  • May 30, 2025, 05:40:08 PM
Author Topic: List Your Set Up...  (Read 203196 times)
Offline Crist Rigotti
List Your Set Up...
« on: March 29, 2009, 09:07:31 PM »
We lost this important thread in "The Crash".  So lets start over and list your set ups.  Like airplane, wing area, flying weight, motor, battery, timer, prop, line length (eye to eye), flight time, rpm, lap speed, and mah used.  In the "Subject" line list the airplane name, then list your set up in the main area.
Barnstormer
« Reply #1 on: March 29, 2009, 09:10:54 PM »
Barnstormer
470 sq-in
32 ounces
Scorpion 3014-22
Rhino 4S 1550mah
Castle Phoenix 35A
JMP-2
APC-E 11x5.5
52 feet
4:40
9200 rpm
4.9 sec
900mah
« Last Edit: June 14, 2009, 07:07:09 AM by Crist Rigotti »
Primary Force
« Reply #2 on: March 29, 2009, 09:14:00 PM »
Primary Force
500 sq-in
38 1/2 oz
Scorpion 3020-16
Gadex 4S 2200mah
Castle Phoenix 35A
JMP-2
APC-E 13x4 cut down and repitched to a 12x5
58 feet
5:45
9500rpm
5.2 sec
1850mah
« Last Edit: June 14, 2009, 07:07:37 AM by Crist Rigotti »
Alan Hahn
Arf Nobler
« Reply #3 on: March 29, 2009, 09:17:07 PM »
Arf Nobler
Wing area=?
Flying Weight=44oz
Scorpion 3020-16 (kV=880rpm/volt--hand-wound) (5.4oz)
FMA 4s2100 18C Lipo (7.3oz)
Castle Creation Phoenix 35A ESC
JMP-2 timer
APC TE 12-6   stock
60 foot eyelet-to eyelet lines
Flight time 300 s (does not include 20 wait after arming the timer)
7950 rpm
lap speed 5.0-5.1s
1560-1600 mAHr put back in according to charger
Whew!
« Last Edit: March 30, 2009, 01:55:08 PM by Alan Hahn »
Alan Hahn
Brodak Electric SuperClown Arf
« Reply #4 on: March 29, 2009, 09:37:06 PM »
Brodak Electric Super Clown
Wing area=355 sq in
Flying Weight=28 oz
Scorpion 3020-12 (kV=1088rpm/volt--stock) (5.4oz)
FMA 3s2100 18C Lipo (5.5oz)
JMP-2 timer
APC TE 10-7 stock
58 foot 0.012" eyelet-to eyelet lines
Flight time 300 s (does not include 20 wait after arm the timer)
8500 rpm
lap speed 4.8s
~1560-1600 mAHr put back in according to charger
« Last Edit: May 27, 2009, 11:06:41 AM by Alan Hahn »
Online William DeMauro
Arf Cardinal
« Reply #5 on: March 30, 2009, 07:15:00 AM »
Flying weight=low to mid 50's
atlas 2921-08 =I believe about 1100 KV
polyquest or trueRC 4s 4000mah
Pheonix 45
Will Hubin timer
APC 12x6E cut to 11.5(for clearance)
61' eye to eye
Lap 5.1-5.2
2300 back in pack
9000 rpm Set RPM Mode
Time=5min 30sec
AMA 98010
E SV11
« Reply #6 on: March 30, 2009, 07:25:41 AM »
Flying weight=60-62 oz(I need a better scale)
Scorpion 3026-10 980 KV
Phoenix 45
Will Hubin Timer
APC 12x6E
64' eye to eye
9300 rpm Set RPM mode
Polyquest or true RC 4s 4000 or FlightMax 4s 4400
Time=5min 30 sec
Back in pack=unknown
This plane is still not flown these are my starting points
Flying weight=64oz
Scorpion SII-3026-890 V2 Brushless Motor(now)
Phoenix 45
Will Hubin Timer
APC12x6EP
65' eye to eye
Polyquest RC 4s 4250 or FlightMax 4s 4400
Time=5min 33 sec
Back in pack=2800mah
This is what I am flying with as of 7/23/09
« Last Edit: July 23, 2009, 07:28:20 PM by William DeMauro »
AMA 98010
