  • July 09, 2025, 12:16:27 PM
Author Topic: Motor for classic stunt?  (Read 973 times)
« on: September 09, 2011, 11:55:27 AM »
Would this be a good motor for classic stunt?
Re: Motor for classic stunt?
« Reply #1 on: September 09, 2011, 03:02:28 PM »
No, you want to use a Fox .35.
« Reply #2 on: September 09, 2011, 03:34:40 PM »
I think that motor was put into production about the same time the Fox 35 was.
Online Dennis Adamisin
« Reply #3 on: September 09, 2011, 06:30:02 PM »
I think you could use it in OTS - in the sparky class
Offline Allan Perret
  • Proverbs
« Reply #4 on: September 09, 2011, 07:42:57 PM »
You guys crack me up...
 LL~
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Keith Renecle
« Reply #5 on: September 09, 2011, 11:36:46 PM »
It could maybe qualify for the Fox .15 hurl competition! VD~
Keith R
Keith R
Offline Bill Ervin
« Reply #6 on: September 10, 2011, 06:35:53 PM »
You're gonna need a battery of the same vintage, I'd strongly recommend something with a lead-acid chemistry, a 2S1P Volkswagen pack will give you around 12 volts... and plenty of capacity.  You'll have to build super light to make up for the weight penalty of the ~70 lb. pack (CG adjustments should be easy).
Using your motor and the above recommended battery should yield max authenticity points but, once in the air, don't go inverted.  The spilled electrolyte will wreak havoc on your finish, the judges, your helper, onlookers.
