  • July 16, 2025, 02:54:16 AM
Author Topic: More Good News for ECL Pilots! New TP Batteries and Charger  (Read 3728 times)
Offline Rudy Taube
  • Ret Flyboy
« on: January 08, 2011, 03:17:18 AM »
The following good news came at a good time today. It is part of my attempt to offset the terrible negitive CL Karma created by the thoroughly discouraging, and mean spirited thread on the open forum. I feel I need to escape to the forward thinking, open minded, kind hearted, positive ion people here in the ECL area before I run away from CL screaming with a strange desire to click my heals together!  n~
I had a long talk with my friends at the TP booth at the AMA EXPO today. Here are some of the highlights:
NEW BATTERIES FROM THUNDER POWER
Many of us use the excellent batteries from Thunder Power and Hyperion. In ECL we only need a 20C rated battery so the TP Pro Lite series has been perfect for our ECL use, they are the lightest batteries available and now their price is very reasonable after their drastic price cut last year.
Now these batteries are even better. The latest version is the G4 Pro Lite V2 20C. It can be safely charged at a 4C rate (a 4,000 mAh can be charged at a 16 amp rate) This means that we can have our batteries charged in around 15 minutes! These new models also offer more cycles. They are now getting around 300+ cycles with these new batteries. For those of you who are really in a hurry all the time, and will pay any price to save some TIME, TP has a new battery that can be charged at 12C! Yes, that is not a typo:  12C. That means a charge time of around 5 to 6 minutes!!! BUT, this is a 45C battery and costs almost twice as much, and is heavier. Both of these batteries require a very good "balancing" charger with at least 250 Watts of charging power.
BTW: They, and their web site states: "DO NOT USE ANY TUNIGY CHARGER AT HIGHER THAN A 1C CHARGING RATE, it is unsafe to do so"! This leads us to the subject below.
NEW TP CHARGER
This is the charger we all have been waiting for. The NEW TP820CD. It is a dual port, 800 Watts total, 20 amps for each port, full feature balancing charger. It is the charger you need if you want to use the new high charge rate batteries to their fullest. We can now safely balance charge two 4S or 5S 4 amp ECL batteries at the same time, in just 15 minutes! The price for all this is only $269 (less at the EXPO). This will also need a very powerful, 40+ AMP 12V power supply. They have one available for only $200, I think it's output is measured in KiloWatts and they were using it to power the nearby Ontario Air Port ILS system!  ;) It was BIG, and it will run many chargers at once.
BTW, the 1st shipment of the new charger was sold out before they arrived from the mfg. The second shipment, set to arrive early Feb, is already 90% sold out. So if you want one, you may want to call your LHS ASAP to order one.  y1
More details with photos in the next PAMPA SN E-Stunt column.  :)
I hope this 2nd bit of good news helps move the CL Karma account in a "much needed" positive direction?
Regards,  H^^
« Last Edit: January 14, 2011, 11:55:02 PM by Rudy Taube »
Rudy
AMA 1667
Offline William DeMauro
Re: More Good News for ECL Pilots! New TP Batteries and Charger
« Reply #1 on: January 08, 2011, 07:21:28 AM »
Rudy,
   This is a topic I've been thinking of bringing up for quite a while as I have been charging my hyperions at 3+C since last year. My average charge time has been 15 minutes or less. Battery and charger technology has been moving very fast. The only reason I haven't brought this up is that I didn't want somebody charging the wrong type of battery at high speed and starting a fire because of something I wrote. It is also important that one uses good chargers as you want to accurately balance these packs at the same time. I have been using the I chargers 206B and the I charger 306B which is good for 30 amps and 1000 watts!! I have also been trying out a FMA powerlab 8 which is good for 40 amps and 1000 watts. There is a ton written on these chargers over in the RC Groups forums battery and charger section.
  On a whole other topic, to run these and similar chargers requires a power supply that that supplies lots of power. I am using a 24 Volt 57 amp supply. I've run all 3 chargers at the same time at 3C with plenty so spare . I'm at work now and will post some pictures later of this setup when I get home if people want to see this setup. By the way these power supplies can be setup for under $40 if one can do a little reading and soldering. 12volt 57 amps can be done for around $20.
