust from the git go!
Jim Jorgensen
Dwayne
Re: ME - 262
« Reply #11 on: September 22, 2014, 05:27:34 AM »
Very sorry to hear this. Just wondering, where was the motor thrust line on the single, those nacelles looked kinda low.
Offline jjorgensen
Re: ME - 262
« Reply #12 on: September 23, 2014, 10:55:51 AM »
The thrust line on the single was even with the wing chord. The nacelles are low on the twin, but with 8 inch props I was able to get 1/2 inch clearance. I did lengthen both the mains and the nose gear though as I originally only had about a 1/4 inch clearance and flying off grass I would occasionally kick up dirt on takeoff.
Jim Jorgensen
Re: ME - 262
« Reply #13 on: September 23, 2014, 01:28:42 PM »
Hi Jim, I'm sorry to hear about this. Are you going to try it again or take a break from it? Incredible looking model.  H^^
AMA 59633
Offline jjorgensen
Re: ME - 262
« Reply #14 on: September 26, 2014, 01:04:13 PM »
Michael, I will build another one. It is second on the build list after I finish the 52 Nobler on the bench now.
Jim Jorgensen
