  • July 12, 2025, 08:55:48 PM
Author Topic: Mah question. How much?  (Read 1947 times)
« on: November 20, 2014, 10:29:10 AM »
Ok guys sorry if this has been asked before but I did a search and came up dry.
How do I tell how many mAH I put back in during charge?
Offline Mike Anderson
Re: Mah question. How much?
« Reply #1 on: November 20, 2014, 11:06:20 AM »
Most chargers display the running total and hold that display until you reset it.  What charger are you using?
Mike@   AMA 10086
Central Iowa
Online Motorman
« Reply #2 on: November 20, 2014, 06:26:14 PM »
Should have a number and a time, read the number before you press stop. If your battery puffs up over the winter you put back too many.
Online Tim Wescott
« Reply #3 on: November 20, 2014, 10:05:20 PM »
LiPo chargers stop automatically.  It's one of those things that you just have to do to keep the battery healthy.
« Reply #4 on: November 22, 2014, 08:40:25 AM »
It's a Turnigy. I will watch  the display next time.
Thanks guys.
Online Motorman
« Reply #5 on: November 22, 2014, 09:33:13 PM »
Yes, they stop automatically and display the charge time and mah put in but once you press stop it clears the display.
I only fully charge after flying if I'm setting up a system or making changes, after that I go right to storage charge after flying. Don't want to work the battery unnecessarily. You only get X number of charge/discharge on those things.
Right now I'm only using 71% capacity for the full pattern +3 laps but thinking of adding a few more laps. Don't want to miscount then crap out in the clover leaf.
