  • July 17, 2025, 07:20:54 PM
Author Topic: Mount the motor forwards or backward?  (Read 2576 times)
Offline Matt Brown
« on: July 08, 2017, 06:49:36 PM »
What's the general consensus on mounting?
The last 15 years or so I've been flying RC 3D profiles. Anytime we had a long bell motor (bell longer than diameter) we mounted them forwards or shaft front. The reason was, if they were backplate mounted there was enough flex in the motor assembly that the bell would flex enough that the magnets would rub on the stator during violent maneuvers. Front mounting only flexed the shaft as there was minimal bending loads placed on the bell by the prop. I recall early articles in MA about E stunt and motors needing additional support. I don't recall how they were being mounted though. Just curious if this was some of the same problem.
I'm sitting here more or less ready to assemble my Brodak universal D profile mount for my Fancherish Twister  and can't decide which way to build it. Front mount or backplate style?
Thanks, Matt
Offline John Rist
Re: Mount the motor forwards or backward?
« Reply #1 on: July 08, 2017, 08:58:19 PM »
After reading many post on the Electric Stunt section  I am of of the opinion that front mount is the best, for all of the reasons you stated about 3D aircraft.  I mount my motors using a motor mount by Bob Hunt (G-10 hard noise).  Seems to work with no problem. Go to:
https://stunthanger.com/smf/gettin-all-amp'ed-up!/ringmaster-576-electric/msg303148/#msg303148
and look at post # 20 for how I use Bob's mount in a profile ship.
Offline Target
  • C/L Addict
« Reply #2 on: July 09, 2017, 01:13:52 PM »
The bigger diameter motors  (35 series vs 28 series) seem to help if you rear mount, if you can fit it in the plane. Shouldn't be a big problem on a profile.
Good luck.
Chris
AMA 5956
Offline John Rist
« Reply #3 on: July 09, 2017, 07:04:50 PM »
Good luck.
 In the example above I am mounting a Cobra C-2826/10.  Why would a 35 series be better mounted on the rear?
Offline Target
  • C/L Addict
« Reply #4 on: July 09, 2017, 11:06:39 PM »
Hi,  John.
I'm assuming  that mounting any motor in the front would be better than in the back,  BUT,  if the install requires an aft mounting and a 6oz motor, a fatter diameter shorter motor would be preferable to a smaller diameter longer motor  for the reasons discussed above.
Eric Rule has some laser cut rear bearing boxes that support the aft protruding shaft on front mount installations.  That's taking this idea even one step further....
R,
Chris
Chris
AMA 5956
« Reply #5 on: July 10, 2017, 07:38:54 AM »
Hi Matt
For a Twister size bird you will likely turn a 10" prop and use a 2815 sized motor.  For that size motor & prop there are no compelling motor flex issues to be concerned with.  I think it should boil down to which brand of motor you want to run.  AXI, Cobra, & most Turnigy's are designed to be front mounted and not terribly good at being reversed.  Arrowind, E-Flite, E-max & Scorpions are designed for rear mounting but easily reversible for front mounting.
Probably the best reason for a front mount is that it will let you swap out different sizes & brands of motors with less effect on things like prop position & spinner fit.  Why would you want to do that?  Mostly for CG adjustments - or just out of curiosity!
Offline Matt Brown
« Reply #6 on: July 11, 2017, 08:56:29 AM »
I made the call last night to front mount the motor. I'm using the Universal D mount from Brodak. I wish they'd have left a bit more material in the screw area of the mount. My motor uses the innermost holes one direction and even with a 3mm drill, they broke out barely. An extra 1/16" of material would have been sufficient and if it's in the way, a few sends with sandpaper would clear it out. I did as the instructions suggested with the wider spaced holes and brass spacer/grommet. I made a simple little tool at work to assist in forming the grommets and it worked great. Didn't think to take a pic though.
Can someone recommend a precision prop mount for a 5mm shaft? There are a ton out there but so many have terrible runout.
Thanks, Matt
Offline John Rist
« Reply #7 on: July 11, 2017, 09:59:41 AM »
The Cobra line of prop adapters has worked well for me.  I have used both their set screw and compression type.  Not a problem with either.  The newer Cobra motor shaft are set up for the set screw type.
Offline Target
  • C/L Addict
« Reply #8 on: July 11, 2017, 11:04:03 AM »
I never have liked the set screw type adapters.  I always buy collet style adapters, they seem that by design they have to better centered. But that's just me.  If it runs true,  that's what really matters.
Chris
AMA 5956
