Electric Stunt => Gettin all AMP'ed up! => Topic started by: jose modesto on August 03, 2013, 11:05:26 AM
My 2013 Nat's model
SI-PM Saturn Impact PM
model specs, Wing: Impact Foam wing and Flaps
Stab/Elev: Pattern Master 51 spec sheeted Foam
Fuse: My Impact vacuum bagged composite fuse
Electrics:motor Cobra 3520/14 700kv E flite 32
Controller: Castle ice 50
Timer Hubin
Batt: sky lipo 3000 Mah
model weight at home 70.5 Nat's 71.5
Model finished with dope,basecoat auto colors with acrylic lacquer top coat.
Nats story to come.
Jose Modesto
Add Photos
jose Modesto
add photos
I like it Jose.
Front mount motor. That is how I mount my motors. Two retrofits from IC so far but next one built from scratch will have front mount.
How do you like the Cobra? They have three bearings I think.
Linheart
Linheart. This model uses a Bob Hunt mount,the mount is attached to my Impact composite fuse. The front mount eliminated the need for a cowl.(firewall mount) so only one opening for fuse the battery hatch.
the cobra worked real well. I used the motor through first round. For second round I used the Eflite power 32
You should talk to Will Moore about his new plane?
Jose Modesto
Jose Modesto
How did you do? We had to leave early so I didn't get to watch any of the round. I know William and Kevin had a good week. Sorry to hear Sina crashed.
James