ARF P40
« Reply #7 on: March 30, 2009, 07:29:43 AM »
Scorpion 3020-14 944 KV
Phoenix 45
Will Hubin timer
APC 12x6E
61' eye to eye
Lap 5.1-5.2
2300 back in pack
Time=5min 30sec
AMA 98010
Offline Rob Roberts
Brodak Shark 402
« Reply #8 on: March 30, 2009, 02:27:21 PM »
Flying weight 33oz
wing area 402 sq inches
Welgard  GH2814-06 1400kv
GraysonPower 4000mAh 11.1V 15C
Phoenix 35
ztron timer
apc 9x6e
60' eye to eye .012
Offline Rob Roberts
« Reply #9 on: March 30, 2009, 02:38:35 PM »
Flying weight 32 oz
Wing area 355 sq in
stock Brodak motor
stock Brodak battery
Phoenix 35
ztron timer
apc 9x4.5e
60' eye to eye .012
Offline Paul Walker
Impact xls
« Reply #10 on: March 31, 2009, 01:30:40 PM »
Impact XLS
750 in^2
69 ounces
Plettenburg 30-12
Thunder power 5S2P4200 brick pack
Kim Doherty Processor
Shultzie 18.46 F2B ESC
Yatchenko knock off Carbon prop  13.6" * ~7" (some parts of the prop are at more than 7, some less than 7)
Flying Speed  ~ 5.3 to 5.4 sec/lap
RPM: ~8650
Line length 70 feet.
Uses ~ 3000 mah per flight
Flight time 6:13.
 Now flies much better than it flew at the 2007 Team Trials.
It would be a definite contender at any contest.  Now if only the wing would have come off, it would have gone to France!  Ugh... :(
Offline Archie Adamisin
Re: List Your Set Up...
« Reply #11 on: April 01, 2009, 10:12:57 AM »
Brodak Oriental ARF
Area 550 sq in
Weight 47 oz
Motor Brodak SC 1500Kv Out-runner
Battery Brodak 15C 3S 4000
2500 mAH used on average
Castle Phoenix 35 ESC
Will Hublin FM-2 Timer
Prop APC 10 x 5 "E"
Rpm 10,920
Lap time 5.15-5.2
Line Length 63' eye to eye
flight time 5:15
This was the Set-up flown @ FCM Last year.
Archie Adamisin
Burlington, KY
« Reply #12 on: April 01, 2009, 10:18:07 AM »
Brodak Oriental ARF
Area 550 sq in
Weight 49 oz
2700 mAH used on average
ESC Kontronik 3SL40-6-18
Timer JMP-2
Prop APC 10 x 5 "E"
Rpm 11,100
Lap time 5.15-5.2
flight time 5:25
This was the Set-up flown @ Brodak Last year.
Archie Adamisin
Burlington, KY
« Reply #13 on: April 01, 2009, 10:22:38 AM »
Brodak Oriental ARF
Area 550 sq in
Weight 50 oz
Motor Rim-Fire 35-36-1200
Battery Maxx-Amps 20C 4S 3000
1750 mAH used on average
Castle Phoenix 60 ESC
JMP-2 timer
Prop APC 10 x 5 "E"
Rpm 11,050
Lap time 5.15-5.2
flight time 5:30
This was a test for my Uncle Dennis' Swinger.
Archie Adamisin
Burlington, KY
« Reply #14 on: April 01, 2009, 10:28:25 AM »
Brodak Oriental ARF
Area 550 sq in
Weight 48 oz
Motor Rim-Fire 35-30-1250
Battery Maxx Amps 20C 4S 3000
JMP-2 Timer
Prop APC 10 x 5 "E"
Rpm 10,980
Lap time 5.15-5.2
flight time 5:30
This was a test for a lighter system for the Swinger and some other Classic 35 sized models we had in mind.
Archie Adamisin
Burlington, KY
« Reply #15 on: April 01, 2009, 10:32:26 AM »
Brodak Vector 40 ARF
Area 536 sq in
Weight 48 oz
2400 mAH used on average
Prop APC 10 x 5 "E"
Rpm 10,920
Lap time 5.15-5.2
flight time 5:15
Archie Adamisin
Burlington, KY
« Reply #16 on: April 01, 2009, 01:05:39 PM »
Big Art's EP Yo-Yo OTS
Area 425 sq in ??