AMA 98010
« Reply #2 on: January 08, 2011, 08:40:00 AM »
All sounds terrific - 15 minutes? takes me that long to wipe off the latent electrons between flights! :o  >:D
The new PLUS packs from Arrowind are also touting 5C charge & 300 cycles - that's longer than the expected life betwen ring jobs on a ST-46!  8)
WILL - definietly interested in info on those power supplies
The times truly are a-changing!
Offline Tim Stagg
« Reply #3 on: January 08, 2011, 09:32:54 AM »
William,
I saw your handy work with the power supply's at Bob's a few months ago and I am definitely interested in building at least the smaller system. My question to you is at the field, can the charger your using support the 3-5C charge on a pack.
If you remember we have a charging station at our field running off of 6 large deep cycle Marine batteries hooked to solar panels to recharge the batteries. It is great that we can charge that fast at home with a power supply, but when I may not have access to that many AMPS at our field, can I still get that 15 minute charge rate?? (PS: I need to see how many amps we do have available, not sure)
Thanks, I can wait to see your instructions and place to order that HP power supply.
Tim
Tim Stagg
Online Howard Rush
« Reply #4 on: January 08, 2011, 10:00:04 AM »
William,
I look forward to pictures of your rig.
This electricity is scary.  Has anybody written up the precautions we should take in putting together battery and charger systems?  I could imagine monitor circuits, idiot-proof connectors, fuses, arc-fault circuit breakers, and that sort of thing (not that I don't have five gallons of nitro in my fuel shed).
Offline Rudy Taube
  • Ret Flyboy
« Reply #5 on: January 08, 2011, 01:24:41 PM »
William,
I am very glad to see that there is another person out there with the same "charger addiction" that I have!  :)
I collect chargers like my wife collects shoes. This new TP charger will be my 11th charger. I don't know what the reason is, my wife can't explain her addiction either?
 Like you, I like the iCharger series, I use both of mine a lot. At under $100 they may be the best bang for the buck out there. The FMAs are also good chargers. Hyperion now makes a nice TWO port (ability to charge two batteries at the same time) balancing charger. We are very lucky to have the market place so rich in good quality chargers. With all the RC pattern guys going to electric with their 10S-5,000 packs, and much larger E Helicopters, we will continue to see more powerful chargers in the future.
I assume the power supplies you are using are converted PC power supplies? A few of the engineers at our E flying field have these and they seem to work just fine for our use. The $200 TP power supply is big and it looks like it came out of an IBM-AS-400, or at least a large file server? They had one being used over in the electric flight section at the EXPO. It had more than 8 chargers connected to it and they were all working all the time. I like the idea of yours at <$40.  :)
Rudy
AMA 1667
Offline Rudy Taube
  • Ret Flyboy
« Reply #6 on: January 08, 2011, 01:36:36 PM »
William,
Tim
Hi Tim,
We have a similar setup at our field. None of us have ever had any problems. We sometimes have over 10 chargers working at the same time. Your 6 Marine batteries hooked up in parallel should have more than enough amps to handle even the new dual port chargers at the 4C+ rate. At the risk of sounding like a real "tree hugger", I think it is so cool that we are actually flying with PV solar power!  8)
Rudy
AMA 1667
Offline Rudy Taube
  • Ret Flyboy
« Reply #7 on: January 08, 2011, 02:21:24 PM »
William,
Howard brings up a very good point. And William also alluded to it in his post.
Talking among ourselves is one thing, but here on the forum everyone is listing. And the people reading vary from experienced electrical engineers to those who don't know an electron from a Berilium Sphere. There are many who read a post without having read the many that came before it, so there is a high risk of a statement being taken out of context. Like William cautioned, someone could think ".... oh, this is great, now I can charge all my batteries at this new 4C rate ....." or "..... gee, now I can use my cheap $29 Turnigy charger at this 4C rate....."   This would be a disaster!    To help prevent any of our discussion being taken out of context, here are some clear requests:
PLEASE: DO NOT CHARGE YOUR BATTERIES AT MORE THAN A 1C RATE UNLESS THEY ARE QUALITY BATTERIES THAT SHOW ON THE PACK THAT THEY ARE RATED FOR 4C CHARGING.
