  • July 16, 2025, 04:18:49 AM
Author Topic: Motor mount  (Read 1514 times)
Offline Jim Dincau
Motor mount
« on: June 25, 2014, 06:03:44 PM »
I am converting a profile model with standard hardwood engine bearers to electric. The motor mounts at the front with 4 screws but they are not in the standard X pattern. I was thinking of making a plate like the attached drawing and mounting it with barrel nuts. Is this a feasible way to do it?
Unless it's crazy, ambitious and delusional, it's not worth our time.
Offline Jim Dincau
Re: Motor mount
« Reply #1 on: June 25, 2014, 07:47:01 PM »
Never mind, the barrel nut reduces the cross section of the engine bearer to almost nothing and the screws are in tension not shear. I will make a u shaped bracket and bolt it through from the sides.