Weight 48 oz
Motor Astro Cobalt 15G (brushed) :o
Battery 14 cell KR700 NiCad pack
ESC Toggle switch
Timer (see above)
Prop APC 10 x 8 Sport
Rpm All it had  LL~
Lap time 5.0 - 5.2
Line Length 60' eye to eye
flight time 3:30 useable, 4:30 to touchdown.
This was the set-up flown @ the 1990 Vincennes NATS unofficially.
Archie Adamisin
Burlington, KY
« Reply #17 on: May 27, 2009, 03:19:09 PM »
Excitation - 600" sq
weight   59oz
Motor   AXI 2826-10  front mounted
prop  APC E 12x6 Pusher
RPM      9000
battery Tenegy 4S1P 3850 mah
Average use  2650 mahs
ESC   CC 45 - fixed RPM mode
Timer ZTron II
Flt time   5 min: 20 sec
lines  68'  C to C
Lap time  5.2 sec
Offline John Witt
Midwest Panther
« Reply #18 on: May 27, 2009, 04:06:08 PM »
Scratch built Midwest Panther
52" span, 475 sq in, 47 oz
E-Flite Power 46 motor -- motor changed to Rimfire 35-48-1000 6/20/09
Thunder Power TP2250-4sp30 pack (4S2P)@14.5V nominal
CC Phoenix 45 ESC med gain governor mode -- changed to RPM mode @9500 RPM
Ztron timer set for 100% output
Currently APC 11-7 2 blade prop -- changed to 11-5.5 APC with new motor
65', .015 7 strand lines, 5.2 sec laps
Using about 1750 mAh in 5 minutes
Latest mods as of 9/20/09
Turnigy C3548 800 kV motor
APC 12-6 prop
Zetron timer with the following settings: Start speed and end speed set to 50% (25 on the dipswitch binary sum)
CC Phx 45 ESC set to SET RPM mode at 8500 RPM for all three bands
63 ft x .015 lines.
Zippy 2650 mAh batteries for 6 min flight (2050 mAh used)
Latest changes as of 8/20/10
Turnigy C3548-1100 kV motor
APC 11-4.5 EP
ESC changed to High Gov at 11180, 5.4 sec laps on 64 ft lines
Hubin FM-9 timer, 5 min 55 sec run time.
« Last Edit: August 24, 2010, 05:22:15 PM by John Witt »
John Witt
AMA 19892
Edmonds, WA
"Houston, Tranquillity Base here. The Eagle has landed."
Mythbuster
« Reply #19 on: June 05, 2009, 06:14:51 PM »
MYTHBUSTER! (original design)
63" span, 567 squares, I-Beam, 15% airfoil,
fuselage is stringered behind wing, 47" nose to tail
44 oz
Originally Rimfire 35-36-1200, switched to Turnigy SK 35-42-1000 for nose weight (1 oz heavier) and better match of kV to lower RPM required
4Sx2500 Evo-lite battery (about 8.5 oz.)
Castle Phoenix 35 in CL Set RPM mode
Will Hubin FM-4 timer with remote switch
63' (eyelet to eyelet) lines
test flown with 10x5 APC-E prop at 10,900 rpm; 5.0 sec laps, 1840 mah used
Switched to 11x5.5 APC-E prop, 9200 RPM, 5.2 sec lap time, about 1850-1950 mah (avg.).
Updated 8/18:
Now running 9000 RPM and using roughly 1700-1800 mah.   Run time about 5:45 (could be shortened)
« Last Edit: August 18, 2009, 06:57:35 AM by Dennis Adamisin »
Hellcat
« Reply #20 on: June 06, 2009, 07:25:19 PM »
Brodak Hellcat (profile)
53" span, 540 sq in, approx 42 oz
Motor: Astro Inrunner with Superbox gear drive (3.3 ratio)
Phoenix 60 ESC
Rhino 4S x 2350 pack
11 x 5.5 APC-E
63' lines (eye to eye)  Approx 5.6 lap time
1840 mah over 5:45
Works very well, albeit nosier than the normal outrunner...