PLEASE: DO NOT CHARGE YOUR BATTERIES AT MORE THAN A 1C RATE UNLESS YOU ARE USING A QUALITY CHARGER RATED FOR THE 4C, OR ABOVE, CHARGING RATE
PLEASE: DO NOT CHARGE YOUR BATTERIES AT MORE THAN A 1C RATE UNLESS YOU ARE USING A QUALITY "BALLANCING" CHARGER. THE BALLANCING FEATURE MUST ALWAYS BE USED WHEN CHARGING AT RATES ABOVE 1C.
The good news is that all the quality chargers come with excellent instructions, both on operation and safety. The iChargers come with a disc that has a ton of useful information and safety precautions on it. As long as one reads these clear instructions there should be no problems with safety. Like Howard says ..... we all used to have nitro in our homes (Howard just has more than most!;-) and we are still safe about its use and treatment.
Howard, I am very glad you brought up this important point about safety. We are very lucky today that all the modern quality chargers have many safety features built into them. As long as we all use balancing chargers, with the batteries balancer plug plugged into the charger every time, then the charger will SHUT DOWN itself if there is any problem at all. A thermal probe is also a good idea, and many quality chargers have them as an added safety feature. Most of the chargers have a memory feature that allows you to set up your charging preferences for a certain size battery and then assign it a #. This way you just push #x and the charger will automatically start the correct sequence every time. This is a great safety feature that prevents human error when we are in a hurry and make mistakes. To use your very appropriate phrase; it helps make them "idiot proof"  ;)
As I have said many times before, E power is NOT for everyone. Those that have an aversion to reading instructions, and a "devil may care" attitude about their sports and hobbies, should not be flying with E power. If someone has a CF prop on their wet plane and still flips it with their finger, then they may be better off not flying with e power.
As William has stated there is a wealth of information on our chargers and their use, on the RC forums. They are worth reading.
Now, to the football playoffs .... Go CHARGERS! ... well, I guy can dream can't he?  LL~
Rudy
AMA 1667
Offline Tim Stagg
« Reply #8 on: January 08, 2011, 03:06:26 PM »
Thanks for the info Rudy, I am thinking about purchasing one of the I-chargers as well. William demonstrated them at Bob's place a couple of months ago.
I can not take credit for our Clubs charging station, our president is a very progressive electric RC flyer so the whole club benefits from his love of gadgetry. I was actually not in favor of the station at first because there were not many in the club flying RC electric stuff any more... but two years forward, I am really glad he did not listen to the naysayers. H^^
It has been a great addition to our field.
Tim Stagg
« Reply #9 on: January 08, 2011, 03:09:16 PM »
I've done allot of reading on this stuff over on RC Groups battery and charger section. This is a sticky right on top http://www.rcgroups.com/forums/showthread.php?t=1292514. What I am doing is converting surplus server power supplies for our use. These are very stable and designed to run 24/7 so chances are that we will never ever kill one. My power supply of choice is Compaq HP ESP114 Series 12V 55A Power Supply. These are cheap, powerful, plentiful, and extremely easy to convert. This is the thread http://www.rcgroups.com/forums/showthread.php?t=1170784#post14001273 If converting them isn't your thing then a guy called feathermerchant will do the conversion for you but you still have to add your own wires.  http://www.feathermerchantrc.com/ . I have his 12v 47amp supply. That was purchased before I figured out how to make my own. If someone wants to take it off my hands PM me as it is now an extra. I'll post a few pictures the one with the 3 chargers is staged as it was easier for me to shoot on my livingroom floor. If you google the 57 amp by part number 192147-001 or 002 or spare number 192201-001 or 002. The 002's seem to be later and cheaper. I have gotten mine for between $15 and $18 and that includes the shipping!!! The price does seam to vary on a daily basis by a few dollars. Mine came from server supply co. http://www.serversupply.com/products/part_search/query.asp Today I happen to get a $20 price using 192147-002 in the search. Hope this helps some of you!!! PLEASE PLEASE BE VERY CAREFUL IF YOU CHARGE OVER 1C. LIKE I SAID EARLIER AND OTHERS HAVE SAID. MAKE SURE YOU HAVE A GOOD CHARGER AND BATTERIES RATED FOR FAST CHARGING!!!! I have been doing this for a while but have been reluctant to post because of the saftey concerns that I have. IF you set up a 24V be twice as careful. Make sure your charger can handle it. The info is out there,some of it is questionable.Its on RCGroups. I won't promote that here!!!
