  • July 07, 2025, 05:28:35 PM
Author Topic: motor test question...  (Read 802 times)
Offline jim gilmore
« on: June 23, 2010, 12:31:25 PM »
ok, here's my question.
I know that the electric motors we use run by sending pulsed in sequence to it make it work.
Is there a simple set up that anybody has seen to be able to  test motors ?
Short of buying a transmitter and reciever so i can cycle the motor on and see how it runs through it's power range ?
I though Will hubin haad something but in his newest list i did not see one.
I'm just looking to bench test some motor and battery combo's and get the rpm and make sure they will turn the rpm I need at prop i need first.
Any suggestions ?
Offline Igor Burger
Re: motor test question...
« Reply #1 on: June 23, 2010, 12:37:40 PM »
You can use any "servo tester". It will make you necessary signal in range used by every ESC.
Offline Dean Pappas
« Reply #2 on: June 23, 2010, 02:47:14 PM »
I'll go looking for more sources, but ...
http://www.vexacontrol.com/
and
http://www.caliberhobby.com/auxcir.html
the GWS servo meter/tester is inexpensive and has the necessary display, but I've never played with one myself.
take care,
Dean P.
« Last Edit: June 23, 2010, 03:15:09 PM by Dean Pappas »
Dean Pappas
Offline jim gilmore
« Reply #3 on: June 23, 2010, 03:31:31 PM »
Thnks guys, i figured out which product will has I need, now.I did not see it the first time i looked.
