Electric Stunt => Gettin all AMP'ed up! => Topic started by: Skip Chernoff on January 28, 2017, 06:57:52 PM
I was given a Tacon 4030-400KV electric motor (new) and aTurnigy AE-65A speed controller (new).I was thinking about building a model for Sport Scale at Brodaks this June once I'm finished with my "Stunters" I'd like to build a WWII fighter with retracts and flaps. My question is what size/weight model will this motor and ESC fly? The ESC says it uses 26S batteries.....also what size prop? Any info would be greatly appreciated and gets you a real cheesesteak if ever in Philly......Thanks,PhillySkip
That's a humongous combination -- it's probably capable of flying something much bigger than you'd want to step into a circle with. If you do use it you'll want five or even six cells to get the prop spinning fast enough, and you'll probably not use everything the motor's good for.
I suggest MotoCalc: http://www.motocalc.com/ (http://www.motocalc.com/). I haven't used it for decades, but when I did it was spot on. Scale control line is going to be close to scale RC as far as motor, prop, and battery selection, so you should be on solid ground.
Frankly, if someone gave that stuff to me I'd try to trade it for something one or two sizes smaller, or I'd build a big RC plane for it.
Hobby Partz is a distributor for Tacon. Here's the link to their page for that motor http://www.hobbypartz.com/96m606-bigfoot60-4030-400kv.html
You may learn something poking around there. Supposedly it's the equivalent of a .60 gas engine used the way the RC guys use them. Fairly weighty though - 420 grams is almost a pound.
Tim I'm trying use something that was "free" . Let's remember that it does have a throttle .I could fly at say 1/2 throttle if it's too powerful. Regarding bigger R/C planes I've got a 100" Me109 90 % done ...so I'm not looking for bigger R/C stuff .This plane is "stupid big" and what possessed me to start building it 15 years ago now seems like a joke....never again!
Dave thanks for the link. I just did a little digging and found that FMS has a P51 that used that motor in a 67" model with weight around 9 pounds with retracts and flaps. Seems to me that the "Free Stuff" I got will work for a"typical" WWII fighter in C/L use.....Cool. I've got 4 kits to choose from:
Pica 65" FW190
TF 65" Spitfire
TF 61" Zero
M Kato (vintage) 70" Ki61 Tony
Decisions,decisions.....Thanks,Skip
Hey, I'm not saying don't do it, I'm just saying it's big for the job.
I'd go with one of the radial engine planes -- with the longer-nose planes you'll run the risk of needing lead in the tail; the short-nosed planes will need extra nose weight anyway.
I think you'll want six cells -- that'll be good for about 8000 RPM. More would be better, but if your "26S" really meant two to six you can't go higher. On the minus side, 8000 RPM isn't much, but on the plus side, it'll mean a bigger prop, which will mean it'll look better than the usual toothpick you see on the front of model warbirds, and the motor should be able to run cool while putting out lots of torque.
Hoovie,thanks for that info!
