  • July 07, 2025, 03:55:43 PM
Author Topic: Motor set up for my Strega  (Read 858 times)
Offline Gary Anderson
« on: June 08, 2010, 08:23:41 PM »
Hi guys,
I wanted to share a picture of my set up for electric motor. The angle bracket has two holes, the one closes to the back plate is where my Saito engine hold down bolts where installed. The back hole is for balance, to be sure the motor lines up on the thrust line. I'm using this set up in my Stiletto and it seems to be working very well. The metal back plate acts as a heat sink. I was using a saito 62 in my Strega and darn saito decided to quit doing the overhead eights. No tears the head in landing only broke her in half. The Strega wing is back together and I believe its stronger how than before. The fuse wasn't hurt, all I have to do is glue the wing and fuse back together and away we go. I was going to set the battery under the wing but I believe I need the weight up front. I'm going to box out for the battery and make it just a drop in and fly awhile. Well if nothing else I hope ya get a laugh out of my doings, Gary
« Last Edit: June 08, 2010, 08:48:08 PM by Gary Anderson »
Gary Anderson
Offline John Cralley
Re: Motor set up for my Strega
« Reply #1 on: June 09, 2010, 09:57:26 AM »
Gary,
I don't hear any laughter!! It looks like a very practical way to convert a glow powered plane to electric. I would have probably bored a bunch of other holes in the plate to allow free air flow through and to save a bit of weight (you can still do that). Rest assured that your electric motor will not fink out on you at the most inconvenient time in a pattern (well a least it is a WHOLE lot less likely than with glow power)!!
Photos of the finished conversion please.
John Cralley
AMA 52183
Central Illinois
« Reply #2 on: June 09, 2010, 10:34:12 AM »
Hi John,
You're correct, the mount isn't complete. There will be more holes, just want to get everything mounted and located. I appreciate your input, when I complete the mount I will weigh her. The slot for the wires to travel thru needs more work also. If the wires touch the metal that wouldn't be a very good thing. Its just a clean way to make the change over. Wood is good but is more permanent and there no go back with wood. After you fly with electric you wouldn't want to go back but you just can do, if ya want to, Gary
Gary Anderson
« Reply #3 on: June 09, 2010, 02:39:32 PM »
Gary,
I think you might be better off to go with a round hole for the wires and fit it with a rubber grommet or just split some fuel tubing and slip it over the aluminum edge (you won't be needing the fuel tubing anymore anyway LOL). A bit of Ca would hold the tubing in place.
John Cralley
AMA 52183
Central Illinois
