  • August 02, 2025, 03:18:31 AM
Author Topic: Electric Vector  (Read 2393 times)
Offline Gil Mc Millan
Electric Vector
« on: November 29, 2014, 06:07:05 PM »
Are most people balancing converted "E" Vectors at around three inches back from the leading edge of the center line of the wing like IC Vectors, or is the balance point moved forward?
If it's moved forward, what is the range for electric?
Thanks, Gil
Gil Mc Millan
AMA 914386
Offline John Cralley
Re: Electric Vector
« Reply #1 on: December 02, 2014, 07:31:15 PM »
There are E Vectors listed above in the list your setup sticky thread. I suggest you contact the listers with a PM and ask where they have the CG set for their models.
John Cralley
AMA 52183
Central Illinois
Offline John Tate
Re: Electric Vector
« Reply #2 on: December 04, 2014, 07:31:15 PM »
Gil,
I have two electric Vectors. First one is a glow convert to electric back in 2010. The balanced point on that heavy one is 2-7/8" back from the leading edge. The newer one is right at 3".
On the old one the leadouts were the same as the glow motor due to using a right hand prop. After changing to a left handed prop the leadouts had to be moved up some.
John Tate
Re: Electric Vector
« Reply #3 on: December 05, 2014, 08:46:18 AM »
Thanks John, I haven't flown mine yet, the weather wont give me a break. I'm balanced at 2 & 7/8" back from LE, I guess that's a good starting point.
Being a IC stunt "old timer" but very new to electric, I had thought that maybe the balance point for an E stunt ship was forward of what we typically use with an IC version to compensate for the weight of fuel.
Thanks again, Gil
Gil Mc Millan
AMA 914386
Re: Electric Vector
« Reply #4 on: December 05, 2014, 08:48:21 AM »
Thanks again, Gil
Gil Mc Millan
AMA 914386
