Electric Stunt => Gettin all AMP'ed up! => Topic started by: Tim Wescott on September 09, 2011, 11:55:27 AM
Would this be a good motor for classic stunt?
No, you want to use a Fox .35.
I think that motor was put into production about the same time the Fox 35 was.
I think you could use it in OTS - in the sparky class
You guys crack me up...
LL~
It could maybe qualify for the Fox .15 hurl competition! VD~
Keith R
You're gonna need a battery of the same vintage, I'd strongly recommend something with a lead-acid chemistry, a 2S1P Volkswagen pack will give you around 12 volts... and plenty of capacity. You'll have to build super light to make up for the weight penalty of the ~70 lb. pack (CG adjustments should be easy).
Using your motor and the above recommended battery should yield max authenticity points but, once in the air, don't go inverted. The spilled electrolyte will wreak havoc on your finish, the judges, your helper, onlookers.