« Last Edit: January 08, 2011, 04:12:09 PM by William DeMauro »
AMA 98010
Online Howard Rush
« Reply #10 on: January 08, 2011, 03:17:17 PM »
I'm worried about doing something stupid and shorting out some high-amp doodad.  The sparks I got from cutting the wire to the lights when snipping a limb off the Christmas tree yesterday weren't a big deal, but got me thinking about electricity.  Then I saw Rudy's mention of King Kong amperes.  I don't think I can be trusted without building in some protections.
« Reply #11 on: January 08, 2011, 03:36:32 PM »
Howard,
Once you set it up its like any other power supply. Just attach your charger and plug it in. There are many safety percations discussed in that thread. As you have read that is my biggest concern. I was not going to be the first to bring this up for just those reasons. Once Rudy opened the door I felt like I should post what I know and what I have done.
AMA 98010
Online Howard Rush
« Reply #12 on: January 08, 2011, 03:59:03 PM »
Go CHARGERS! ..
Is this some football thing, or just your continuing cheerleading for electric stuff?
« Reply #13 on: January 08, 2011, 04:04:50 PM »
Dennis, Most of us DO NOT treat our batteries properly!!!!! If you want those 300 cycles then we should all read this page over on RCGroups http://www.rcgroups.com/forums/showthread.php?t=1051482&page=67#post15307087 Pay special attention to what Nippon Dave and Everyday flyer say!!!!
AMA 98010
Offline Rudy Taube
  • Ret Flyboy
« Reply #14 on: January 08, 2011, 08:04:07 PM »
Hi Howard,
Good one. ..... I wish I could tell you that it was a plan, but I never even thought of that angle when I wrote it, but I should have. I was just lamenting the fact that my SD Chargers were on vacation this year.  :'(  ..... BTW: congratulations on your Seahawaks amazing upset!  :)
Rudy
AMA 1667
« Reply #15 on: January 08, 2011, 11:43:51 PM »
Hi Rudy,
Thanks so much for your help in these areas.  It is sincerely appreciated.  While Aaron and I are officially in the electric arena, it is at the entry level now, and that's fine for us where we are at now.
The highly competitive stuff will come, I hope since it will be an advantage to have silent flight at most of the ball fields we get to fly at.  Whether or not "I" will completely switch to ECL is up in the air, so to speak. ;D  There really seems to be a difference in opinion of "affordable" hobby items in different areas of the country.  And I ain't singing the blues here, but $469 for a charger and power source is definitely not in any part of my hobby budget for anytime soon.  I would really have a seizure over the prices BEFORE the "drastic price cut".  Of course, I could knock off some liquor stores...........  or make some "refreshments" for profit........  Seriously, I hope that while I can still turn in circles that these components follow the trend of all the other electronic consumer products, price wise, like personal computers have over the past two decades.
A perfect condition, "super zoot", IC engine can actually be bought used for a really low price if in the right place at the right time, but I see no such market for electric stuff.
I think I will really like ECL, but affording it will be another story, altogether.  No criticism of anyone or anybody, just a premise for discussion, possibly. ??
