Electric Stunt => Gettin all AMP'ed up! => Topic started by: Motorman on July 15, 2025, 06:18:55 PM
Title: Lippo to Li-Ion
Post by: Motorman on July 15, 2025, 06:18:55 PM
Looking at the 6S 2600 Mah Li-on battery packs in the classifieds I was wondering, are these a direct plug and play replacement for 6S 2800 mah Lippo batteries.
MM :)
Title: Re: Lippo to Li-Ion
Post by: Ken Culbertson on July 15, 2025, 11:19:24 PM
In the four that I have in rotation, the one 2600 performs no differently than the three 2800s.
Post by: Motorman on July 16, 2025, 01:49:53 PM
Any setting changes needed other than the charger?
Post by: Ken Culbertson on July 16, 2025, 01:57:50 PM
None  The 2600 has enough "head room", the 2800 has more.  I don't make any changes to the charger either.
On my charger a LiIon will charge just fine using the Lipo setting.  I get a slightly smaller charge before it stops but is well over what I need.  Makes it simpler when you have both.
Post by: Crist Rigotti on July 16, 2025, 02:51:33 PM
Ken, OP was asking the difference between 2600mah Li-ion and 2800mah Lipos.  You are comparing 2 Li-ion batteries.
Post by: Ken Culbertson on July 16, 2025, 04:43:56 PM
As usual you are exactly right.  The answer is similar.  The LiIon will "sag" a bit sooner than a Lipo but they can be run down considerably more than the Lipo and the timer makes them pretty equal.  The Lipo should be > 20% "head room" where as the LiIon will probably be < 10%.
