  • June 23, 2025, 07:12:40 PM
Author Topic: List of electric motors for 6S setup  (Read 6463 times)
Offline Vitalis Pilkionis
« on: November 02, 2018, 09:53:18 AM »
In a case someone is struggling to find a suitable electric motor for 6S (5S) setup. Here is the list I have been gathering for some time. Weights and prices are approximate. Updates will be following.
AXI V2 2826/13(F2B)  710kv  177g  98eu
Cobra C-3520/18  550kv  216g  70eu
Cobra C-3520/14  700kv  216g  70eu
Cobra C-3515/18  740kv  178g  65eu
Hacker A30-12XL V4  700kv  177g   92eu
Hacker A40-10S V4  750kv  208g  112eu
Hacker A40-12S V4  610kv  200g  112eu
Hacker A40-14S V2  530Kv  208g  discont
Hacker A40-12S V2  610Kv  208g  discont
Plettenberg Orbit 20-16  720kv  215g  184eu
Plettenberg Orbit 20-18  640kv  215g  184eu
Plettenberg Orbit 15-22  685kv  175g  162eu
Plettenberg Orbit 15-24  620kv  175g  162eu
Plettenberg Orbit 15-26  585kv  175g  162eu
Kontronik Kondor 25-65  650kv  218g  170eu
Kontronik Kondor 25-55  550kv  218g  170eu
Kontronic Kondor 15-69  690kv  150g  160eu
Kontronic Kora 25-10  650kv  225g  discont
Kontronic Kora 25-12  550kv  225g  discont
Kontronic Kora 15-16  690kv  150g  discont
Torcman NT350-20-Z  anykv  220g  149eu
MVVS 8.0/680  680kv  225g  115eu
Scorpion SII-3026  710kv  205g  140eu
E-Flite Power 32  770kv  200g  70eu
ROXXY C35-48/06  700kv  172g  60eu
ROXXY C42-50/07  720kv  195g  70eu
ROXXY D3555/06  590kv  178g  75eu
FOXY G2 C3520-730  730kv  205g  70eu
Pichler Boost 45 V2  700kv  185g  63eu
Simprop Magic Torque 40-07  700kv  175g  52eu
PA Thrust 45  740kv  205g  99eu
T-Motor (Tiger) AT3520-6  730kv  206g  74eur
Dualsky XM4250EA-7  640kv  209g  55eu
Dualsky ECO 3520C V2  680kv  210g  53eu
LEO-Dualsky 3520-0500  500kv  210g  55eu
Fusion 3551/06  700kv  175g  50eu
Hobbystar 3520-07  720kv  205g  40eu
Emax GT2826/06  710kv  175g  35eu
Joker V3 4250-6  680kv  210g  36eu
Joker V3 4250-8  510kv  210g  36eu
D-Power AL 42-06  540kv  199g  58eu
D-Power AL 42-07  710kv  195g  58eu
Leopard 4250-(6T-7T-8T)  720kv-620kv-550kv  208g  42eu
Aeolian C5045/C4110  720kv  210g  32eu
Sunnysky X3520-06  720kv   210g   32eu
Sunnysky X3520-08  520kv   210g   32eu
Turnigy SK3  4240  620kv  194g  35eu
Turnigy G32  600kv  202g  33eu
Aeolian 4250  600kv  205g  30eu
« Last Edit: November 06, 2018, 07:37:31 AM by Vitalis Pilkionis »
Offline John Rist
Re: List of electric motors for 6S setup
« Reply #1 on: November 02, 2018, 12:55:43 PM »
How about Cobra?
« Reply #2 on: November 02, 2018, 02:41:40 PM »
How about Cobra?
Good point, thanks. Corrected.
Vitalis
« Reply #3 on: November 04, 2018, 01:33:53 PM »
Just curious.. What size prop (dia & pitch)  do you use with 550Kv motor on 6 cells?
« Reply #4 on: November 04, 2018, 03:08:47 PM »
Hi Joe,
I know Sergii Solomianikov from Ukraine has been testing Cobra 3520/18 550kv on 6S with 13.5x5.5 3-blade prop. Recently he told me that the motor perform very well with this prop.
And Pavel Kravchenko uses the same prop with Hacker A40-14S 530Kv also with a great success.
Greetings,
Vitalis
« Reply #5 on: November 05, 2018, 09:01:32 AM »
Hi Joe,
Greetings,
Vitalis
Thanks Vitalis. much appreciate the insights. It makes sense now.. lower Kv motors swings larger props at lower rpms.
That looks like a nice prop. Would you know who makes that one? wouldn't mind getting one to check out.  :)
« Reply #6 on: November 05, 2018, 10:50:10 AM »
As I know Pavel Kravchenko makes and sells them. You can contact him on FB easily, here is his profile:
https://www.facebook.com/profile.php?id=100006745386478
Vitalis
Offline MikeyPratt
« Reply #7 on: November 05, 2018, 04:28:26 PM »
E Flight make some really good electric motors as well, E Flight 32 KV 770 is a good example (5 cell 13” X 4”).