Offline Will Moore
Nobler
« Reply #21 on: June 07, 2009, 10:01:35 AM »
Top Flight Nobler ARF  - First electric flown in the North East , at the Lee MA contest - 2003
Motor                    AXI 28-26-10
Battery                  Thunder Power 2 / 3 cell 2100mamp
ESC                        Jeti 30 amp
Throttle control      Z-Tron infra  red
Prop    Aero Naut  carbon   10 / 6
« Last Edit: September 13, 2019, 06:05:55 AM by Will Moore »
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
 AMA # 209
Offline Will Moore
Cavalier 650
« Reply #22 on: June 07, 2009, 10:34:31 AM »
Cavalier - 650   Tom Morris design
Wing Area               650
RTF weight              60 ounces
Motor                      AXI 28-26-10
Battery                    4cell/ 4200 mamp LiPo
Timer/sequencer       JMP 1st to 3rd generation
ESC                         Phoenix 40 amp
Prop                         Carbon 3 blade bolly  10 / 6-8
 AMA # 209
Offline Robertc
« Reply #23 on: June 07, 2009, 10:49:25 AM »
Desperado - 635 sq in
Weight - 53 oz
Motor - Axi 2826/10
Prop APC 12-6e
Ave battery use 2300 mah
ESC   Phoenix 45
Timer   Ztron 2
Lines 63' eyelet to eyelet
Lap time 5.2 sec
Robert Compton
Offline Will Moore
Gieseke Nobler
« Reply #24 on: June 07, 2009, 10:53:10 AM »
Geiseke Nobler - from plans
UltraCote covering with Tamiya enamel
Motor        AXI 28-26-10
Prop            various
Battery        Thunder Power 4cell 4000 mamp
Timer/seq.     JMP 3rd gen
ESC -            Jeti
First electric to place first in a Classic event, in New England
 AMA # 209
Offline Will Moore
Twin - motor fighter/Bomber
« Reply #25 on: June 07, 2009, 11:18:29 AM »
Twin powered bomber / fighter - imaginary
Scratch - built, based on Dave Cook "Lightning" wing , all else educated guesswork.
64" Span,    approx 740 sq.in wing area including flaps
Motors           2 ea.     Hacker A30 series outrunners,  counter rotating
Prop               APC 12/6   tractor / pusher
ESC          2 ea  Jeti Spin 30 amp
Battery           4 cell / 5350 mAh Evo Lite LiPo
RTF  weight        70 ounces
Timer/seq.         1 ea.  JMP
First twin electric in competition on East Coast
 AMA # 209
« Reply #26 on: June 14, 2009, 07:12:04 AM »
Resolve EP
570 sq in
51 ounces
Scorpion II 3020-890
PolyNoOne 4S2P 20C 3400mah battery
Castle Phoenix 45A ESC
JMP-2 timer
APCE 13x6.5P modified to 12.5x4P
63 feet eye to eye
5:58
9050 rpm
5.2 lap
@ 2400mah used
« Last Edit: August 20, 2009, 08:41:17 PM by Crist Rigotti »
Offline andreas johansson
  • SWE-56998
« Reply #27 on: June 24, 2009, 10:06:14 AM »
My Noblarf setup:
Model: Top-Flite Nobler ARF
Wing Area: 500 sq in
Weight: 45 oz
Motor: Turnigy 35-48 900kv
Battery: Flight-Max 2200mAh
ESC: Castle Creations Phoenix 35
Timer: own
Prop: APC 12 x 6 "E"
Rpm: 8400
Lap time: 4.9-5.0
Line Length: 60' eye to eye
flight time: 5:15
Battery drain: about 1700mAh
/Andreas
« Last Edit: July 16, 2009, 01:49:14 AM by Andreas »
Nobler-O-Maniac
SWE 56998
Alan Hahn
« Reply #28 on: June 24, 2009, 01:44:46 PM »
e-Vector 40 ARC
Brodak Vector 40 ARC
Wing Area 536 sq in
Weight  46-47 oz (depends on spinner I am using)
Motor--Scorpion II 3020-780 (kV=780 rpm/volt)
Battery--FMA 4s2100 mAHr (18C)  weight 6.9oz!
ESC --CC Phoenix 45, running in Set RPM Governor mode, 26kHz PWM rate, low motor timing
         7600 rpm takeoff, 8000 rpm flying
Timer---W.Hubin for setup (flight time, rpm changes are easy), JMP-2 for "standard" pattern flying. 300s flight time
Prop---what else? APC 12-6 thin electric tractor.
Lap Time (currently) 5.1-5.2 s     This and next two lines updated (but not the data from the recorder).
Line length: 61 foot eyelet to eyelet.
Battery drain <=1450 mAHr depending on wind.
