  • August 03, 2025, 11:35:17 PM
Author Topic: About 12 minutes to discharge....  (Read 1059 times)
« on: November 07, 2013, 04:48:57 PM »
It took me a little extra time to find an open field but I got two flights in as the sun set. Discharged two batteries. I would have got three flights in if the soccer people were not out at my first spot. Grrr.
I just have to tell you guys, I like this lectric stuff!! #^
Now go to go test out my new power supplies.
Offline William DeMauro
Re: About 12 minutes to discharge....
« Reply #1 on: November 07, 2013, 05:48:18 PM »
If it's not too late , maybe you have time to cancel your HK order. Once you start using your esp113  you will find you don't have a need for the HK one.
AMA 98010
« Reply #2 on: November 07, 2013, 08:37:11 PM »
Thanks William.
I started using the ESP113 and about 5 mins the power supply shut down. I had to go to the backup laptop brick.  ;)
It took me most of the night by process of trial and error to get it up and running with only one jumper. Anyway it already shipped so will have a backup to the ESP. And my guess is I will be charging more then one battery at a time.  H^^
« Reply #3 on: November 11, 2013, 04:33:18 PM »
FINALLY on electric huh Paul .... good stuff
« Reply #4 on: November 11, 2013, 06:46:26 PM »
Yea Wynn and I like it!
Hey PM me your new email address.
« Reply #5 on: November 11, 2013, 07:53:10 PM »
e-mailed ya
