  • July 13, 2025, 06:41:55 PM
Author Topic: My Newest Project  (Read 2968 times)
Offline ericrule
My Newest Project
« on: August 31, 2013, 04:42:56 PM »
Back in the 1990's I designed a profile P40 Warhawk. At the time I did not have a laser machine so I had to come up with something that I could build using a band saw and sand paper. The model became my P40 Profile. Although it flew very well I was never completely satisfied with the looks of the model.
Today I have the use of AutoCAD and a laser machine plus electric power. I have revisited the P40 profile and incorporated some new ideas into the construction. Things like laminated structures Stabilizer incidence and full span gapless hinges.
I intend to power this 624 sq. in. model with one of my KDA 36-10XL motors using the Kr Governor, ZTW 50 Amp ESC and a 4 cell 3300 mAh battery.
Here's what the new Electric P40 Profile will look like.
Eric Rule
Online William DeMauro
Re: My Newest Project
« Reply #1 on: August 31, 2013, 05:21:03 PM »
I always liked P 40's looks good to me!!!
AMA 98010
« Reply #2 on: September 01, 2013, 08:29:39 AM »
I too like P-40's, infact with the tiger  mouth has always been my favorite.   Will this be a package deal with the power package?  There are so many choices these days and this has really caught my eye. #^
Offline ericrule
« Reply #3 on: September 02, 2013, 10:22:32 AM »
Hi Doc:
The new P40 will be offered as a kit (with an I/C conversion included for those who still like "smokies"). We will also offer a complete, bench run and ready to mount ECL power system in either competition or sport level. The difference in the two power packages is the motor. The Competition motor is the Hacker A30-10XL while the sport motor is the KDA 36-10XL. Both of the power packages deliver around 700 watts so the performance with a 12" prop will be rather good.
Eric
Offline Jeff Traxler
  • T-Bone
« Reply #4 on: September 02, 2013, 11:51:13 AM »
Hi Doc:
  Eric,That's hilarious!! LL~ LL~ LL~ LL~ LL~ LL~ LL~ Nice looking ship.When you get the time an E-51 would be nice too.Trax
« Last Edit: September 02, 2013, 01:06:09 PM by Bill Little »
« Reply #5 on: September 02, 2013, 01:07:12 PM »
Hi Jeff,
Eric has a "E-51" already.  It is the ".15" size P-51 that Ron Burn designed.
BIG Bear
RNMM/AMM
  • T-Bone
« Reply #6 on: September 02, 2013, 01:17:39 PM »
Bill,That is a nice little ship.I was just hinting at a big brother for it(or me) to play with.Trax
Offline ericrule
« Reply #7 on: September 04, 2013, 09:52:46 AM »
Hi Trax;
We have already designed an ECL conversion for my P51-D. It's simply a "drop in" to replace the  existing IC mount. Lots of room inside the fuselage for the electric power system and with the low wing saddle you can shove the battery way back to achieve a perfect C/G.
Eric Rule
Offline ericrule
« Reply #8 on: September 20, 2013, 10:40:35 AM »
I made some changes to the way I handled the full span hinges in the flaps on the new P40 Profile Electric.
Here's the plan just about 100% completed. I expect to start cutting the test build kit sometime next week.
All comments & suggestion will be appreciated.
Eric
Offline Guilherme Souza
« Reply #9 on: October 28, 2013, 10:14:48 PM »
Hi Trax;
Eric Rule
Eric
Do you have a convertion system to Oriental Plus ? I still have mine here in new in box
Thank yo u
guil
Offline ericrule
« Reply #10 on: October 30, 2013, 07:19:52 PM »
Hi Guil;
I don't have one right this moment but can certainly run one off for you. Since you are using those "G" motors just send me the measurements so that I can make the drop in box to fit your motor. Give me stuff like: length of motor from back of the stator to the front of the shaft (if you're mounting using a front mount). If a rear mount the let me know the width of the mounting plate. Also need to know the width of the motor.
Eric Rule
Offline Mike Scholtes
« Reply #11 on: October 30, 2013, 08:41:28 PM »
Hi Eric:
I have an O-Plus almost completed (needs only trim colors) build around PA40UL on pipe. Would the E conversion you have in mind work with the as-built motor bearers etc?
Offline ericrule
« Reply #12 on: October 31, 2013, 10:19:21 AM »
Hi Mike:
In order to use the drop in motor box I have designed without any modifications you would have to remove the maple motor mount rails. If you wanted to cut down the box side to allow them to run under the maple rails I see no reason why it wouold not work for you in the O Plus.
Eric Rule