Today's Pattern flight data recorder:
« Last Edit: August 17, 2009, 09:49:27 PM by Alan Hahn »
Offline Jason Greer
Omega
« Reply #29 on: August 24, 2009, 01:41:42 PM »
wingspan: 53"
weight: 43 ounces
area: 575 sq"
motor:  scorpion 3020 890
esc: phoenix 35
timer: hubin fm-2a
battery: 4s thunder power 2600 prolite v2
prop:  apc 12x6e tractor
rpm: 8400
lap time: 5.3
lines: 64' .012 solids
flight time:  5:30 using about 1640 mah
« Last Edit: August 28, 2009, 07:26:39 AM by Jason Greer »
El Dorado, AR
AMA 518858
Offline walterbro
  • walter brownell
Blue angel Classic
« Reply #30 on: September 23, 2009, 10:38:18 AM »
    Blue Angel
    608 sq in
    60 oz.RTF
    AXI 2826/10
    TP prolite V2 4s3900mah (12.8 oz)
    CC45 -High Gov. mode
    Zigras V.4 field adjustable RPM
    12'x6'' APC EP (Cut down to 11.8"dia)
    Lines .015" x 65' C to C
    4.9 to 5.1 sec Lap times
    8800 to 9000 RPM Range used
    2350 -2550 Mah used
    Flight Time 5:40
    Walt Brownell
Offline Jim Moffatt
Brodak 1/2A Baby Clown ARF
« Reply #31 on: October 21, 2009, 06:33:54 PM »
Wingspan 25 1/4", area 136 sq-in
Weight 10.5 oz
Motor: BP Hobbies 2212-13 Outruner, Kv=1000
ESC: BP Hobbies 20 amp helicopter, in governor mode
Timer: timer replaced by RC throttle control
Battery: Hyperion 3rd generation 3S 850 mah LiPo
Prop: APC 8x8 thin Electric
Line length 40' eye to eye
Lap time 3.7 sec at 7,500 rpm
Static power at 7,500 rpm approximately 150 watts
Flight time: 4 min to keep battery usage to 80%.
Setup will also do 4.3 sec laps on 50' line for 3 min.
The photo shows it with a slightly longer 2217 motor.
« Last Edit: January 18, 2010, 03:56:13 PM by Jim Moffatt »
Pathfinder 1/2A
« Reply #32 on: November 10, 2009, 03:01:21 PM »
Brodak Kit, 34" span, 236 squares
Profile fuselage 27" OAL
16 oz
NOTE: THis is the prototype for a new "10" sized system from Brodak.
> Arrowind 2210-25 kv=1560
> APC-E 7x5 Pusher prop
> Arrowind 3Sx1600 (20C) battery (123g/4.4 oz.)
> Arrowind 18A ESC (non governing
> Will Hubin FM-0c timer with "throttle up" capability
> .008 x 50' (eyelet to eyelet) lines
Currently flying approx 4.2 sec lap time (want to slow it to 4.4) and using 970 - 1000 mah in roughly 5:10,  this bird flies extremely well.
For Arrowind products see: http://arrowindhobby.com/
« Last Edit: November 26, 2009, 05:42:38 PM by Dennis Adamisin »
Offline John Witt
« Reply #33 on: November 10, 2009, 04:10:05 PM »
Vector 40
Built from Brodak kit. 47 oz
Turnigy 3548-800 motor -- now a different motor, Rimfire 3538-1000kV 14 poles
800 kV, 14 poles. (measured to be 749 kV)
Zippy 2650 4P battery
Ztron timer
Castle Creations ICE 50A controller, set rpm at 9600
Initial flights with MAS 10-7 three blade prop -- changed to 10.5-6 cut down 12-6 @ 9100 RPM
Now using 11.7-4.5 pusher, a cut down 13-4.5P
Set RPM mode, 5.2 sec laps
1900 mAh in 340 sec run
Ultracote cover and Lustrecote paint on the balsa.
No trim paint yet
63 ft lines, eye to eye
Changed motor to Turnigy 3548-1100 kV
Hubin FM-9 timer
APC 11-4.5 EP prop at 11100 rpm, high gov mode in the ESC
5.4 sec laps, 64 ft lines
2100 mAh in 5 min 55 sec run through the pattern.
