  • July 18, 2025, 02:30:16 AM
Author Topic: Max charging voltage  (Read 892 times)
Offline JordanSegal
« on: September 01, 2017, 09:22:09 PM »
I understand it's better to charge to 4.1V rather than 4.2V for longer battery life.  How do I set up my icharger 106 b+ to only charge to 4.1V?
Offline Fred Underwood
Re: Max charging voltage
« Reply #1 on: September 01, 2017, 09:44:38 PM »
How to charge to 4.1 volts is here under settings
https://www.progressiverc.com/media/iCharger%20106B+%20Manual.pdf
In very short form, find settings using the buttons and scroll to lipo termination voltage.  If you hold the R button down, the voltage will blink and then you can increase or decrease.
Whether to terminate charge at 4.1 volts is another matter.  The question will be whether you have enough capacity to charge to only about 4.1 and then fly a full flight and not go below 20%.  Going to low can harm the battery and shorten life.
Fred
352575
Offline Target
  • C/L Addict
« Reply #2 on: September 02, 2017, 10:20:46 AM »
Or just buy a newer "HV" 4.35v/cell battery and charge it to 4.2v/cell....
Chris
AMA 5956
Offline pmackenzie
  • Pat MacKenzie
« Reply #3 on: September 02, 2017, 02:44:30 PM »
Some higher end chargers( like the iCharger) let you adjust the termination voltage, but many others don't.
With almost all "4 button" chargers you can get 4.1 volt termination by selecting LiIon as the battery type.
Charge method is the same (Constant current then constant voltage) for all lithium types.
Pat MacKenzie
MAAC 8177