Big Bear
Offline Rudy Taube
  • Ret Flyboy
« Reply #16 on: January 09, 2011, 12:41:08 AM »
Hi Bill,
My pleasure. I'm glad you brought up this important subject of costs. I should have been more clear in my post. This "high ZOOT" equipment is NOT needed to fly CL using E power. I was only pointing out what is available for those that really (emotionally) NEED to have their batteries charged in the shortest possible time, and get pleasure from "high Zoot" stuff, and have a need to be on the "bleeding" edge of technology! It's kind of like paying extra for the "Gold" edition of the Saito 4 Stroke engines. It is not needed, but some just have to have it. ;-) With that said, for a top CLPA competitor who is flying 8 flights at each practice, and flies a few times+ every week, then this dual port charger is actually very cost effective because chargers are less expensive than extra batteries if you put in a lot of flights each flying session and you don't have the time to wait a few extra minutes. But for the vast majority of CL pilots they do not need this feature.
All most people really NEED is the iCharger and one of the very good $20 power supplies that William showed us in his photos. Total cost for both = $100. This setup will allow you to charge your batteries in 30 minutes, and that is more than fast enough. And this setup will last a long time. I have LiPo-Ion chargers that have made many hundreds of charges and are now 8 years old, and still going strong.
In my humble and very biased opinion: The day will come when CLPA will be dominated by E power, then those that have not yet sold their wet engines will find that the price for them will be very very low. This has already happened in the RC world, and my guess is that it is beginning to happen in the CL world too.
Thanks again for pointing this out. I always try to keep in mind that there is a wide spectrum of flyers out there reading these posts. And I need to make sure that I clarify what is really needed, as apposed to what is "nice to have", but not really necessary. I am a big fan of buying quality equipment as it is more reliable and usually more cost effective over the long run. But this is different from buying the bigger unit with more bells and whistles that are not really needed by everyone(like the new TP charger), or the unit that is more convenient but is not more quality.
« Last Edit: January 09, 2011, 12:02:06 PM by Rudy Taube »
Rudy
AMA 1667
Offline Russell Bond
  • Bandolero
« Reply #17 on: January 09, 2011, 05:39:23 AM »
Quote ... "In my humble and very biased opinion: The day will come when CLPA will be dominated by E power, then those that have not yet sold their wet engines will find that the price for them will be very very low. This has already happened in the RC world, and my guess is that it is beginning to happen in the CL world too."
I agree 100% with you Rudy, electric will certainly dominate "Stunt" within a few years and agree that glow motors will almost become worthless except for collector units for Classic or Vintage for example.
I just sold both of my PA75 models, complete with motors, lines and handle, all ready to fly. I worked out that I would NEVER fly them again after being "pampered" by my electric models.... ;D
Bandolero
« Reply #18 on: January 09, 2011, 07:20:44 AM »
Bill,
Rudy said it very well. The reason I suggested those power supplies is because they are as good or better than any other ones out there for a fraction of the cost!!!! If bought new those supplies probably cost between $300-400. We just get to take advantage of another industry's surplus or outdated stuff, that happens to work for us.Even if you use a totally budget charger and go buy a budget powersupply to run it you will pay at least $20 for the budget supply after shipping in most cases. These will run the budget chargers as well as the highest of the high end chargers just as good. Why would anyone buy something else? Most of us flying ECL can solder!!! Most of us can build our own models and know how to read instructions(I hope). As far as the chargers go, I see "High end"(whatever that is,since it varies according to the individual) chargers (hyperion duo,cellpro 10, i chargers, shulze) for sale in the "for sale" sections of the RC forums all the time.This is usually at a fraction of their original cost. The chargers,batteries,speedcontrols,motors and even allot of the props we use were originally developed first for RC use. They had it first. There is a wealth of knowledge on those forums if we dare go there. Their "rejects" can save us a ton of money!!!!! I would never buy a Castle speed controller "new" any more. Just in the last 6 months, I've picked up an new ICE 50 for$50,new Phoenix35 for $35, and a lightly used Phoenix 45 for $40. The deals on good stuff are out there if you know where to look and are patient. I will almost guaranty you that you will not even find this stuff for sale yet on controline boards!!!