« Last Edit: August 24, 2010, 05:27:07 PM by John Witt »
John Witt
AMA 19892
Edmonds, WA
Offline John Sunderland
« Reply #34 on: November 11, 2009, 06:51:29 PM »
Vector 40
800 kV, 14 poles.
Ztron timer
No trim paint yet
63 ft lines, eye to eye, shooting for 5.2 sec laps
This is the first under the cowl shot I have seen that was purpose built for E power. Tell me about your doublers etc?
Offline John Witt
« Reply #35 on: November 11, 2009, 07:33:57 PM »
Reply with more info in Rudy's motor mount thread.
John Witt
AMA 19892
Edmonds, WA
Offline John Cralley
« Reply #36 on: November 15, 2009, 08:27:36 PM »
I have 2 Ringmaster S-1s
One is an RSM Old Time Legal S-1 kit build. 32 oz
One is scratch built (using RSM S-1 Old Time Legal plans as a guide). 28.5 oz
42" span
383 Sq area
Scratch built has a Turnigy 3245 1000KV (This maybe a little overkill!)
Castle Creations Phoenix 45 ESC (Using Control Line set RPM Governor mode.)
Rhino 4S 1750 20C or Zippy Flightmax 4S 2200 20C Battery
Will Hubin timer FM-2X (custom for CC ESC using Control Line Governor mode set RPM)
(Will now has this timer called FM-2SR at $15)
APC 12-6 electric pusher cut down to 11"
60' lines (eye to eye).
RSM Old Time Legal kit built is the same as above except:
Scorpion 3014-22 motor 892 KV
(Scorpion has replaced this motor with the "new" Scorpion SII-3014-830KV)
« Last Edit: October 05, 2011, 06:35:11 PM by John Cralley »
John Cralley
AMA 52183
Central Illinois
Re: Cavalier 650
« Reply #37 on: November 18, 2009, 03:36:49 AM »
Wing Area               650
Motor                      AXI 28-26-10
ESC                         Phoenix 40 amp
That is Gorgeous!!!
Alan Hahn
Baby Clown
« Reply #38 on: November 25, 2009, 04:45:35 PM »
Strictly speaking, this plane no longer exists  :'(, but during its short life it was a pretty good flyer.
I don't exactly recollect how or why I bought the ARF, but it was pretty cheap and I think Renkar's "It's only a Hobby" 1/2A stunt contest was fast approaching. I was getting a little tired of flying an old hand-me-down TF FLite Streak (irony is I flew that plane in this fall's contest). I also believe that I originally assembled it for my Killer Bee 049, planning to use a Kavin extended Black Widow Tank. As it turns out that didn't work well.
So moving right along, I decided to convert it to electric. At the time I was thinking about the possibilities of making a beginner's electric 1/2A, and thought I would target it with a 2sLipo pack. One motivation was that a beginner might want to use a 6 cell NiMH pack, and that is about the same volts. I also had the motor winding bug back then, and purchased several kits from Gobrushless.com. In the end I went with a GBx1.1 which I wound with 11 turns of 22 gauge wire (this is a 9 tooth stator with 12 magnets). My kV was ~2300 rpm/V. This was a bit on the low side, and since I was limited to a 6" diameter prop (Renkar rules), it was important to get as high a pitch as possible.
Here was the final setup.
Brodak Baby Clown ARF.
GBx1.1 wound 11 turns of 22 gauge wire--kV~2300rpm/V  weight = 1.3oz
Thunderpower Lite 2s730mAHr Lipo (weight=1.14oz with connector)
JMP-2 timer
CastleCreation Thunderbird 9A ESC (no governor mode)
APC E 6x5.5 prop (just one!)
All up flying weight is 6.9oz (plane alone=3.9oz)
I flew on 35 foot lines. Beginner pattern (used in contest) used no more than 1/2 the pack capacity.
Here is a photo with an early attempt at using a multiblade prop!
« Last Edit: December 23, 2009, 07:45:48 PM by Alan Hahn »
Offline Darkstar1
« Reply #39 on: December 20, 2009, 03:24:54 PM »
Modified Eratix 3D Plane
This plane was originally posted with a different setup, but since I snapped the outboard wing off. I will list the changes that made it work this time.
Weight: 66oz
Motor: Rimfire 42-50-800kv
ESC: Castle Creations Ice 50
Timer: Hubin FM-2A
Prop: APC e-prop 12.75 x 4.5
Lines: .015 x 63.5 Eye 2 Eye
ESC set up.
