  • June 13, 2025, 10:36:01 PM
Author Topic: 2320 BadAss front mount collar prop drive slipping  (Read 8725 times)
« on: June 17, 2024, 03:44:36 PM »
I have been using a BadAss 2320 820Kv on my Ringmaster front mounted. I have been having some issues with the collar slipping on the motor shaft as I tighten the prop. I am not comfortable with this. I have used the front mount motors for years, this is the first one that won't tighten properly. I looked to switch it to a rear mount but the drive shaft they that Inov8tion provides is like 3mm shaft with a very small drive collar that looks like it is for a small prop not a stunt prop.
Anyone know of a 4mm prop drive collar? I have used a Hyperion HP-ADAP-40XL adaptor. It seems to be a couple thou over and doesn't grip the motor shaft well. Is there is away to roughen up the motor shaft to allow it to grip better?
Best,    DennisT
Re: 2320 BadAss front mount collar prop drive slipping
« Reply #1 on: June 17, 2024, 04:39:55 PM »
Update: I found a 4mm Aluminum Bullet Prop/propeller Adapter Holder that holds well. It has flats cut into the collar/drive for a wrench. I don't know who makes this one any ideas?
Best,    DennisT
« Reply #2 on: June 18, 2024, 12:02:52 AM »
Best,    DennisT
Does it have a small prop shaft, if so the is probably a Great Planes.  1/4-28 shaft could be Spektrum.  I think they both make bullet adapters.  I have been using the Spektrum ones with few issues.  They are difficult to get tightened in a full body with nothing to hold on to.
« Last Edit: June 20, 2024, 08:07:28 PM by Ken Culbertson »
« Reply #3 on: June 20, 2024, 05:25:12 PM »
I like using set screw style adapters on 4mm & 5mm shafts on up to a 3520 motor (so far) they work great and no, they do not vibrate.
Offline Mike Palko
« Reply #4 on: June 21, 2024, 10:48:28 AM »
I've always solved slipping by putting sandpaper washers (320 sandpaper glued back to back) between each surface (prop/spinner and spinner/drive washer).