Rudy and Russel, I think many of us have already waited too long to sell our wet stuff. I couldn't sell one motor at the last swap meet i attended and i don't believe anything I have was overpriced. I even had some NIB stuff!!
AMA 98010
« Reply #19 on: January 09, 2011, 09:03:43 AM »
Hi William and Rudy,
Thanks for your replies!
Don't get me wrong, wehn i am serious about flying CLPA, I want the best equipment there is.  Like Aaron says, I don't want my equipment to bet me! LOL!!
I did want to point  out that to a raw beginner in ECL, "printed" costs can sometimes be overwhelming.  In my personal experience, the "start up costs" can be more than any other aspect of the stunt hobby IMHO.  And I fly PA engines with pipes right now (when I do get to compete anymore), equipment that "appears" to be very costly.
I am not disputing the advantages of ECL.  The learning curve goes beyond the simple learning of terminology of the components, or even how to fly them! LL~
William, Aaron has forwarded me the "power source" communications", and we appreciate it.  "Making the parts" is not a problem, and it is very affordable, thanks!
I know that the people on this forum will answer my questions, though, and that is a huge positive!
Thanks, again,
« Reply #20 on: January 09, 2011, 11:13:20 AM »
Bill,
Originally I wasn't going to put the stuff I sent Aaron out here. But one this thread started I felt I had no choice. I very much believe the the printed cost for some of this stuff is outrageous and people that don't do their research can end up paying way more than they should for this stuff. My goal from the beginning has been to show that with a little research one can buy good ECL stuff at better prices than most people think. There are things that I feel shouldn't be compromised on. Sometimes more money needs to be spent up front to save money in the long run. I've used the lowest of the low end stuff, all the way to the shulzie Plett stuff.I have a pretty good idea of what works and what doesn't. I will say that even the low stuff works better than my glow stuff ever did and my glow stuff worked great!!! I already learned the hard way with some of this stuff. I also don't like to spend one penny more than I have to anymore. Done right this is cheeper than glow!!
AMA 98010
Offline Andrew Borgogna
  • Andy
« Reply #21 on: January 14, 2011, 02:23:55 PM »
OK Rudy I did a Google search on DC power supplies and I quickly learned they are very expensive.  Do any of you know of a place where supplies can be had for the "non wealthy" in the world?
Andy
Andrew B. Borgogna
Offline Rudy Taube
  • Ret Flyboy
« Reply #22 on: January 14, 2011, 03:50:59 PM »
Hi Andy,
Did you get a chance to see Willam's excellent post #9 below? With your electronic skills it should be very easy for you to safely build one from a Computer PS. Several of my ERC buddies have built these and they work great. Like William said, you can make a real powerful one for low $. They are a little bulky compared to my iCare smaller/lighter unit, but this is only a minor inconvenience at the flying field, but at home it is no problem at all. Because they are meant to be inside the computers protective outer cover, they do not have any protection from stuff dropping inside and causing problems, but this can be easily mitigated.
I'm very glad William posted this PS info, and especially his making it clear to be VERY CAREFUL if you build one. Experienced people like you know how to do it safely, but inexperienced people may want to buy one of the "pre-built" conversions or an iCare PS.
BTW: I hope you guys are enjoying the power and nice table over at the car track at WN. It makes ECL very convenient. I have to remember to thank those guys some day. I left two ceramic tiles under the table for everyone to use under your batteries for safe charging on the wooden table. Maybe someday we will get solar panels like we have at the basin ECL field.  8)
Regards,  H^^
Rudy
Rudy
AMA 1667
« Reply #23 on: January 14, 2011, 03:59:40 PM »
Andrew,
 Your best bet is to convert a server power supply. the easiest one to convert is the Compaq HP ESP114 Series 12V 55A Power Supply. All the links needed are provided in my post#9 above. These can be had for around $20 from server supply and this includes free shipping. If you don't want to convert one Feathermerchant.com has them for around $50. Rudy posted while I was writing this but there are a few smaller ones in the RC group thread on these. I only suggested these because they are the easiest,cheapest and most plentiful.
AMA 98010