Throttle                                       Brake
Vehicle type: C/L                          Strength: 100%
Throttle type: Gov                         Delay: None
Settings for Gov mode                    Ramp: Immediate
Set RPM
Initial spool up rate: 8                    Cutoffs
Head speed change: 8                    Voltage :Normal
                                                  Current limiting :Normal
Required settings for set RPM           Cutoff type :Hard
Volts: 14.8
# of cells: 4                                  Motor
Motor & gearing info                       Start power: High
Direct drive                                  Timing: 8
                                                  Direction: Fwd
Motor info                                     PWM Rate: 12Khz
KV:800
Magnetic poles: 14
Head speeds
9800 @ 50%
9900 @ 50-99%
10000 @ > 99%
Well at least this is a good start any way. Ill figure how much battery is being used once I start doing full patterns.
Later.
Later,
Evolve or get left behind!
Offline Tim Tipton
« Reply #40 on: December 30, 2009, 08:50:05 AM »
I would like to post my set up.  I need to know if the weight of the airplane includes the battary.  My E-Vector weighs 46 oz. with the battary installed.  36 oz with it sitting on the bench.
Tim Tipton
« Reply #41 on: December 30, 2009, 12:26:54 PM »
Electric converted Baby Ringmaster (Pat King kit patdk@aol.com)
Flight weight = 7.7 oz
Wingspan = 24+ inches (modified to extend an extra 4 inches)
Area = 112 sq inches
Wing loading = 9.2 oz per sq foot
Motor = Turnigy 2822 at 1400KV
Prop = APC thin electric 7/5 pusher
RPM = 11500
Current = 5.4 Amp
Battery = Rhino 3S 460 20C
ESC = Castle Creations 10 Amp in Control Line Governor Set RPM mode
Timer = Will Hubin FM-0d
Static thrust= 8.5 oz
« Last Edit: May 28, 2010, 07:43:32 PM by John Cralley »
John Cralley
AMA 52183
Central Illinois
« Reply #42 on: January 09, 2010, 08:41:03 AM »
Brodak Baby Flight Streak Conversion
(Kit was built stock except the addition of a battery box on outboard wing.)
RTF weight = 9.3 ozs
Wingspan = 26.25"
Area= 150 sq in
Wing Loading = 8.93 ozs/sqft
Motor = Arrowind 2040-24 in-runner @ 2200 Kv
Prop = 4.7 x 4.2 APC Speed 400 Prop
RPM = 19,000 static
Current Ststic = 10.5 amps
Battery = Rhino 3S 20C 1050 (Lightened by replacing leads, shortening balance plug, and removing shrink wrap and replacing with Kapton Tape.)
ESC = Turnigy Plush 9gram 10 amp
Timer = JMP-2 (Flight Time set to 3:00.  First flight speed set to 85% throttle for 1:30, then upping to 100% before end of flight.  (2) flights on (1) pack)
Static Thrust = approx 14 ozs (calculated)
Lines = 0.008" x 42'
Lap Time = 3.2 sec/lap
Airplane is very fast and can do the whole pattern in 3:00.  Have flown in up to 18mph wind with no issues.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
« Reply #43 on: January 29, 2010, 06:55:27 PM »
Brodak Super Clown Sport Package (BH-1831)
Motor: Arrowind Outrunner 2815-09  kV = 920 (3.9 Oz)
ESC: Arrowind 35A (1.3 Oz)
Timer: Will Hubin - FM-0c (adjustable time 1.45 to 6 min and power 60-100%)
Battery: Arrowind 3300mA 3S1P 20C (9.4 Oz)
Prop: 9 x 4.5 E
Brodak Pathfinder
55" wingspan
620 sq. in.
