  • August 05, 2025, 02:36:47 AM
Author Topic: motor stopping  (Read 950 times)
Offline Peter_Jackson
motor stopping
« on: August 27, 2012, 11:26:44 AM »
hi all just starting in electrics
and i have a few queerys ,,,,,,,
one is that the motor stops and restarts 5 seconds before the end of its timed flight
also im using too much battey
the set up is
os motor 750 kv
5s 3000 battieries
ice esc
wills fm9 timer
Offline Crist Rigotti
Re: motor stopping
« Reply #1 on: August 27, 2012, 01:12:27 PM »
the set up is
os motor 750 kv
5s 3000 battieries
ice esc
wills fm9 timer
The 5 second "burp" in normal and it is there to warn the pilot that the motor will stop in 5 seconds.
Need more info on using too much battery question.  How much are you putting back in?  Keeping with the 75 to 80 % rule, you should be keeping the drain on the batteries less than 2300 to 2400mah.
Offline Darkstar1
Re: motor stopping
« Reply #2 on: August 27, 2012, 01:46:16 PM »
Does the motor completely stop or just slows down?
I believe it just slows down. But not so much that it falls out the sky.
Later,
Evolve or get left behind!
Re: motor stopping
« Reply #3 on: August 28, 2012, 02:26:30 AM »
hi
this problem is only on the test bench
it does stop completely ,then starts again
will this change in the air ????
« Last Edit: August 28, 2012, 04:28:37 AM by Peter_Jackson »
Offline Mike Anderson
Re: motor stopping
« Reply #4 on: August 28, 2012, 06:42:04 AM »
Does it stop with or without a propellor?
If you have no propellor and the brake setting (in the ESC) is set to be very aggressive, then I can see the motor stopping completely during the 'warning' burp.
I don't think that the timer is supposed to go to a 'Stop' condition (less than 1.1 msec) but only supposed to slow it to half throttle or so during the warning burp.
Mike@   AMA 10086
Central Iowa
Re: motor stopping
« Reply #5 on: August 28, 2012, 07:40:18 AM »
with a prop on
its all ok in the air <= #^
« Last Edit: August 28, 2012, 10:21:11 AM by Peter_Jackson »
