Electric Stunt => Gettin all AMP'ed up! => Topic started by: Alan Resinger on January 08, 2012, 06:18:02 PM
I'm using an E-flite motor that is front mounted. To get the nose shape the way I want required the motor to set back approx. 3/4" behind the nose ring. The standard E-flite collet that fits the 5mm shaft and has a 1/4"-28 prop shaft isn't long enough. I need something that gives about 3/8" of so more length while retaining the 1/4" - 28 shaft. Any ideas?
you could try the scorpion one with the 45mm long shaft and put a packer/washer behind the prop
I was going to suggest finding a longer shaft for the motor, perhaps thats your best option, I have not seen a longer collet assembly
Have you tried loosening the shaft set screws and pushing the shaft further forward? thats what I did with mine.
Pete,
I've got it pushed through as far as I can get it. I might look for a longer shaft as I had thought of that.
Alan
Try Tru-Turn
Look at E-cubed adapters. Radical RC carries them. :)
Dan
http://www.gobrushless.com/shop/index.php?app=ccp0&ns=prodshow&ref=PROP-ADAPTER5mmXL
I got mine here.
Linheart
Lee Machine Shop (see vendor section) can probably fix you up. Lee could make an aluminum screw-on extinction that would move the prop thrust washer forward as well as extend the prop thread. Use lock-tite to lock it in place.
Lee has done some work for me - he is good and reasonably priced.
PS it may require modifying the original adaptor- contact Lee he can work it out.
Locally, you may want to ask Mike Haverly , he has the knowledge and equip to machine one .
did u ever get your exstended adapter
Bob,
I got a longer adapter from gobrushless that filled the bill. It has a 6mm X 1mm shaft as opposed to a 1/4" x 28 but I had Jim Lee make some special nuts that were half threaded for the metric shaft and with 1/4" x 28 so that I could still use an Aero Products spinner.
Alan