Mikey
« Last Edit: November 05, 2018, 04:48:38 PM by MikeyPratt »
« Reply #8 on: November 06, 2018, 05:43:31 AM »
I have added it to the list, although it's not a 6S motor, but who knows, perhaps someone will find a right setup with it and 6S also. Thanks.
Vitalis
Online TDM
« Reply #9 on: November 06, 2018, 07:15:54 AM »
I use this with a 12x6, 12x5, Igor 11x5 UCT 3B
JOKER 4250-8 V3 510 KV  it works effortless.
« Reply #10 on: November 06, 2018, 07:33:45 AM »
Thanks, I'v added it to the list. Just out of curiosity, what rpm do you get with these props and 510kv motor? And do you use any active rpm regulation?
Vitalis
Online TDM
« Reply #11 on: November 06, 2018, 09:44:10 AM »
I get 10500 rpm on the 3 blade. Checked it on the ground. Not sure that was the MAX as it was done with the timer on the ground. I would have to rig something up and bench test to be sure. Yes I use Igor for now. I also have the Fiorotti timer.
More recently I have changed to the 12x6 XOAR electric prop.
« Reply #12 on: November 06, 2018, 12:20:12 PM »
Hm, this is interesting. Let's say we have freshly charged 6S battery, that's ~23V under load.
23 x 510 = 11730 rpm.
That means the motor performs at ~90% efficiency. And that's if we don't count other loses.
Vitalis
Online TDM
« Reply #13 on: November 07, 2018, 06:35:57 AM »
Looses usually show up as excessive heat, and I can shut down the motor touch it with my hand and a little warm for sure mot hot at all. So I don't really have excessive looses in the system.
I will make a bench test and will update the information.
« Reply #14 on: November 07, 2018, 08:17:29 AM »
Anyway I think you should use that motor with a 13x6 prop. Then it will work in it's sweet spot.
Vitalis
Online TDM
« Reply #15 on: November 09, 2018, 06:39:40 AM »
I will try the 13in props in the spring after I do the gear modification. That prop might be hurting the corner a little on my model. It is likely that if I go to the 13in diameter I might end up with a 13x7 or even 13x8 and use battery 5S or 4S but that is not the subject of this topic.
Offline Mike Alimov
« Reply #16 on: November 15, 2018, 08:03:46 AM »
Vitalis, you seem to be a big fan of 6S setups.  I might have my ideas as to why, but would you please elaborate for everyone's benefit?
Coincidentally, I'm designing a new airplane for my kid, and this discussion is very useful.
« Reply #17 on: November 16, 2018, 02:16:27 PM »
Well, it's a simple story. When four years ago I started look into electrics I read a lot of information and decided that Igor's setup was the most advanced and sophisticated. So I invested in Igor's active timer and that's how it started. And I never regret I did. Actually that saved me a lot of time, because the setup has always been reliable and trouble free, so I could spend more time on flying. And now I don't see a reason I should go other way. Next year I am going to try 550kv motor with the new ukrainian prop, but still this will be 6S setup.
Vitalis
Online Frank Imbriaco
« Reply #18 on: November 28, 2018, 06:45:49 PM »
Vitalis :
I'm considering swapping out the E-Flite Power 15(950KV, 5.4 ounces) with  4S passive system in my Caprice (Classic ) for either an AXI or Cobra .  Since you have already done a lot of research, what is a comparable motor  with, of course, a lower KV rating ?
I plan to go 6S with an Active timer; possibly Igor's system. The primary considerations ,as I see them, are weight, KV rating and ability to swing a 3 blade . I believe that a 9" or 10" (at most)  with a 4.5 or 5 pitch three blade would be about right. Need to find out who is producing carbon fibre props of this size that are suitable for our purposes.
Offline Igor Burger
« Reply #19 on: December 09, 2018, 03:34:59 PM »
There is no "automatic" reason for 4 or 6 cells. When I designed 6 cell setup, I used rather higher voltage and lower current because Spin ESC has upper limit 6 cells and it will run at lower current. Plus there were more available motors in usefull range and plus differnce between 6 and 5 pitch prop with the same motor responds to 5 or 6 cells. Usage of constant RPM or active timer setup is also aproximately one cell (6 vs 5 - while 3 vs 4 or 4 vs 5 is already too much). Simply it was easier with 6 cells.  However if you can find proper combination of prop / motor / battery with 4 cells, it is not going to be worse or better than 6, both have some +es and some -es.
If I can recommend something, then use well tested combination of prop - motor - ESC - timer - battery. Only when you see how it should/can work, start with experimenting. There are too many wrong combinations and olny few those well ballanced and it is always good to have chance to compare  :)
Offline Daniel_Munro
« Reply #20 on: April 07, 2022, 02:37:27 PM »
I see the Scorpion 3026 710kv is on this list. I have one of these motors. Though go to Scorpion website and it suggests max 5s battery for this motor. Has anyone successfully run one on 6s? I don’t own any 5s batteries and would rather stick with 6s but don’t want to let the smoke out of this motor.
NZL7396