Motor: Turnigy 35-48 B kV: 900  (Weight: 5.75 Oz)
ESC: Castle Phoenix ICE LITE 50 (Wt: 0.8 Oz) Set RPM mode
Timer: Will Hubin FM-2 (adjustable RPM, Delay & Time)
Battery: Turnigy 3300mA 4S1P 20C (Wt: 12.6 Oz)
Prop: APC 12 x 6 EP (pusher)
All up Weight: 53.0 Oz
Lines: 61' x .015 eye to eye
RPM: 8700
Laptime: 5.4 sec
mAH used in 6 min flight: ~2400
« Last Edit: March 17, 2010, 03:45:29 AM by Warren Leadbeatter »
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Vincent Corwell
E Nobler happy days
« Reply #44 on: February 12, 2010, 11:43:20 AM »
E Nobler, scratch built, full take-apart, 2 piece fuselage,2 piece wings,removable tail
removable fin/rudder, long top hatch with full access to power train and controls so also is
fully adjustable. Final weight is 53 ounces, flies a sweet pattern plenty of line tension
Axi 2826/10, Hyperion 2500mah 4cell 25C quick charge batteries, Schultz F2b ESC, Hubin
timer, isolating switch on red battery lead to ESC, 12x6 APCE pusher prop, on 60 foot
015 lines lap time is 4.99secs, flight time is 5:40mins take off revs 8000
Special thanks to Wil Hubin for help above the call
Vincent
NO NAME
« Reply #45 on: March 12, 2010, 07:51:08 PM »
Original Design  (no name yet)
Span          55"
Area           580 sq in
Weight        50 oz
Motor         Hacker A30-10XL   900RPM/V
Controller    Hacker X-55-SB  (55 Amps)
Battery       4S 3200 mAh  (Electri fly)
Prop           12-6 APC Electric
Lines           66.5'  X 0.018
Set for about 80% max RPM.. (Will get tach read and lap time)
This plane is now shown on www.flyinglines.org under Eugene Prop Spinners (club newsletter).  Will get
some pictures soon as it stops raining.
Floyd Carter
Eugene, OR
« Last Edit: March 19, 2010, 08:12:46 PM by FLOYD CARTER »
Offline John Witt
« Reply #46 on: March 14, 2010, 09:08:27 PM »
Proctor Jenny JN4D-2
87.5 inch wingspan, 10.2 lbs, 1400 sq in. biplane
Turnigy SK5065-380 kV, 1800 watts
CC ICE 100 A ESC
Turnigy 6S 5000mAh battery
17-6 Scimitar prop (scale prop)
flies at 35mph on 70 ft lines
Clancy Arnold 4 channel encode-decode, using throttle and towhook release.
See build thread in Scale Models
John Witt
Edmonds, WA
John Witt
AMA 19892
Edmonds, WA
Offline Bruce Hoffmann
« Reply #47 on: March 15, 2010, 05:01:24 PM »
"Firecracker" - (Take apart)
61oz
650 sq inches (approx)
Eather 13 x 5 " Carbon prop  (shortly to try 13 x 4.75")
9300RPM
5.5 - 5.6 Sec/Lap
Arrowind 2832 motor
Turnigy 3600 4s or Rhino Zippy 3700 4s battery
Uses approx 2300 mah on 6m flight (less 25 secs spool-up)
Hubin Timer
Ice 50 ESC
68.5ft lines (centre to centre)
Bruce Hoffmann
Bruce
« Reply #48 on: March 15, 2010, 09:34:55 PM »
Legacy  Built from Brodak Kit
Weight fully loaded 66oz
Motor  - Turnigy 35-48-900
ESC – Castle Creations Phoenix 45
Timer – Ztron V4
Battery – Zippy Flightmax 4000mah
Prop – APC 13 x 4.5 Pusher
63ft lines
Lap times are a little quick  at 4.9 sec  -this is running at 10,200 rpm – will be taking this down to 9800 or so to slow it down a little.
Flight Time set to 5m 30sec – gets me through the pattern and 6-7 laps after – putting various amounts back in to pack – from 2675 to 3525!!!!!!   The larger limit was at 6minute flights – so hoping I can get it stabilised a lot lower…… only had 12 flights so far
  • AUS-14782
    • My Home Page
« Reply #49 on: March 16, 2010, 12:10:09 AM »
e Vector - Brodak Kit - conversion from IC (was OSLA40) to ECL
Motor: Turnigy SK3542-1000 Aerodrive xp
ESC: Castle ICE Lite 50 - CL governor mode
Timer: Hubin FM-2 remote (set RPM mode)
Battery: Zippy 2650 mAh 4S 20C
Prop: APC 11x5.5E
Using: 1800mAH / 6 mins
Lines: 61' x 0.15 eye to eye
Weight: 50 oz
RPM: 9500
Lap time: 5.2 sec
« Last Edit: March 27, 2010, 01:32:11 AM by Warren Leadbeatter »
Warren Leadbeatter
AUS-14782
