  • June 16, 2025, 11:00:47 PM
Author Topic: My first Electric CL System - Over the wires power  (Read 1379 times)
Offline Jim Moffatt
« on: November 11, 2009, 04:41:38 PM »
About 10-15 years ago I got started in electric control line with the plane pictured below. Its a Brodak 1/2 A Cosmic Wind kit I built. Brushless motors and LiPos were at least 8 years in the future. The motor is a 7.4 volt speed 400 brushed motor that I rewound with twice the number of turns it came with. Each rewound pole had 60 turns. I got around 6 volts to the plane over something like 18 gage magnet wire from radio shack. Wires were 35' long. Battey power was three 7.4 volt nicad packs carried in my pocket. The plane would fly but not enough power for a wingover so I abandoned the project. Electrics have come a long way since then. Between then and now I flew conventional RC but about 3 years ago I got interested in CL again. I first tried 1/2A size with a handle but just cant spin that fast anymore so I went to the hybrid CL/RC I do now. I have never gotten over the thrill of seeing CL fliers in the local park in the mid 50s when I was a teenager.
« Last Edit: November 14, 2009, 06:59:05 AM by Jim Moffatt »
Offline Robert-Jan
Re: My first Electric CL System - Over the wires power
« Reply #1 on: November 13, 2009, 01:03:46 PM »
A wingover is possible on copper wires. And a little more  ;D
greetings Robert-Jan
Offline TDM
« Reply #2 on: November 13, 2009, 01:16:21 PM »
1986 was the first year that I started to fly CL. And guess what my first trainer plane was also a over the wire electric powered plane. It was made out of corrugated cardboard for a wing with a bit of balsa on the LE and TE a stick for a fuse and a thin balsa rudder. I used a toy motor Mabuchi and in my hand I was holding the batteries inside of a PVC tube with a switch in my handle to turn the motor on and off. It taught me level flight landing and take off.
I almost forgot about it.  8)
Offline Jim Moffatt
« Reply #3 on: November 13, 2009, 04:24:13 PM »
Robert-Jan
That is really excellent work.
How long were the lines and what diameter were they?
What was the motor?
Anymore you can share about your equipment would be very interesting.
Offline Robert-Jan
« Reply #4 on: November 19, 2009, 02:10:38 PM »
The motor is a speed 400. Take the one with the highest voltage I believe 7,2 Volt.
I used 3 batteries in serie 28,8 Volt  >:D
Prop is a gunter prop. You have to drill it a little and glue it. otherwise the prop will fly of or breake at the hub.
The line length is about 9 meters I think.
The big trick is to use a bigger diameter at the handle and a thinner at the plane.
If you calculate were the power drop is it will be in the thinner cable. in this way you can use longer lines.
At the beginning they were to long.
I made a PWM regulation to regulate the power.
It was perfect for the kids also because the can adjust the speed.
Greetings Robert-Jan
Offline Dean Pappas
« Reply #5 on: November 19, 2009, 03:57:38 PM »
Hello Robert,
What material are the cables? Copper, steel? What type of insulation?
Thank you,
Dean P.
Dean Pappas
Offline Robert-Jan
« Reply #6 on: November 20, 2009, 06:01:35 AM »
Copper with enamel isolation like they use in transformers
Steel has to much electrical resistance
Offline Jim Moffatt
« Reply #7 on: November 20, 2009, 04:26:35 PM »
My system used copper magnet wire which is laquer or varnish covered. That is enough insulation for mabye 20 flights but then the wires rubbing on each other in flight wears bare spots. Then its time to replace them or recoat them.
You could possibly use one wire with plastic insulation but it adds weight and air resistance.
If anyone is interested I can go through the voltage drop calculations for different line lengths, US wire gages and current and put the results in a table.
