  • June 18, 2025, 10:53:41 PM
Author Topic: Will Hubin Phone number  (Read 861 times)
Offline Leo Mehl
« on: August 17, 2013, 10:15:40 AM »
Does anyone have will Hubins phone number. I bought a programmer from him and only used it once and now am trying to get it to work but it won't go to the program after turning it on Thanks HB~> HB~>
Re: Will Hubin Phone number
« Reply #1 on: August 17, 2013, 10:50:46 AM »
Maybe send him a PM and ask?  He's on Stunthanger, so you should be able to look him up in the member's list.
Offline William DeMauro
« Reply #2 on: August 17, 2013, 11:01:33 AM »
Leo,
1) With the prog box off plug the timer in.
2)Press and hold the start button on the timer and turn the prog box on while the start button is depressed.
3) If nothing else is wrong it should now program.
4) If that doesn't work then contact Will
AMA 98010
Offline John Cralley
« Reply #3 on: August 18, 2013, 07:27:30 AM »
Note: You must turn the programmer off before you unplug the timer or the timer will not save the input that you have programmed into the timer. Don't ask.
Further note: If you leave the programmer on for a day or so, you will be installing a new 9 volt battery to make it work again.
John Cralley
AMA 52183
Central Illinois
