I'm flying an RD1 electric with an Eflite 15 motor. Its front mounted, as you can see in the picture. The mount is made from stainless steel (the original was aluminum, but I felt I needed more strength). The problem I had was with vibration. I think I hit a resonant frequency with the rpm I wanted to run (10,000-10,500) and the nose shook violently in that range. I decided to add a rear bearing to it, which you can see in the 2nd photo. Its a real simple addition, just a piece of basswood with a 5mm bearing pressed fit into it. I had to move the shaft back 1/8" to engage the bearing, but it works perfectly. No noticeable vibrations at any rpm. I would be a lot happier with a longer motor shaft, so I could get full engagement into the bearing. I was wondering if a shaft from an Eflite 25 (which is about 1/4" longer) could be used in an Eflght 15?
Rick
