  • August 02, 2025, 04:18:17 AM
Author Topic: MAH question  (Read 1572 times)
Offline RC Storick
MAH question
« on: September 27, 2013, 07:53:29 AM »
I am currently using the TP 5S 2700 25C MAH battery. I have noticed I am only using 945 MA from the battery. Should or could I use a smaller battery? Also is there one that's smaller and lighter?
Offline Doug Moon
Re: MAH question
« Reply #1 on: September 27, 2013, 08:13:47 AM »
Thats the average over how many flights?
How long is your timer set for?
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline Crist Rigotti
Re: MAH question
« Reply #2 on: September 27, 2013, 08:20:06 AM »
I'm sure you are using more than 945mah for a full flight.  Recheck how you got to the 945mah number.
Offline RC Storick
Re: MAH question
« Reply #3 on: September 27, 2013, 08:25:14 AM »
That's what I am putting back into the battery
5min 30 seconds flight time and this is the average over the life of the plane.
65% left after each flight
Offline Dean Pappas
Re: MAH question
« Reply #4 on: September 27, 2013, 08:33:19 AM »
Hi Sparky,
I kinda doubt that's all you are consuming as well, but if this is really the case, you could have much better performance up top and in turbulence by finding enough prop to use maybe 60% of your battery.
That would mean either more diameter, more blade width or 3 or 4 blades.
Can you borrow a different charger for comparison purposes?
Dean
Dean Pappas
Offline Larry Renger
Re: MAH question
« Reply #5 on: September 27, 2013, 08:36:12 AM »
Either you have discovered better than 100% efficiency, have a defective charger, or are flying a 1/2A size model.
My 1/2As use about 750 mAh, the .15 size P-51 about 1900 mAh. Their batteries are 850 mAh and 2200 mAh respectively.
I suggest some troubleshooting of your measurements.
Offline RC Storick
Re: MAH question
« Reply #6 on: September 27, 2013, 10:57:48 AM »
Hi Sparky,
Dean
I am reading it with my battery meter and then the charger and they both agree.
James_Mynes
Re: MAH question
« Reply #7 on: September 27, 2013, 11:04:13 AM »
5s, 18 volts. Maybe he is getting flights with low amp draw.
Offline Dan Bregar
  • Field Marshall
Re: MAH question
« Reply #8 on: September 27, 2013, 11:15:49 AM »
1945 mah would be more like it !  ;D
AMA 33676
Offline John Cralley
Re: MAH question
« Reply #9 on: September 27, 2013, 11:33:26 AM »
If that is REALLY all you are  using, than there is plenty of room to switch to a smaller battery.
However, like the other "Doubting Thomases" that posted above, I find it hard to believe that 945 mah is all you are using!!! That figure would mean that you are ONLY pulling about 10+ amps using your setup!!!
Do recheck with a different charger. A quick and dirty check would be to put a watt meter (or an appropriate amp meter) between your battery and the ESC and read the static amp value you pull. You can then divide the amps by .06 and multiply by 5.5 to get the static drain for your flight time.
John Cralley
AMA 52183
Central Illinois
Re: MAH question
« Reply #10 on: September 27, 2013, 12:23:43 PM »
If he's flying one of the planes he's written about, it's in the 50-ish ounce range.  That ought to work out to more than 20 amps.
A real quick and dirty check would be to try flying on a 5S 1200 mAh pack -- if you can find one, and if you dare stunting.
John's method will cough up the maximum expected power draw, not the power draw during normal flight.  But it should get you in the ballpark.
Re: MAH question
« Reply #11 on: September 27, 2013, 01:51:34 PM »
What prop are you using?
Offline Dan Bregar
  • Field Marshall
Re: MAH question
« Reply #12 on: October 06, 2013, 01:56:07 PM »
So Robert, what did you find out about your MAH usage  querry ?  Some of us would like to know what your secret formula is for ultra low battery consumption ?  ;)
AMA 33676
