So back to using a battery to charge flight batteries at the field. I took some measurements to see if my Costco battery is defective or just too small, hence whether I should return it and invoke my sliding-price warranty. My charger takes 29 amps from the 12V server power supply to put 14 amps into my flight batteries (two 5S batteries both on the constant-current charging phase at 7 amps each). An interesting phenomenon is that the lower the battery voltage goes, the more current the charger takes to deliver 14 amps to the flight batteries (an instability allegedly also seen on airliners and space stations). Charger input current from the Costco battery got up to 32 amps while I was watching, and the voltage to the charger eventually got to the 10V cutoff. This was on the first pair of flight batteries I charged after filling up the Costco battery. I have a fuse in the circuit, the current-measuring shunt, and an extension cord so I can leave the battery in the car while getting the charger far enough away from the car that I can still get home if a battery blows. All this claptrap was causing a 2V drop from battery to charger. I think the lesson is that hooking the charger directly to the 12V battery, although inelegant, is probably the way to go.
