  • June 27, 2025, 08:28:27 PM
Author Topic: UBEC SBEC?  (Read 1014 times)
Dwayne
UBEC SBEC?
« on: September 16, 2011, 06:30:09 AM »
Hi all, I'm looking at brushless ESC's on line and some have UBEC on them and others have SBEC on them Whats the difference and wich one would I use with a Hubin Fm-2sr timer sold by Brodak.
Thank you
Dwayne
Offline Igor Burger
Re: UBEC SBEC?
« Reply #1 on: September 16, 2011, 06:47:23 AM »
Can you post a link? As far as I know both UBEC and also SBEC are separate units (U stands for universal, S for switching) and they are use with OPTO ESC or for larger power than integrated BEC can supply. If it is so, you have to chosse better ESC with integrated BEC. All our timers use so little power, that you not need to worry about type of BEC, just check voltage, as some timers can be designed for 5V and som BEC can be even for 6-7V.
If you have really UBEC or SBEC intergated ON THE ESC, then again, both will work well, but linerar (non switching) BEC costs less and it is also better because of smooth voltage.
Dwayne
Re: UBEC SBEC?
« Reply #2 on: September 16, 2011, 07:01:52 AM »
Thank you for the reply This is one of them there is a bunch of em but looking more I see they all wiegh at least twice that of a Ice Lite.
Dwayne
http://www.hobbyking.com/hobbyking/store/__11618__Turnigy_AE_45A_Brushless_ESC_.html
Re: UBEC SBEC?
« Reply #3 on: September 16, 2011, 09:47:53 AM »
Hi Dwayne
The FM-2SR timer ONLY works with Castle ICE or Phoenix ESC's in "Set RPM" mode.
Offline Igor Burger
Re: UBEC SBEC?
« Reply #4 on: September 16, 2011, 01:22:33 PM »
It is strange - SBEC and they say linear ... ok, something new for me ... in any case, you not need to worry about name of the BEC (beside some special ESCs with hight voltage 6-7V)
However that ESC does not have governor as far as I understand, it is really better to use something tested in C/L models.
Dwayne
Re: UBEC SBEC?
« Reply #5 on: September 16, 2011, 04:22:03 PM »
Hi Dwayne
Thanks Dennis I thought so, just wanted to check.
Dwayne
Dwayne
Re: UBEC SBEC?
« Reply #6 on: September 16, 2011, 04:22:47 PM »
Thanks Igor I'm going to buy a Ice Lite.
Dwayne
