  • July 17, 2025, 05:07:04 AM
Author Topic: Lippo to Li-Ion  (Read 183 times)
Lippo to Li-Ion
« on: July 15, 2025, 06:18:55 PM »
Looking at the 6S 2600 Mah Li-on battery packs in the classifieds I was wondering, are these a direct plug and play replacement for 6S 2800 mah Lippo batteries.
MM :)
Re: Lippo to Li-Ion
« Reply #1 on: July 15, 2025, 11:19:24 PM »
In the four that I have in rotation, the one 2600 performs no differently than the three 2800s.
Re: Lippo to Li-Ion
« Reply #2 on: Yesterday at 01:49:53 PM »
Any setting changes needed other than the charger?
Re: Lippo to Li-Ion
« Reply #3 on: Yesterday at 01:57:50 PM »
None  The 2600 has enough "head room", the 2800 has more.  I don't make any changes to the charger either.
On my charger a LiIon will charge just fine using the Lipo setting.  I get a slightly smaller charge before it stops but is well over what I need.  Makes it simpler when you have both.
Offline Crist Rigotti
Re: Lippo to Li-Ion
« Reply #4 on: Yesterday at 02:51:33 PM »
Ken, OP was asking the difference between 2600mah Li-ion and 2800mah Lipos.  You are comparing 2 Li-ion batteries.
Re: Lippo to Li-Ion
« Reply #5 on: Yesterday at 04:43:56 PM »
As usual you are exactly right.  The answer is similar.  The LiIon will "sag" a bit sooner than a Lipo but they can be run down considerably more than the Lipo and the timer makes them pretty equal.  The Lipo should be > 20% "head room" where as the LiIon will probably be < 10%.
